Offline chelseadrake
#1 Posted : 12 October 2012 11:34:52(UTC)
chelseadrake
was wondering if anyone had any tips for this as usual?
I was thinking of switching the small rubbing cloth for a q-tip but still soak it with a bit of the alcohol and just take quick swipe at each dirty stud in question .. but then I realize that its of a different metal so thought I would ask here just in case
Offline tulit
#2 Posted : 12 October 2012 12:51:58(UTC)
tulit
I just use a high grit sandpaper and very gently give it a quick pass over the studs. For me this has worked the best.
Offline witzlerh
#3 Posted : 12 October 2012 17:29:16(UTC)
witzlerh
I use a white eraser dabbed in alcohol. I only drag it across the studs, no force.
I have used paper or a fine stone on rusty studs. This is the only place I used sandpaper. It is not recommended to used sandpaper on rails as the scratches ususally will attract dirt.
Harald
CS2 DB & Canadian Era 3-6
Offline kbvrod
#4 Posted : 12 October 2012 20:39:40(UTC)
kbvrod
Offline Ross
#5 Posted : 13 October 2012 00:50:48(UTC)
Ross
Hi Kevin,
Thanks for the interesting link.
I also wrote some articles on how I tackled this problem which are similar to the links you provided.
Centre Stud Cleaner and Lube
Edited by user 02 January 2025 04:36:55(UTC)  | Reason: Link corrected 02-01-2025
Ross
Offline Brakeman
#6 Posted : 13 October 2012 06:40:15(UTC)
Brakeman
Hi Kevin,
http://members.ozemail.com.au/~...entre_stud_clean_lub.pdf
and
http://members.ozemail.com.au/~.../centre_stud_cleaner.pdf
Thanks Ross and Kevin,
I've used a similar slider covered with 800 sandpaper.
BR,
Juha
Offline drstapes
#7 Posted : 21 October 2012 03:52:25(UTC)
drstapes
For track cleaning I have always used a simple abrasive rubber as made by Peco etc. I guess it removes the original protective covering on the M track rails but I have never had any particular problems with this.
Geoff (UK)
#8 Posted : 21 October 2012 08:45:41(UTC)
Me too... Works great.. The trick is to keep running trains after you have cleaned the track..Smile
This page was generated in 0.461 seconds.
