Offline Hobbit
#1 Posted : 08 October 2007 17:10:57(UTC)
Hobbit
Can someone please tell me the part number for the conductive coupler link for the wagons in set 28506. They are shorter than the conductive couplers used in set 28703 and set 2681. I believe they are the same as in the Rheigold set 4228.
There is no place like The Shire...
Offline TTRExpress
#2 Posted : 08 October 2007 19:59:09(UTC)
TTRExpress
There are three part numbers that I am aware of for current conducting close couplings:
7319; 72020 and 72021.
You should check with your Marklin dealer or shoot an E-mail to Maerklin.
Hope this helps (a Scot in Wisconsin)
Offline Hobbit
#3 Posted : 10 October 2007 07:43:15(UTC)
Hobbit
I am just looking for one conductive bar coupler. 7319 has 10 and I don't know if they are long or short. I presume you can get just one as a spare part. Does any one know the number?
#4 Posted : 12 October 2007 17:08:38(UTC)
Probably just as well to buy 10 as the postage I expect would be the same. I would be surprised if you can buy just one coupling.
David
#5 Posted : 12 October 2007 22:28:23(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by Hobbit
<br />Can someone please tell me the part number for the conductive coupler link for the wagons in set 28506. They are shorter than the conductive couplers used in set 28703 and set 2681. I believe they are the same as in the Rheigold set 4228.
The Rheingold uses couplers that are shorter than the 7319 couplers.
[size=1" face="Verdana" id="quote]quote:Originally posted by Jens Peter Christensen
The current conducting coupler for the Rheingold is spare part number 272140.
I don't think the 7319 is the same coupler. My dealer had some (I think they were 7319's) and they were longer.
Jens Peter
I ordered a few 272140 for my Glückauf train set.
Offline Hobbit
#6 Posted : 15 October 2007 07:44:43(UTC)
Hobbit
Thanks. This is the best forum for such help.
I will order a few with my next order to save on postage.
#7 Posted : 15 October 2007 12:18:00(UTC)
I used the RTS CCC for my 4228 Set. Works well.
N
This page was generated in 0.385 seconds.
