Offline wa6ld
#1 Posted : 17 March 2009 00:20:00(UTC)
wa6ld
Hello all,
I have three locomotives from older starter sets that have decoders with 701.22B chips on them. What I was wondering about is can you change the Vmax, Acceleration, deceleration settings by writing to the correct CV or must you use the trim pots on the decoder? I know that you must change the address with the dip switches, but these other settings are not clear.
Also, just wondering how may speed steps these decoders handle 14,27 or 28?
Bill
ECOS1 , MS1, 6021
Offline perz
#2 Posted : 17 March 2009 01:09:04(UTC)
perz
The 701.22B chip does not support on-track programming. So the only way to change Vmax and Acc/dec delay is to use the trim pots.
It should be noted that the trim pot settings affect the behaviour in AC mode as well, contrary to how it works with the on-track programmable decoder versions.
The 701.22B supports 27 speed steps, the traditional Märklin way. This means that the decoder goes through odd speed steps with increasing speed, and even speed steps with decreasing speed. There are only 14 different speed steps available in the command set.
Offline wa6ld
#3 Posted : 17 March 2009 01:42:02(UTC)
wa6ld
Thanks Perz,
There was no one place for this information, and it got very confusing trying to piece it together. However the answer was what I thought.
Bill
ECOS1 , MS1, 6021
Offline wa6ld
#4 Posted : 18 March 2009 00:46:55(UTC)
wa6ld
Lutz,
Thanks for that site. It is now one of my bookmarks.
Bill
ECOS1 , MS1, 6021
Offline davemr
#5 Posted : 18 March 2009 13:27:10(UTC)
davemr
Good site. Thank you for link
davemr
This page was generated in 0.322 seconds.
