2 Pages12>
Offline LeoArietis
#1 Posted : 07 February 2008 13:54:09(UTC)
LeoArietis
Imho there are quite a few missing C-tracks.
First the very short approx 33-mm straight. This is needed when constructing very tight layouts with complicated turnout-placement and mixing various radi on the curves as well as using the short X-crossing 24649.
Its possible to DIY this pice with a saw, glue and some reinforcement but it should really be aruond.
The long slim curved turnouts and double slips, 24771-24772 and 24724.
I don't understand why Märklin simply can't let the "OLD STUFF COMPABILITY" overboard here. Scrap the old modells or learn that they are old and simply need old trackwork to function (or maybe the standard C-gleis).
The long curved turnouts could be constructed with micro-switches that turn on or off current in the critical spots.
The crossing rails could serve as current-conductor for the pick-up-shoe in the middle after the tounge. This is what all 2-rail-modell-railroaders have to live with in the "electro-frog" turnout-world. It also means that you cant drive into the opposite direction without setting the turnout accordingly. I guess the same concept could go for the slim double slip, you have to set the track-route between in and out and it is then only possible to travel along 2 directions, very much like it is in the real world of double slips.
Short bits of the R3-R4-R5, possibly just the 7.5°(degrees) will be enough since they are so long anyway but 6° will work fine as well since you only break geometry with 1 degree.
The ultrabig radi-curve, something like 2 or 3-4-metre-radius-curve, in bits of 5° or 6°(degrees) or maybe 3° for the really big radi, this in combination with 24224 or 24206/24207 and the 33-mm-track allows for almost any big radius to be constructed, and merely "breaking geometry" just a little. This long curve is simply used when building a curve for looks or when getting a station to curve slightly and not for use in building a full 90-degree.
The "hosen-träger" bit for the slim turnouts, a full long 24° crossing with straigth trackwork on the sides to fit between 4 slim turnouts. This bit has already been DIY by several but it still odd its not around.
Current layout:
The former project:
Offline Caplin
#2 Posted : 07 February 2008 15:37:05(UTC)
Caplin
Agreed. It is very disappointing that development of the c-track system still is at a grinding halt! [:(!]
Benny - Outsider and MFDWPL
Offline Lars Westerlind
#3 Posted : 07 February 2008 17:20:29(UTC)
Lars Westerlind
Amen.
It I would suggest 5 or 10 degrees of R3,R4 and R5 as my first choice.
/Lars
Offline Zora la rousse
#4 Posted : 07 February 2008 18:57:15(UTC)
Zora la rousse
On my wishlist are 360mm C tracks.
I don't like to couple 172mm and 188mm together every time.
As I understood, this was promised by Märklin.
Offline PierreGILLARD
#5 Posted : 07 February 2008 19:26:07(UTC)
PierreGILLARD
I agree with all of the above, of course.
I would add :
- Wye turnouts.
- More R9 rails.
- New R8 series of rail.
By the way, welcome to this forum, Leo !
Pierre.
Offline Armando
#6 Posted : 07 February 2008 19:48:27(UTC)
Armando
Welcome Leo!
I'm so happy to see that you are "wide-minded" about this hobby!
In addition to what Leo and Pierre wrote, these things IMO are badly needed:
1)A wide angle double-switch crossing to match the wide angle turnouts is badly needed. The existing "straight" one is totally useless. How could one possibly build a decent station without this crossing?
2)Flexible C-track, please!
3)Make-up curved track for R-9, so that a half circle or the full circle can be buckled.
4)Highly desirable: R-8 or R-10 and corresponding curved turnouts.
5)Also highly desirable would be a three-way wide angle turnout, with offset track.
Märklin could find inspiration in the PEKO or Roco track.
Leo: I cannot begin to tell you how much I endorse your comments about scrapping the "old stuff compatibility". I would also add: scrap R1! Or just continue designing a "hobby-line" for compatibility with R1.
Armando García
Offline ulf999
#7 Posted : 07 February 2008 20:00:28(UTC)
ulf999
Welcome Leo, I agree with all above!
#8 Posted : 07 February 2008 22:40:19(UTC)
hear hear
Offline biotechee
#9 Posted : 07 February 2008 23:00:10(UTC)
biotechee
My $0.02 (adjusted for USD-Euro conversion: probably closer to $0.005):
I wish they would certainly expand the C-track program. I know that a bunch of people prefer K-track, but people such as I really think the C-track offering is awesome. I say expand it to meet a broader range of hobbyists' needs.
2 comments/questions:
1) How the hell would you make flexible C-track? I see it mentioned all the time here, but for the life of me I can figure out how to accomplish it. Enlighten me.
2) I would gladly endorse an revival / expansion of the hobby line. Not to hijack this thread on C-track with a discussion of locos and rolling stock, but I would enjoy having more lower cost alternatives to fully mfx/fx-compliant locs. A bunch of people here also think the deltas were substandard- I like 'em. They give me digital operation and are relatively cheap. I don't need a lot of sounds / bells / whistles. That's just me.
Offline LeoArietis
#10 Posted : 07 February 2008 23:03:57(UTC)
LeoArietis
Thankyou for your welcomes!
Armando, with double slip I meant the double-swich crossing. I have to learn the english/american vocabulary for all sort of things since my native language is neither english nor german, but I have to admit I know the railroad terms far better in german due to reading Märklin Magazin! Else my english is better than my german.
I absoluotetly agree with you the double-slip should be a top priority, possibly second or first! The reason I put the 33-mm track on top was that it will be very easy to construct the molds and production-line for such an easy item. (However they are not so difficult to DIY like a double-swich-crossing would be)
Is there a dictionary for all the MR-related things around here?
Regarding pushing the parallell-radius to R9 and a lot of other good examples I recomend Henrik Høxbroe's http://hoexbroe.tripod.com/train/id36.html for some nice tips in building with the C-track.
I forgot about the symetric wye, however they are not as common today and often an ordinary 2-way could do the job, but in many track-plans they look very nice.
Current layout:
The former project:
Offline kbvrod
#11 Posted : 08 February 2008 03:44:14(UTC)
kbvrod
[size=1" face="Verdana" id="quote]quote:Originally posted by biotechee
<br />My $0.02 (adjusted for USD-Euro conversion: probably closer to $0.005):
Well my .00000000000000005 sense,er cents,...biggrin
C-track is a marvel,no question,(this coming from a former K-track user) and it must be a success for Mother M,however for the life of me I can not understand the -gaps- in the program that everyone has pointed out!These -gaps- IMHO are not only holding customers back,they are holding Marklin back,...eeeshhh! I am sure that you folks would not only send your Euro's M's way,but the are other who are nodding their heads also,....
Wye's,...rare in Germany and maybe all of Europe(?) good for a point to point branchline,if they did not have an 'Armstrong' TT,..wink
Flex-track,C-style. I have been hinking about that.
Problems: 1) making a foam/synthetic road bed to match the current one(you know folks if you start weathering stuff,it will all look good!LOL!)
2)The rails(all 3) will have to flex one way or another.
3)Tools,you'll need 'em to fit a flex section into a layout,and this goes against the plug-n-play reason behind *almost* what C(or old M) track is all about.
Thank Crom you can either do this with K,or build your own K-track.
Dr Dirt(thinking 2-rail)[:0]
Offline Armando
#12 Posted : 08 February 2008 03:56:27(UTC)
Armando
[size=1" face="Verdana" id="quote]quote:Originally posted by kbvrod
<br />Hi all,
Roco has flex track. Märklin would only need to find a material that mimics the hard foam in colour and grain. Obviously, anyone wishing to use flex track is light years away from "the plug and play" mentality. C Flex track would be a very valuable product for layout modelers.
Armando García
Offline kbvrod
#13 Posted : 08 February 2008 04:18:58(UTC)
kbvrod
[size=1" face="Verdana" id="quote]quote:Originally posted by Armando
<br />Hi all,
True,but that's the rub,Rocoline(with roadbed) is all the same material,whether 'fixed' or flex,so they match.Matching a hard plastic(density) to a foam(less density) is the problem.Color may not be the same.Again weathering may not make all men equal,but it will make Gleis look better Cool
So if C-track modellers want the -gaps- in the program,that should be first and foremost for M to deliver,however if your going to call yourself "The World Leader in Model Railroading" then step up,...
Dr Dirt
Offline JT42CWRDriver
#14 Posted : 08 February 2008 11:39:35(UTC)
JT42CWRDriver
Dr Dirt
Fleishmann do ready ballasted flexible track that has a different material to the other rigid pieces in the range. Appearance and colour matching are spot on. It's now offered in a concrete sleeper version as well.
Märklin really needs to move the C Track range on now.
Peter.
3 Rail/2 Rail Märklin, Fleischmann, Roco. DCC.
Offline LeoArietis
#15 Posted : 08 February 2008 13:14:26(UTC)
LeoArietis
Regarding the C-FLEX-track, it does not really have to flex below say 500 or 600 mm radius since smaller radies may be achieved with the regular program of fixed tracks.
I'm quite convinced there are rubber-type or plastic-foam materials that will do perfect as a roadbed for a C-FLEX-track. Colour wont be a problem, infact rubber will likely be less shiny than the plastic, hence more realistic.
One could considder having short (10mm) straigt joints at the end of the FLEX-track that are made of the plastic to get a perfect fit. Those short straight joints wont be noticed in a long curve of +500 mm radius, at least not for beeing straight, trust me on this. I strongly agree with Armondos point about using flex-track isn't intended so much for the beginner, but rather the more serious railroader. However a sort of quite stiff lightversion of a flexitrack, say 720mm fixed length with fixed ends possible to bend to minimum 600 mm radius will also provide great joy for the less seasoned floor-players. Even more to the serious builder if its possible to remove the end and cut the middle to desired length.
I don't really want to argue about the 360-mm track. I dont see a need for it, unless it will be much cheaper per metre than the 188.3mm-track. For some reason the 236-mm isn't as cheap per mm as the 188 nor the 171!
The wide curved turnouts are also for more seasoned builders as well as the entire slim-line of turnouts. Serious MR will often have rolling stock (coaches, locos) from other manufacturer, and they might not like the 360mm-radius at all so a serious alternative around R4-R5 would be appreciated. R4 is 579 mm and R5 is 643 mm radi and that should be sufficient for almost everyone.
biotechee has a good point about wanting Märklin to expand the HOBBY-line. However electronics is constantly getting cheaper. I'd say there is really just need for one type of decoder, maybe with some added for sounds. Most units could be done integrated and in huge series, hence cutting the price more than if Märklin were to produce a whole range of different decoders. Then the differences might instead be programmed into the decoder instead. Then make sufficient connections if needed out from the cirquitboard to Bells or whistles, horns or headlights or what ever fun you can think of...
Keeping the Hobby-line in fair price helps attract new (young) people to MR.
Current layout:
The former project:
Offline Caboose
#16 Posted : 08 February 2008 22:34:53(UTC)
Caboose
Yes, yes and yes. Totally agree.
I have posted some times before in this matter.
The C-track as a product for teoreticly easy building is good.
But there is a lot of pieces missing.
So in reality it is not easy to build a good looking layout.
You always have to compromise when building with C-track.
You can sit for hours and plan a trackplan, but newer be ready.
The small radius turnouts are to tight to look good, and the wide radius turnouts are to complicated with the small pieces, and they take a hole lot of space.
There shood be turnouts between, maybee with radius 4 or 5.
Wide radius curved turnouts is also urgent, and so is a hole buntch of other pieces.
Sweden & USA
Offline Hemmerich
#17 Posted : 08 February 2008 23:48:54(UTC)
Hemmerich
[size=1" face="Verdana" id="quote]quote:Originally posted by LeoArietis
Hi Leo,
although this decoder stuff is just on the side-line of this thread, I'll give you some response to it: Opposed to the years/time before, Märklin has now managed to reduce its decoder variety to basically three types:
- "simple" pfx decoder
- normal mfx decoder
- mfx sound decoder
In addition, there are now so called "standard" interface pcb's which contain both, all usual wiring connections within the model and the decoder connector, as well as special pcb's for certain dedicated models; may it be due to space/shape or other functional conditions. You can almost choose whatever you think you'll need. wink
PS: I'm looking with a VERY smiling face at this C-track discussion; especially when seeing all those items assumed to be DESPERATELY needed by EVERYONE using this track system. Frankly speaking - if this would REALLY be the case, nothing would stop Märklin to deliver it immediate! biggrin
However, I can see (just) a few of the suggestions be realistic from their overall customer demand scale - and by this business wise suitable and maybe profitable.
Offline Laffe
#18 Posted : 09 February 2008 11:08:49(UTC)
Laffe
Why scrap R1??? I say, add R9 (and R8 and R7) curves for those who has the space, but keep the R1 for the rest of us! Don't use if you don't want to!
My wish list then:
* A Y-switch. If M can make a 3-way they should be able to do a Y.
* More 7.5 and 15 degree curves with large radius. Good for making small variations in straight tracks.
* An R2 curved switch.
* A 90 degree crossing.
/L
/Laffe
Wargamer, Roleplayer, Proud Father and Born-again Model Railroader
Offline Turbo T Terry
#19 Posted : 09 February 2008 16:20:54(UTC)
Turbo T Terry
I think Leo has the right idea on the C flex. I think a workable solution would be to have short (about 25mm) adapter pieces (C on one end, K-style on the other) and then flexible sections of code 90 flex track similar to the old Roco Line flex with sliding outer ballast slopes. As an alternative, you could use a Fleischmann-style flex and then a separate roadbed. The rail would probably need to be nickel silver so that a hobbyist could cut it, but there's no reason this couldn't work. The flex sections could join with each other without adapters to permit smoother curves. I don't see a simple way to have a one-piece flex section because of the need to cut the rail.
I'd also like to see a mid-sized turnout and perhaps an R3 curved turnout, but a flex track would be a great start.
T.
Offline kbvrod
#20 Posted : 10 February 2008 22:39:02(UTC)
kbvrod
[size=1" face="Verdana" id="quote]quote:Originally posted by JT42CWRDriver
Dr Dirt
Cheers,Peter.
Hi Peter!
Yep, I saw this here:
http://www.fleischmann.de/images/products/big/6106.jpg
No reason that Marklin can't do the same in C.
I sit corrected.B)]
Dr Dirt
Offline 60904
#21 Posted : 10 February 2008 23:51:00(UTC)
60904
Wide turnouts are needed for Trix otherwise they can forget about the track system. C track should be completed very soon.
Martin
Offline WelshMatt
#22 Posted : 11 February 2008 00:48:05(UTC)
WelshMatt
The thing that has always puzzled me about C track is why two "standard" straights are needed (24188/24172). Surely it could have been designed to use one standard straight, like M track does?
Matt from Wales.
Offline MärCo
#23 Posted : 11 February 2008 07:28:57(UTC)
MärCo
[size=1" face="Verdana" id="quote]quote:Originally posted by 60904
<br />Wide turnouts are needed for Trix otherwise they can forget about the track system. C track should be completed very soon.
Since I'm running also some old English model train, I know that there are wide turnouts for Trix.
It would be nice if they produce the crossings too.
Absolutly AFB-NOHAB fan ;-)
Offline Schienenbus
#24 Posted : 11 February 2008 08:50:58(UTC)
Schienenbus
Lutz,
I think you are taking it a bit too far here... It cannot be a rule for M to only make things that are DESPERATELY needed by EVERYONE. Then they would need to close down, since nobody really needs any model train... And certainly not everyone...
I believe the requests here are legitimate - once M introduces the R3-5 the desire to have a complete line-up (incl double-switch) naturally comes up, for example to build a complete train station with long turn outs. Or to have fractions of 30 degrees available without cutting, glueing and soldering. In a way one can say 'M started it' - now they should complete it...
Arthur
Offline Schienenbus
#25 Posted : 11 February 2008 08:52:09(UTC)
Schienenbus
<br />The thing that has always puzzled me about C track is why two "standard" straights are needed (24188/24172). Surely it could have been designed to use one standard straight, like M track does?
The short straight (172) is the match to the short end of the normal turnouts. SO there is a purpose.
A.
Offline Caplin
#26 Posted : 11 February 2008 10:07:42(UTC)
Caplin
[size=1" face="Verdana" id="quote]quote:Originally posted by Schienenbus
<br />.... In a way one can say 'M started it' - now they should complete it...
Hi Arthur.
Your entire statement is very valid and well said.
Probably everyone using c-tracks will second that.
#27 Posted : 11 February 2008 10:24:21(UTC)
Zora la rousse
There was a reason for it:
[size=1" face="Verdana" id="quote]quote:Originally posted by Zora la rousse
<br />On my wishlist are 360mm C tracks.
Offline Hemmerich
#28 Posted : 11 February 2008 13:39:45(UTC)
Hemmerich
Lutz,
Hi Arthur,
not really, since I know what the (unchanged) current position of Märklin is regarding this subject; same is the case for K-tracks.
PS: Not saying that I fully agree to everything, but I think I do at least understand it (has much to do with business decisions and profitability). wink
Offline Caplin
#29 Posted : 11 February 2008 14:13:50(UTC)
Caplin
<br />.... I know what the (unchanged) current position of Märklin is regarding this subject; same is the case for K-tracks.
Hi Lutz, So, what is the current position of Märklin on this subject confused
Has Märklin made a statement saying the C-tracks (and K-tracks) will get no further development, or what confused
Please tell us (sorry, if you have pointed it out before, but I can't remember [:I]).
Offline WelshMatt
#30 Posted : 11 February 2008 15:19:51(UTC)
WelshMatt
A.
Yes, I know that - but M track had points made to the same 180mm length as the standard straights. My point is why on earth they didn't do that with C track too.
Matt from Wales.
Offline MärCo
#31 Posted : 11 February 2008 15:43:00(UTC)
MärCo
Simple, you can't make a 8 mm piece in C track. To solve this, they created a 180+8 (=188) mm and a 180-8 (=172) mm C track.
I agree with Zora, they should produce the 360 (2*180) mm C track, certainly when you own a digital layout.
Offline rschaffr
#32 Posted : 11 February 2008 17:44:17(UTC)
rschaffr
You have been a member since:: 03/01/2003(UTC)
Well, other than the line where the track and roadbed join, the 172/188 combination is effective. The electrical characteristics of C track are excellent.
-Ron
Offline Diggum
#33 Posted : 17 February 2008 01:38:00(UTC)
Diggum
I would agree with Zora - but I have an addition:
R1 Turnouts! Anything similar to the venerable 5117's!
AARGH! I have small layout set up which uses R1 exclusively (yeah, Armando, go gripe about it) due to space limitations - its rolls under the kiddo's bed. We got a starter set at Christmas and I'd like to go all C-track for that layout but am finding it very frustrating getting as complex a layout in the same amount of space.
Sorry... just had to vent.
Old Marklin: tough enough to take 3 generations of enthusiastic play.
Offline Legless
#34 Posted : 17 February 2008 13:23:36(UTC)
Legless
Views messages in topic : 809
Love to have a flexi C-track
Legless
Offline Armando
#35 Posted : 17 February 2008 17:54:25(UTC)
Armando
[size=1" face="Verdana" id="quote]quote:Originally posted by Diggum
<br />I would agree with Zora - but I have an addition:
Well, I for one hope that day never comes, i.e., Märklin making more investments towards R1 and neglecting to further develop the wider radii track series. That'll be the day when I'd need to stop buying Märklin stuff altogether because this would be the dawning of an era of involution in the hobby with more and more curtailed and skirted models to satisfy the "streetcar" curve mentality.
Armando García
#36 Posted : 17 February 2008 18:21:51(UTC)
PierreGILLARD
... And to add some oil on the fire : why not a C-Track equivalent of industrial curves such as M # 5120 or K # 2210 ! [}:)]winkbiggrin
Pierre.
Offline weichen-walter
#37 Posted : 18 February 2008 00:29:47(UTC)
weichen-walter
Why not?biggrin UserPostedImage biggrin
Best regards from Lake constanz
Weichen-Walter
http://www.weichen-walter.de
Offline rschaffr
#38 Posted : 18 February 2008 03:01:44(UTC)
rschaffr
Well, I for one hope that day never comes, i.e., M�rklin making more investments towards R1 and neglecting to further develop the wider radii track series. That'll be the day when I'd need to stop buying M�rklin stuff altogether because this would be the dawning of an era of involution in the hobby with more and more curtailed and skirted models to satisfy the "streetcar" curve mentality.
I am really tired of your arrogant and insulting attitude, Armando. I do NOT run "streetcars" . I really have no need for R1 switches, but if that is what it would take to make it so we don't have to listen to you whine anymore, I am all for it. Fortunately, Marklin understands that it's bread and butter is the small layout community, and will continue to support that community for the future. Let's face it, it is ridiculous to argue over 10 to 20 mm on coaches and moving skirts when we gladly accept pukos and oversize flanges. Come on..lighten up and have fun! I am having fun WITH my R1 curves running Era V stock.
-Ron
#39 Posted : 18 February 2008 03:26:47(UTC)
PierreGILLARD
All right ... It seems that this stupid debate is alight again ! [:(!][:(!][:(!][:(!][:(!]
We should be happy that Märklin offers a so wide range of radii both in C-Track and K-Track. We have R1/R2 for those of us with space constraints, we have R4/R5/R9 for those with plenty of space, and we can mix both if we want to manage available space. So why this endless dispute ?
Pierre.
Offline rschaffr
#40 Posted : 18 February 2008 03:32:54(UTC)
rschaffr
I don't mind Armando liking large radius. I think it is great that he has the room for it, but there is no need for him to characterized everyone who doesn't think like he does as wrong and playing with toys. THAT is my problem with him and I just can't continue to keep quiet while he continues to voice his opinion like that. That is the utmost in arrogance. There are many different ways to enjoy this hobby. There is no RIGHT way.
-Ron
#41 Posted : 18 February 2008 03:36:21(UTC)
PierreGILLARD
<br />(...) There are many different ways to enjoy this hobby. There is no RIGHT way.
I definitively agree with this. Cool
Pierre.
#42 Posted : 18 February 2008 04:04:36(UTC)
Bring back M track and add new radius... That plastic rubbish will never last so that you can hand it down to your grandchild's grandchildren...biggrinbiggrinbiggrin[:0][:0][:0]
Offline Armando
#43 Posted : 18 February 2008 05:47:18(UTC)
Armando
Is someone overreacting here?
Armando García
Offline rschaffr
#44 Posted : 18 February 2008 05:53:39(UTC)
rschaffr
I don't think so, Armando. Maybe you don't realize how arrogant you come across. If so, perhaps you need to read your posts with a different mindset. I really don't mind you extolling the virtues of wide radius curves but there is no reason to belittle the rest of us who's space requirements cause us to bend the track a little more in places. I know you are angry because the Gottardo did not live up to your expectations, but that is life. You should have canceled your order as I did. I didn't mind the skirts nor the car length, in fact I feel the shorter cars look better on a typical layout,. I just could not accept the green circuit boards.
-Ron
Offline Rowan
#45 Posted : 18 February 2008 08:26:54(UTC)
Rowan
<br />All right ... It seems that this stupid debate is alight again ! [:(!][:(!][:(!][:(!][:(!]
Pierre.
Offline Armando
#46 Posted : 18 February 2008 20:33:15(UTC)
Armando
Pierre.
Pierre,
Marklin does not yet offer a wide range of radii in C track. The "wide" range is incomplete, which is actually the main topic of this thread. Since the appearance of C track on the market, Marklin has been announcing that the programme is to be "further developed". Well we have been sitting pretty waiting for these missing track, and unfortunately, it seems that we're going to have to wait for a long time. Now, how can you possibly build a decent station without a double-switch wide crossing? The existing "straight" one is totally useless, as it only allows trains to proceed "gayly forward" (pun intended).
Armando García
#47 Posted : 18 February 2008 21:32:40(UTC)
Ron : I am with you on the circuit board. What a terrible way to join coaches.
Getting back to C track a really long straight would suit me and save joining all those small parts when there is room for a long run.
David
#48 Posted : 19 February 2008 00:59:06(UTC)
<br />why not a C-Track equivalent of industrial curves ! [}:)]winkbiggrin
Great. Would get my BB hopping ... biggrin
Offline rschaffr
#49 Posted : 19 February 2008 01:45:08(UTC)
rschaffr
With the exception of flex track and a long crossing, what does C-track lack that is in K track? Seems to me that it is more or less the same. In fact K track lacks R3 altogether but it is available in C. There is not much more M needs to develop on C to make it as flexible (pun intended) as K track.
-Ron
Offline LeoArietis
#50 Posted : 24 February 2008 18:32:59(UTC)
LeoArietis
The 32 or 33 mm straigth track (24032 or 24033) is needed when fitting the short cross 24649 since it is 103 mm long, and the missing 33-mm track will match up that length together with the 71-mm track 24071. This is just one of the many situations where the 32-33 mm track is missing.
As for the wide slim double-switch crossing and the wider curved turnouts I'm quite certain they will be economical to produce, there are many railroaders who want them. If Märklin have issues with profitability, they should start including some of the wider radius in the expansion-sets, why not an expansionset with wide-radius curved turnouts+a few R4 and R5 and the straights?
I think they could include some R3 in the starter-sets to use as transitation-curves (exchange the first (and last) curved pice in a long curve with one track of wider radius). This way I think Märklin would "promote" the use of wider radius to a few more than just more serious MR-s.
Current layout:
The former project:
2 Pages12>
This page was generated in 1.051 seconds.
