Offline Zora la rousse
#1 Posted : 11 July 2008 12:07:33(UTC)
Zora la rousse
Due to a derailment yesterday 10 July 2008 at Köln the ICE3 Amsterdam - Frankfurt am Main is temporary out of use. All sets will be investigated first before they return into service.
Die Bahn (with PDF of trains taken out of use and alternative connections):
http://www.bahn.de/blitz/view/index.shtml
See also this newsitems in the German newspapers —>
Der Spiegel:
http://www.spiegel.de/re...ll/0,1518,564922,00.html
Welt Online:
http://www.welt.de/vermi...ptbahnhof_entgleist.html
Offline renevoorburg
#2 Posted : 11 July 2008 13:22:35(UTC)
renevoorburg
This morning at Utrecht station it was announced like "Due to technical problems, there will be no ICE trains to Germany today. We apologize for the inconvenience."
As simple as that, not alternatives given -[:(!]
René - trying to obtain tickets to Zürich that were never delivered [:(]
Offline Weltenbummler
#3 Posted : 11 July 2008 16:57:24(UTC)
Weltenbummler
it's not only AMS - FRA. It's nearly all train relations run by ICE 3 all over Germany.
Lots of lines are cancelled and a few ones are run by replacements trains like IC.
This is a precaution check, as they learned something out of the Eschede desaster in the 90's.
Regard from Karachi
Thomas
Offline spitzenklasse
#4 Posted : 11 July 2008 18:59:07(UTC)
spitzenklasse
I'm sure the delays will be short lived. The DB is well managed. It could have to do with the warmer season affecting wheelset linings? Wasn't the Eschede crash in May of 1988?
Offline Tivvy
#5 Posted : 11 July 2008 19:44:02(UTC)
Tivvy
Is is at the Hauptbahnhoff or at Messe-Deutz?
Ep IV / V Marklin Layout
Under construction.
Offline jonquinn
#6 Posted : 12 July 2008 05:08:47(UTC)
jonquinn
[size=1" face="Verdana" id="quote]quote:Originally posted by spitzenklasse
<br />I'm sure the delays will be short lived. The DB is well managed. It could have to do with the warmer season affecting wheelset linings? Wasn't the Eschede crash in May of 1988?
if this was the very bad high fatality crash you are referring to, it was due to the steel "tire" delaminating from the wheel - unwinding almost as a piece of tape would from its spool. the straightened out steel tire thrust through the floor narrowly missing impaling a seated passenger. I guess at that point the train became unstable at the high speeds it was moving.
http://en.wikipedia.org/...i/Eschede_train_disaster
apparently a bad design.
Offline mmervine
#7 Posted : 12 July 2008 05:36:12(UTC)
mmervine
I wonder if there is any impact on Spain's AVE and China's versions?
Offline Tivvy
#8 Posted : 12 July 2008 05:47:38(UTC)
Tivvy
[size=1" face="Verdana" id="quote]quote:Originally posted by jonquinn
That is essentially what happened, it is also believed to have put the axel out of place. This then caught on the rails at a point which is what finally caused the train to derail.
Under construction.
#9 Posted : 13 July 2008 14:06:24(UTC)
Weltenbummler
[size=1" face="Verdana" id="quote]quote:Originally posted by Tivvy
<br />Is is at the Hauptbahnhoff or at Messe-Deutz?
The train was geting out of the Hauptbahnhof crossing over the bridge to Deutz.
The Eschede desaster happened on 3rd June 1998
Regard from Karachi
Thomas
Offline Tivvy
#10 Posted : 13 July 2008 15:26:50(UTC)
Tivvy
[size=1" face="Verdana" id="quote]quote:Originally posted by Thomas Duengefeld
So the train actually derailed whilst in/on the bridge.confused
Under construction.
#11 Posted : 13 July 2008 16:31:10(UTC)
Weltenbummler
Part of the train was on the Hohenzollernbrücke already when the derailment happened. Last coaches were still at the platform so that all passengers could leave the train safely.
Regard from Karachi
Thomas
#12 Posted : 14 July 2008 10:55:00(UTC)
Zora la rousse
Spotted today some ICE3 running again. According to NS Hispeed sometimes you need to change in Emmerich or Köln.
This page was generated in 0.474 seconds.
