Offline Joseph Meiring
#1 Posted : 07 August 2010 18:11:04(UTC)
Joseph Meiring
I'm back! After some chronic illnesses and hospitalization and various operations, I seem to be OK again! I SO missed the forum!
Anyway, I finally got my 3309 (serial numb E74038, what does that make it, 1983/85??, in the blue clear plastic box); My question: How exactly does the the "smoke set" work. Mine worked once or twice and then simply stopped smoking. I cleaned the little flue with a needle, and bought new M smoke oil, but to no avail. I see there is a little brass tab just above the front globe - is this supposed to get warm, and then heat the oil? - I did notice that when working the telex coupling a few times (the front coupler seems to stick in the up position at times), all of a sudden there was a spurt of smoke! I am told that all the oil must be "used up", otherwise it gets "hard"? How is one supposed to clean it out?
Lots of questions, hope someone can help....otherwise it runs well, and is in very good condition.....
its good to be back folks!!
M track Joe
Offline Ian555
#2 Posted : 07 August 2010 18:15:05(UTC)
Ian555
Hi Joe,
Good to have you back mate.ThumpUp
Ian.
#3 Posted : 07 August 2010 20:02:11(UTC)
Joe,
Good to hear you've got your health back.
3309 smoke unit:
several things can go wrong with this.
a.) contact from the smoke unit to the chassis chimney.
b.) underneath the smoke unit there is a contact wire, use a fine file or nailfile and go over once and take off any corrosion
c.) the little brass tab could also have a little clean.What I do, put solder on it. make sure it is bent up enough to have contact with the smokeunit.
The telex coupling is a hard one and not easy to fix. Unless you know what your doing you could to more harm than good.
the only thing I can recommend, take both apart and observe the angle and everything elsre on the one that works and than look at the one that sticks and see if you can see anything different, especially the arm that lifts up when the solenoid is activated.
It almost works like a seesaw, iot gets lifted when the solenoid is activated and droppes when the solendoid is turned off. if that arm is not absolutely straight, the arm does'nt fall back down.
#4 Posted : 07 August 2010 20:16:44(UTC)
Hi Joe,
Glad to see you're feeling better. Welcome back!
Online steventrain
#5 Posted : 07 August 2010 20:33:15(UTC)
Hi Joe, Good to see you well.Smile
3309 in plastic window box date 1982-1985
Running number 85 007.
Online steventrain
#6 Posted : 07 August 2010 20:40:03(UTC)
See information on serial number topic here https://www.marklin-user...aspx?g=posts&t=14737
#7 Posted : 08 August 2010 00:28:33(UTC)
Should be 1987, then... Looked at my 3308 which was also delivered in that clear/blue plastic box and it seems to be from 1985 with a serial number starting with E5...
I have not seen any other locos but the 3308 & 3309 packaged in this kind of box, so I wonder if there are any other 80's models that were sold with this (rather flimsy, I must say..) packaging?
#8 Posted : 08 August 2010 04:14:24(UTC)
Welcome back Joe.
#9 Posted : 08 August 2010 05:49:34(UTC)
Pleased to hear that you are well Joe.
REcently I was having problems with Telex and Smoke.
I did a factory reset of the decoder. all problems went away.
Nev
Offline applor
#10 Posted : 08 August 2010 08:48:29(UTC)
applor
If only someone made the BR85 in era3a :(
#11 Posted : 15 August 2010 22:02:29(UTC)
Joseph Meiring
thanks everyone for the good wishes! Much appreciated....I have decided to let the experts look at the probs with the 3309 telex coupler and smoke issues, and so sent it off to the dealers....could end up with more hassles if I start to scratch where I shouldn't!!
m track Joe
Offline Munich 1860
#12 Posted : 20 August 2010 03:41:56(UTC)
Munich 1860
Hi Juhan,
no other lokos in the plastic packaging, just those two ... I believe that was an experiment, and that it failed. Is your box still complete, nothing broken?
Many greetings,
Hans
Offline mrmarklin
#13 Posted : 21 August 2010 01:21:35(UTC)
mrmarklin
Munich 1860 wrote:
Hi Juhan,
Many greetings,
Hans
All the boxes are broken!!!!!BigGrin
Re: smoke. I think if you are analogue, there has to be a certain amount of current in the track for the smoke unit to work consistently well. That means high speed running.Scared
I conveerted mine to digital, and love this engine that way.
#14 Posted : 22 August 2010 21:35:05(UTC)
I have both the 3308 and the 3309.
The smoke unit in 3309 worked perfect, the 3308 did not work very well. This was before converting to digital.
I found that the ground connection between the loco body and chassis was poor.
After examination I found that on both sides of the "chimney" there are metal support "surfaces" that fit down into grooves in the loco chassis.
Photo of the similar grooves (inside the rivests for the cylinders) in 3084:
I removed the paint from both the loco body support surfaces and from the chassis in the bottom of the grooves.
After that the smoke unit worked perfect, also after converting to digital.
For the reference:
Märklin 3308, DRG 85006
Märklin 3309, DB 85007
#15 Posted : 22 August 2010 22:17:17(UTC)
Munich 1860 wrote:
Hi Juhan,
Many greetings,
Hans
It is very broken, held together with tape... Lousy plastic, it is... Not made for opening more than once... Crying
This page was generated in 0.738 seconds.
