#1 Posted : 03 July 2011 17:53:57(UTC)
As I've mentioned before, the latest generation 4 decoders have the Lenz railplus protocol build in. (by the way Zimo is using it as well but apparently without the consent of the owner)
It is more or less the same system as the MFX or M4 the difference is it is an open protocol and all CV's are reachable.
Furthermore, the difference between the previous M4 and the Märklin MFX is, the loco identifies it self and asks the question, do you want an automatic address or would you like your own address.
Say for instance you type in 500, the address will than be 500.
You than read the decoder on your lok programmer it still shows the address as 3(interesting).
The moment the loco is registered with the ECoS, even if you take it off the track it doesn't have to re-register again.
Another point I like to make, if you program the loco on your lok programmer 4.1 e.g. to this address, the ECoS will not recognize the loco
regards.,
Edited by user 03 August 2011 04:01:48(UTC)  | Reason: Not specified
#2 Posted : 03 August 2011 04:21:30(UTC)
Other possibilities with an Version 4 ESU decoder.
Lights: Output: there are many options to have your headlights and marker lights programmed to your satisfaction, e.g. consists, high beam - low beam.
digital uncouplers: pulse time regulated
Fir box light and many more functions to change your light configuration., e.g. dimmer, fade out, brightness and a dozen or so different light effects.
Lights mapping: here you can change or add functions to your lights or function setting.
Gearlight: program it, so it is turned on while the loco is at a standstill and will go off when loco is moving, same applies to your fire box light or interior cab light.
With a 21 pin adapter plate you also have the opportunity to program your Function 3 & 4 independently giving you 4 function outlets.
for instance:
Aux 1 = Smoke gnerator
Aux 2 = digital uncoupler (Telex coupling) with time out function (front)
Aux 3 = as above (rear) or fire box
Aux 4 = Gear light & Interior cab light connected together with light diminishing when loco is in motion.
Speed curve: measured in km/h
other improvements and new functions have been implemented and the findings will be published in due course.
regards.,
#3 Posted : 03 August 2011 05:00:54(UTC)
Interesting that there is no (as yet) m4/mfx version of the Loksound 4. While I have an Ecos, and can therefore make use of Railcom, I also have a CS1 and a CS2. Which means that the Marklin controllers will have to use the MM protocol to control Loksound 4 equipped locos, and only have access to 4 plus 4 functions (assuming the 2nd address is programmed in CV75). Bummer!
#4 Posted : 03 August 2011 07:01:10(UTC)
Lokpilot has M4 so I expect it should not be too long before loksound has it also
NN
#5 Posted : 03 August 2011 09:33:24(UTC)
Lokpilot has M4.......
Really Confused Confused ???
From the ESU website
"LokPilot V4.0
The LokPilot V4.0, top of the range, speaks DCC, Motorola® and Selectrix®. Armed for the coming NMRA DCC BiDirectional Standard („RailCom®“), it is for all ambitious model railroaders with technical vision and an appetite for new technologies."
http://www.esu.eu/en/products/lokpilot/
http://www.esu.eu/en/pro...s/lokpilot/lokpilot-v40/
Lokpilot 3 has m4, but no mention of it for Lokpilot 4.
#6 Posted : 03 August 2011 15:04:11(UTC)
Nev & Dave,.
Loksound decoders V4 are the same as lokpilot 4, recognizes railcom
regards.,
#7 Posted : 04 August 2011 01:54:03(UTC)
OK I was incorrect.
NN
Offline applor
#8 Posted : 12 October 2011 07:25:42(UTC)
applor
Bit of a late reply on this, but you can configure your CS2 to use DCC protocol rather than MM.
#9 Posted : 12 October 2011 09:28:47(UTC)
Thanks Eric. I did actually realise that, after posting my comment above. And with the CS2, I would only need to set the loco up once, and then save the settings to a loco card. Only a minor inconvenience to read the settings from the card thereafter.
Offline old toot
#10 Posted : 27 November 2011 05:57:37(UTC)
old toot
hi david
we have had them for over 6 months
and dion is very happy with them
he says they are great improvement
on the 3.50 with the lower power
for the speakers which we also have to
whole range so if you want them they are
here and yes the whole 12 functions on dcc
I was using one with as customer yesterday
old toot
This page was generated in 0.457 seconds.
