Offline Frostie
#1 Posted : 14 March 2008 23:34:04(UTC)
Frostie
Does anybody have any experience with these building kits ?
they look very good and I think the look more era 1/2 than most others as a manufacturer.
But they also are pretty pricey. But my plans are not for many buildings on my layout, so that is not too bad.
But they look very nice !
CS/MS Digital Era 1/2
Offline Chriscam
#2 Posted : 15 March 2008 02:34:27(UTC)
Chriscam
I haven't built one myself but I have taken a close look at the kits Walter at Euro Rail Hobbies keeps in stock and they are quite impressive. I would not recommend them to a beginner but an experienced modeler should not have too much trouble. I have seen some photos of layouts done with all MBZ structures and they look amazing.
Walter has a good video on his site showing the process of putting an MBZ kit together that may give you a better idea if it is something you want to try out.
http://www.eurorailhobbi...ilHobbies.asp?pageid=484
Chris
Offline kbvrod
#3 Posted : 15 March 2008 03:53:09(UTC)
kbvrod
They seem to fit together well,still a long way around the barn,...
DR Dirt
Offline Frostie
#4 Posted : 15 March 2008 05:22:27(UTC)
Frostie
I viewed the video just now, and it is a really good demonstration of using washes.
They really have some glod items that look old "timey" era 1/2 ish for me.And are giving me more layout inspiration.
Offline Sander van Wijk
#5 Posted : 15 March 2008 14:27:41(UTC)
Sander van Wijk
Wow! I saw some of their stuff before, but this video is definitely convincing. If I'll ever have both time and space to build a layout, I'll certainly try their products.
Thanks for sharing!
Sander
Offline PierreGILLARD
#6 Posted : 15 March 2008 16:39:43(UTC)
PierreGILLARD
[size=1" face="Verdana" id="quote]quote:Originally posted by Sander van Wijk
<br />(...) If I'll ever have both time and space to build a layout, (...)
You are not alone in that situation ! biggrin
Thanks for the link, Chris. wink
Pierre.
Offline Caplin
#7 Posted : 15 March 2008 16:45:55(UTC)
Caplin
Very instructive video. Thanks for the link.
BTW I couldn't get any sound. Was it audible with you guys?
Benny - Outsider and MFDWPL
Offline ulf999
#8 Posted : 15 March 2008 20:25:09(UTC)
ulf999
Looks like very nice kits.
Offline jeehring
#9 Posted : 23 October 2010 15:16:59(UTC)
jeehring
....following the web-link mentionned above I can't find any video about MDZ Thomas Oswald....could you re-direct me please ?
I've found pictures only :railways building, farms etc...look very nice....is it laser cut cardboard ? Unfortunately they don't give measures...Do you know if it is colored already same way as we see on photos or if we have to paint it by ourselves ? ( do they give instructions about colors & paint ?) I like those wooden sheds, wooden workshops & buildings...
Most of the buildings are from era 1 or 2....this is what I like, as we can use them also for era 3 - era 4 - why not era 5 - sceneries.
Anyone to direct me also to an authorized MDZ retailers with access to the complete range, here in Europe (or France ? )
Thank you
RECTIFICATION : they say it is mainly laser cut wood or plywood....it seems that we have to paint them.....I hope we can find accurate instructions about it.... a pleasant hobby for winter evenings !
Offline jeehring
#10 Posted : 23 October 2010 15:34:51(UTC)
jeehring
.....sorry , ...I've found the MBZ site....it seems to be in German only...Sad
http://www.mbz-modellbah...behoer.de/news/index.htm
....in fact they use cardboard as well...
Offline Bob24
#11 Posted : 17 August 2024 06:04:46(UTC)
Bob24
20240816_215239 (1).jpg.I recently completed an MBZ Water Tower, Z scale. It went together more easily than I anticipated. The instructions were in English and German. The walls had tabs that went into slots which made it easy to align the walls. I have a few more MBZ buildings to complete as time permits. They require painting and priming. You can still get them at Euro Rail Hobbies and Reynaud's. Also you can order them from directly from MBZ. I don't know what the minimum order amount is through MBZ. I bought quite a few items. Let me know if anyone has recently completed any. Sorry about the orientation of the pictures.
thanks 1 user liked this useful post by Bob24
Offline Bob24
#12 Posted : 30 September 2024 03:15:12(UTC)
Bob24
Just finished this MBZ Z scale Water Tower. Took a while to complete it, but well worth the time.20240929_213720 (1).jpg
Edited by user 30 September 2024 17:33:03(UTC)  | Reason: Not specified
thanks 3 users liked this useful post by Bob24
#13 Posted : 03 October 2024 20:28:28(UTC)
Very Nice.
I've got several kits waiting for me to do including a big station.
Did you use the MBZ primer?
Any tips/gotchas/learnings from the application of the primer, to the painting and using of powders, etc to colorize the primed models?
Offline Bob24
#14 Posted : 04 October 2024 03:46:39(UTC)
Bob24
I used the MBZ Paraloid B72 crystals that you dissolve in acetone to make primer. It worked well. I also got some of the some MBZ primer( ArtNr.72 214) from Reynaulds, but the bottle was only two-thirds full so I concluded it had evaporated. I may add some acetone to it and use it later. A few of my pieces were not well cut on one water tower and had tabs missing. I sent MBZ some pictures of the plates and Herr Oswald sent two replacement plates, so he is good to work with. There are some videos on painting and some instructions on the MBZ website. I dabbed my brush in acetone periodically while applying primer so as not to get too thick a coat. I used pigment to paint for the first time and followed the instructions. The exact amount of binder is trial and error. I added a bit more binder as I went along because I thought the paint was too powdery when dry. I was careful to do light coats of paint so as not to get the cardboard too damp which could cause warping, etc. On the pump station I first just dusted with dry pigments and later put primer over the dry pigment and it worked well. The pieces went together amazingly well, even in the areas where there were no tabs. I work extremely slowly and cautiously. I'd starve if did this for a living. The water tower lights up well.
Offline Bob24
#15 Posted : 04 October 2024 03:51:58(UTC)
Bob24
Here are pictures of the pump station with the primed over dry pigment and the lit-up water tower.
#16 Posted : 04 October 2024 04:04:15(UTC)
I got sent a metal can of the primer.. its in the metal tins like 72-224, which may be the same stuff just larger quantity. I imagine he picked out the size to match the various kits I purchased. Since I'm building the giant Bahnhof Bebra (10528 ), its gonna take a good bit. Go big or go home. For me the station itself was the unicorn - I grew up around that station in my youth and to find there was a model of it available for such a historic but now irrelevant station, struck me as a miracle. Had to buy it.
Did you use the pigments MBZ sells or some locally sourced pigments. I wonder how well acrylics if near dry brushed would work, or if that would be a problem for the card stock structures. I'd asked him but didn't get an answer, so maybe I'll just ask again, what a base set would be of pigments for the buildings I was building. As I have no experience I have no idea what amounts of which pigments, particularly if one mixes, one needs for certain coverage. I imagine if I ask again I'll get some better guidance how much and which colors of pigment to do Bebra the way it is shown in the photo.
This page was generated in 0.447 seconds.
