Offline dpg001
#1 Posted : 15 October 2008 01:10:44(UTC)
dpg001
You have been a member since:: 22/09/2008(UTC)
Just wondering if anyone has any experience in using Viessmann Decoders and S88's in lieu of the Marklin versions when using the Marklin Central Station. For me here in the UK Viessmann is a lower cost option and I would appreciate any opinions that you may have on this subject.
confused
#2 Posted : 15 October 2008 02:56:40(UTC)
I have used them without problems with Intellibox - the Viessmann stuff is better engineered, cheaper and are electrically compatible. Paying more for M stuff is plain silly.
#3 Posted : 15 October 2008 09:56:31(UTC)
Yes, I'd agree with Dale. I'm using Viessmann Signals, Decoders and S88's with my Marklin Central Station, no problems at all. You do need a separate transformer for the decoders, etc, but this means you are not using up precious track power.
Offline frankie
#4 Posted : 15 October 2008 12:26:25(UTC)
frankie
Fully agree, their k83 can be powered separately via the 5215 module which is a plus, same arrangement as Dave.
Alessandro
I have a CS1 Reloaded!
#5 Posted : 15 October 2008 12:49:16(UTC)
I'm using my V k83's without the 5215 power supply.........[:I]
Offline Rinus
#6 Posted : 15 October 2008 14:49:41(UTC)
Rinus
Dale is right. Paying more for Marklin versions in this case is not the smartest thing to do. the Viessmann decoders work great. I use S88's , K83's, the 5215, signals, various light decoders and streetlights from them. they all work great and if you incidentally "kill" one, you will discover they offer a great after sales as well.
Offline frankie
#7 Posted : 15 October 2008 15:11:22(UTC)
frankie
True, I burned a couple of k83, sent them back and they repaired it for few euros, I remember that I almost paid more of shipping than of the fix itself.
Alessandro
Offline frankie
#8 Posted : 15 October 2008 15:12:41(UTC)
frankie
<br />I'm using my V k83's without the 5215 power supply.........[:I]
You should try it biggrin anyway the rest it's just about the same.
Alessandro
Offline mascagni
#9 Posted : 15 October 2008 15:26:23(UTC)
mascagni
It'a unanimous: Viessmann makes great M-compatible k83/k84/s88. They are more reliable, they are often more flexible, and they cost less. BTW, the under the C-track decoders from Viessmann are MUCH BETTER than those from mutter Maerklin. The only thing I can think of is that they may be negative is that don't come in a Maerklin box).--MM
Michael Mascagni, Tallahassee
Offline rschaffr
#10 Posted : 15 October 2008 15:58:14(UTC)
rschaffr
I concur. I have bought nothing but Viessmann items for the past few years.
-Ron
Offline dpg001
#11 Posted : 15 October 2008 23:37:44(UTC)
dpg001
As I rather new to this. How are the s88's connected. I intend to use two 5211's controlling 8 turnouts (is this necessary as I have two turnout switches 1 x per entry and 1 x per exit, they are back to back) and how many s88's would I require.
I'm not sure oif this ios clear, but here goes.
Offline mascagni
#12 Posted : 16 October 2008 00:06:05(UTC)
mascagni
David: S88 modules are used to detect small currents, and are used to report on track occupancy with the use of special tracks and other tricks. However, you do not S88's to control turnouts. You need the S88's if you plan to use track occupancy to trigger events using a digital control system.--MM
Offline dpg001
#13 Posted : 16 October 2008 11:06:08(UTC)
dpg001
Michael,
What I am trying to achieve is some sort of automation. The Viessmann 5211 is clearly controlling the switches. The question of track occupancy, I'm assuming that this would suggest that the track will be split into active sections and that the S88 provide feeback on where on the track the lok is located. This then through the Central Station means somehow (yet to be discovered)this all works together. This is all new to me hence some lack of awareness.
David
#14 Posted : 16 October 2008 11:21:21(UTC)
David, there are a number of sensors you can plug into a S88 - contact tracks as already discussed, reed switches mounted in the track at some point, or circuit tracks, which have a lever built into the track which is activated by a loco's pickup shoe.
Contact tracks are activated by the wheels of a loco or car shorting out both rails of the track - one track is isolated from the other, and shorts out when a wheelset goes over it. Reed switches are activated by a magnet fixed to a loco/wagon, that activates the reed switch when the magnet passes over it.
Contacts are good for when you want to detect the presence of a train in a particular track section, reeds are good for when you want to know whether the start, middle or end of a train has cleared a certain point, and circuit tracks are good for when you need to know the direction a train is travelling in, such as for shuttle trains that move from the end of one part of track to the other end, then reverse direction.
Having got your sensors sorted, you use the S88's to detect the sensor activation, and you program your CS or your software to take certain actions based on what sensor is activated. For example you might switch a point for one sensor, set a signal for another, and stop a train for a third. Possibilities are endless.
Offline frankie
#15 Posted : 16 October 2008 11:49:34(UTC)
frankie
Viessmann makes also a specific s88 to detect occupancy, based on the drawing of current from the track, but this requires to isolate completely sections of track, which may require extra feeds around the layout.
Alessandro
#16 Posted : 16 October 2008 14:25:38(UTC)
Alessandro. Can you give me the number of the above Viesmann s88.
David
Offline fvri
#17 Posted : 16 October 2008 14:28:13(UTC)
fvri
Hi David,
Alessandro is talking about the Viessmmann item number 5233 (8 inputs, current based).
The S88 corresponds to the 5217 of Viessmann (mass based).
I can also confirm that I'm pretty happy with the Viessmann products for track occupancy detection. In the last 6 years no failures... .
Important remark when mixing them in a chain in use for ECoS/CS please group first the 5233's and then the 5217's.
Br,
Frank
Offline mascagni
#18 Posted : 16 October 2008 14:47:01(UTC)
mascagni
David: If you need S88 units, you also will need tracks that can be used as detectors and hooked up to S88 inputs. Based on what you use to detect occupancy means that you will hook those up to different S88 modules from Viessmann, some have 8 inputs and some 16 inputs. Thus, the question you have to solve now is what you will use to see your trains on the track. Then, you can choose the appropriate electronics.
Good luck, enjoy your hobby.--MM
Offline frankie
#19 Posted : 16 October 2008 15:34:56(UTC)
frankie
Well, with the 5233 actually you only need to have isolated track sections.
What you say, the need for a specific track or reed contact, applies if you use the 5217.
Strange that when it comes to this topic is just the 5 or 6 of us...
Alessandro
Offline Caplin
#20 Posted : 16 October 2008 15:48:01(UTC)
Caplin
[size=1" face="Verdana" id="quote]quote:Originally posted by frankie
<br />Strange that when it comes to this topic is just the 5 or 6 of us...
You are the experts!!wink
Unfortunately, I have nothing to offer having no layout plan, but be assured that I follow your writingsSmile
Benny - Outsider and MFDWPL
Offline mascagni
#21 Posted : 16 October 2008 16:18:39(UTC)
mascagni
Alessandro: Perhaps there are not really that many people who use feedback. I suspect a very interesting thing to do on this forum would be to set up a poll/questionnaire(polls are REAL BIG in the US right now!!) to find out what people who use this forum ACTUALLY do with model railroading. How many of us are digital/analog/mixed, how often do you play with your trains/your kids, do you feedback, are you a member of a model railroading club, Obama/McCain? This would be interesting.--MM
Offline Renato
#22 Posted : 16 October 2008 19:17:29(UTC)
Renato
<br />Well, with the 5233 actually you only need to have isolated track sections.
at the moment I have only 4xK83, 1xK84 and 1xS88 from Marklin, but reading your posts and your positive experiences, now I can decide to buy Viessmann components too (and this is my 100th post!).
Renato
#23 Posted : 16 October 2008 19:20:03(UTC)
Hi Guys Thanks for info. The 5233 looks interesting as from what I read it only needs an isolated section of track. Can I presume that when a loco enters the isolated section of track this will show on the CS screen. Lighted coaches with a centre pickup would also show ? What happens when a loco with a lighted coach enters the isolated section of track?
Sorry to be vague about this but I have not used this item from Viessmann.
David
Offline frankie
#24 Posted : 16 October 2008 20:26:10(UTC)
frankie
This box reads that "something" is drawing current from the tracks, then it takes a little bit more planning on how to divide the layout in isolated sections depending on the lenght of your train and if it uses lighted coaches or not, plus since you have to insulate both red and brown, you have to plan on how to redistribute the power to the tracks to avoid blind spots.
That's one reason why ones uses conducting couplers taking the power for the coaches from the loco pick-up, for example.
I think it can be useful on large layouts, with long straight tracks, where you can replicate blocks like in the real thing.
You need an upgraded CS1 for s88 though, as far as I can remember you kept yours as it was, right?
Alessandro
Offline fvri
#25 Posted : 16 October 2008 20:26:53(UTC)
fvri
Hi David,
Correct, every object(eg. train, coaches with a pickup) that enters the isolated current section that draws current will trigger occupancy in the 5233.
I use them for my M-rails as it easier to setup an isolated 'current' section. For my C-rails I use the 5217. Easy to make contact rails in C.
Br,
Frank
#26 Posted : 16 October 2008 22:12:22(UTC)
Hi Alessandro You are right that I have the original CS1 but was going to order the CS2 although this is now on hold until the problems are sorted.
If just using a short piece of isolated track would the CS2 indicate when the loco passes this and then disappear when the loco leaves the isolated section.
Can the unit be used for 8 different sections of track amd I presume has an address for each section. I have a few long tunnels and would like to know just where a loco has reached in these tunnels and this looked like an easy and fairly cheap way of doing this.
Many thanks for your help .. much appreciated
David
#27 Posted : 17 October 2008 01:48:26(UTC)
King Flash Dave, the CS1 sure gives you an indication when a sensor has been triggered, so I would assume the CS2 would as well. With the CS1 you do have to go into the S88 setup screen (similar area to where you set up the MS), but visual idication is given there when a sensor is triggered.
Offline frankie
#28 Posted : 17 October 2008 11:56:41(UTC)
frankie
Actually s88 is designed for retro action, that means activating a switch or a route when the loco triggers the contact, then is not really designed for just signaling the presence of the train.
I mean, for your tunnels, it can do more than telling you where the train is, it can set switch and signals appropriately to keep your layout safe, just like the real thing.
Just my two pennies worth, with the upcoming release of a 3.0 upgrade I would rather go for an Ecos, it will be free for this controller, it's a mature product and you have a couple of software to choose from to control your layout for free too.
Obviously that developed by Frank is much betterbiggrin[:I]biggrin
Alessandro
#29 Posted : 17 October 2008 14:25:40(UTC)
Thanks guys. I will invest in a 5233 and see how it goes.
My only other item bought from Viessmann is their three way turnout decoder which is excellent and much better than the Marklin set up.
David
Offline huttel
#30 Posted : 17 October 2008 20:47:45(UTC)
huttel
Hi all
Can also only recommend Viessmann. So far I have 9x16 Viessmann 5217 S88 feedback modules and a lot of the 5211 and 5231 decoders. Works great. I use C-track and have first isolated the two tracks and then split the layut in blocks all controlled by WinDigiPet on my laptop cónnected to my IB. Works like a dream Smile
Btw does anyone now if the Viessmann S88 feedback and decoders can be used with the CS2? I would expect them to...
For power and control I use Uhlenbrock.
Rgds,
Thomas
Carpe Diem!
Märklin HO | Insider | C-Track | Digital | Primarilly DK & D | Era III+IV | PC Control with CS2 (60215), Intellibox & Win-Digipet | http://huttel.dk/marklin
Offline dpg001
#31 Posted : 18 October 2008 12:32:23(UTC)
dpg001
All sounds very confusing. It look's like i've a lot to learn. Is there any recommended plain english reading on this subject.
David
Offline dpg001
#32 Posted : 27 October 2008 21:53:34(UTC)
dpg001
I've eventually bought two Viessmann 5211's that I want to plug into a Marklin Central Station. I'm not quite sure how these cand be connected. This instructions on the Marklin Central Station and Viessmann 5211 are paricularly helpful. Does anyone know how to connect a 5211 to the Marklin Central station to operate a number of switches
Offline frankie
#33 Posted : 28 October 2008 11:17:55(UTC)
frankie
First of all you have to set them up with the dip switches, this gives you a range of four addresses on your 5211, 1-4-&gt;5-8 and so forth, each one of them has to be set differently.
Then you have two sides where red/brown sockets are, actually on one side you have an extra red.
The one where only red/brown is, is the input from your CS on the other side is the output to daisy chain other 5211, if you want this kind of setup.
Remember to bridge the extra red socket with the red on the output side, otherwise you will not have any power to move your points.
This extra red socket is to connect the power from the 5215 module, in that case you don't have to bridge them.
WARNING: don't do any connection, plug or unplug while the power is connected and on, this is the only care you have to have with the 5211.
Alessandro
#34 Posted : 28 October 2008 11:31:46(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by dpg001
<br />I've eventually bought two Viessmann 5211's that I want to plug into a Marklin Central Station. I'm not quite sure how these cand be connected. This instructions on the Marklin Central Station and Viessmann 5211 are paricularly helpful. Does anyone know how to connect a 5211 to the Marklin Central station to operate a number of switches
The instructions are the same as for the 6021. Do not feed the power input to the 5211's from the transformer powering the Central Station. Use a separate transformer, or loop the red wire from the CS going to the red input on the 5211 to the E input (this means the CS is powering the 5211, which will mean less power for locos).
If you use a 2nd transformer, you will also need a common earth (brown) between transformer 2 and the brown output from the Central Station (NOT the transformer powering the CS), and the yellow output from transformer 2 will go to the E input on the 5211 (make sure you remove any loop wires to the red input on the 5211 first).
This page was generated in 1.645 seconds.
