Offline epoche_ii
#1 Posted : 15 November 2009 16:16:24(UTC)
epoche_ii
Does anyone know if there is a patch for the Marklin 60521 Gleisplanung 2D/3D version 2.0?
It does not run on Windows 7
Offline Ian555
#2 Posted : 15 November 2009 19:15:44(UTC)
Ian555
Welcome to the forum.
Ian.
#3 Posted : 15 November 2009 19:22:43(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by epoche_ii
<br />It does not run on Windows 7
Have you tried the compatibility settings of Windows 7?
What error msg do you get?
It's (AFAIK) an OEM version of WinTrack - but I'm afraid it's too old and no longer supported.
Offline epoche_ii
#4 Posted : 16 November 2009 17:23:23(UTC)
epoche_ii
[size=1" face="Verdana" id="quote]quote:Originally posted by H0
<font face="Arial]</font id="Arial]Thanks for the welcome to the forum.
The error I get is: "Error Loading X64 Driver. Did you forget to reboot?" I'm not even sure what the compatibility settings of Windows 7 are?
If it is unsupportable, I guess I will have to use my old PC instead of my laptop to work on track plans.
It's an OK program, but with the language barrier, there are still a lot of options I don't know how to use yet. Does anyone know if they ever upgrade it after 2.0?
Is there something newer or better out there.
I took a break from the hobby for about 2 1/2 years now, and am not really up to date except for reading the "Insider" magazine occasionally.
#5 Posted : 16 November 2009 17:36:41(UTC)
Hi and welcome to the forum.
If you look around in this forum you will find all kinds of informations and quickly get updated. I suppose you allready did...
#6 Posted : 16 November 2009 18:10:35(UTC)
<br />The error I get is: "Error Loading X64 Driver. Did you forget to reboot?"
The track planner is a 32-bit Windows application.
It sounds as if you have a 64-bit version of Windows 7.
32-bit programs should run under 64-bit Windows.
I googled for "Error Loading X64 Driver. Did you forget to reboot?" and hat 100,000 hits ...
... but didn't find a solution yet.
The track planner is AFAIK an OEM version of WinTrack.
I guess it matches WinTrack 6 or 7.
You can find Service Packs on the WinTrack site (www.wintrack.de) - but I don't know if they can be used with the Märklin version.
Current version is WinTrack 9.
WinTrack 9 is available in English.
http://wintrack.de/usa.html
(scroll down to find their E-Mail address)
Offline Maxi
#7 Posted : 16 November 2009 19:28:17(UTC)
Maxi
Version 2 of the Marklin Track Plan CD is the equivalent to Version 7 of the WinTrack program but only setup for mainly the Marklin assortment of products.
If you are looking to upgrade to a more current version then I would suggest getting the latest Wintrack program in the lanuguage you are most comfortable with.
Version 9 of Wintrack is in English with the help files also translated into English.
#8 Posted : 16 November 2009 21:13:38(UTC)
Have you tried launching the program with Administrator privileges?
The error message could be related to the copy protection. Admin privileges could be the key.
#9 Posted : 16 November 2009 21:40:39(UTC)
Maybe you should try and install it in the "XP-mode" in Win7?
#10 Posted : 17 November 2009 19:36:35(UTC)
Hi and Welcome to the forum.
This page was generated in 0.535 seconds.
