Offline Brakepad
#1 Posted : 21 August 2009 18:11:08(UTC)
Brakepad
France, Metropolitan
Recently there have been some threads related to performance, durability and reliability of Märklin models (old/new, one type of motor/another, and so on). Somebody stated that old SFCM/LFCM motors were better than DCMs, and even that "old" DCMs were better than "new" DCMs.
As I own far too many locos, I'm trying to make some kind of inventory in order to write down when they are oiled, price, modifications, and everything that could be of interest.
Today I took all the BR89s out of the place where I store them and checked them. I own four of these and it's funny to see that they show many differences, even if theoretically all of them are the same model. There's also a CM800 around which is mechanically the same as the other analog BR89s. One of the differences is the motor type. Some of them have SFCMs, some others have DCMs. There are some new models with 5-pole DCMs, as far as I know, and perhaps some have a can-motor. I'm not sure about this, but, at least, new BR81s have a can motor instead of the SFCM that used to have. In any case, I can not comment about 5-pole BR89s. I do not own any of these and it's clear that I do not need any other BR89.
OK, let's go ahead. The oldest one is a 89 006, SFCM, analog. It has no serial number. metal hook couplers, metal cylinders. 2 intermediate sprockets. It ran somewhat roughly, but after some oiling it has improved a lot. It's not silent, but I wouldn't say it's noisy. It runs quite smoothly, but not as much as the next one. Got it from eBay, the wear in the pickup shoe shown that it had been used a lot.
The next one is mainly the same as the previous one, but it already has a serial number. It came with a start set I purchased for cheap (29201) because the locomotive was "non working, for parts only". It had not only been used but abused. Wheels were out of place, shafts were crossed and the coil was cut. In the pictures you can notice the "wrong" bolt and also a missing bit in the body. After repairing and oiling it, it turns to be the smoothest and best running BR89 I own:
Next one: a BR89 from 2915 start set. The motor is already a DCM, it has a Delta unit, plastic couplers & cylinders. It keeps the intermediate sprockets. It's clearly noticeable that its running characteristics are worse than the analog locos. It's noisier, also, but it's still OK.
Now the last one: This is the loco which was included in the 29145 set. The painting scheme is slightly different, the road number also. While it keeps the DCM motor, the delta unit and the plastic couplers & cylinders, the intermediate sprockets are not there any more. I removed the bulb because in digital operation it was always ON (even when the loco was stopped) and I don't like that (why did they change this if the previous locomotive had the "good" lighting?). This loco operation is a disaster: it's extremely noisy, running characteristics are very, very poor, to the point that I try to avoid using it. It will move when the regulator it's almost at full, and shows always a jerky running. Oiling it improves nothing (and it's not dirty or mistreated, in fact it's the only "new" BR89 I own, it has been properly run-in, there should be nothing wrong with it).
So far, I do not know if it's the DCM motor or the Delta unit what makes a difference. But even between "old" and "new" DCMs+Delta there are some noticeable differences, regarding performance & noise. Maybe Oscar was right. What do you think?
**UPDATE** I'm adding the CM800 pictures as today I've oiled it and I've seen that, in addition to the external "obvious" differences (lettering -89 028- and two bulbs in CM800 model), the motor is also different. This motor is mainly a primitive SFCM with a different motor cover, which does not include the housing for the oil foam but has a brass bearing:
The last Delta version can not withstand a comparison with the primitive CM800 in terms of constructive quality.
Offline Oscar
#2 Posted : 21 August 2009 22:49:36(UTC)
Oscar
<font face="Verdana]Wonderful photos and a very interesting topic! I think the most difficult issue is to determine when something becomes a characteristic of a particular technology. For example, my 37121 doesn't run very well but does that imply that all present-day DCM's run poorly? I don't know, as I only own one. And while a lot of people here have chimed in and admitted their doubts about the DCM motors, some others have stood up for it and claimed that their DCM's were sturdy, reliable, strong, easy to service and relatively quiet. There's no right and wrong in this matter I guess.
As for digital operation, that's another toughie. I have a BR81 with a Delta decoder. It runs fine in analogue mode, but is unpleasant when I control it with the Mobile Station. Like your BR89, it requires lots of juice before it starts to move, and when it finally moves it immediately goes into high speed mode. None of this happens when I run it in analogue. So is it the motor, or the decoder? I think it is the decoder, not the motor. If that loco can drive smoothly in analogue mode, then the motor is fine.
As for the BR89, it is still in production under catalogue number 30000!! No idea how well it runs, but it is still there after all these years! I own one very old 3000 that must have done a thousand miles. It refuses to run well, but I can't find the cause of that. I've taken it completely apart, cleaned all parts, replaced what was imperfect and carefully put it together again. And though the motor and the gears run freely and are well-lubricated, the loco still runs "laboriously" and requires lots of voltage.
</font id="Verdana]
#3 Posted : 21 August 2009 23:21:35(UTC)
I have a CM800 from around 1958, and a 3000 which is only about a year younger. Both are mechanically identical with SFCM motors.
The CM800 is still analogue and runs very smoothly forwards, but runs more slowly with a high pitched whine when moving backwards. I suspect I've run it much more in one direction and this has worn the gears unevenly. It's still a lovely runner though.
The 3000 was modified with a delta decoder a couple of years ago. It runs just as smoothly as the CM800, except at very low speeds, where it "lunges" slightly as the motor rotates. Considering that it's using it's original AC motor I am satisfied with its performance.
Offline Brakepad
#4 Posted : 22 August 2009 00:45:00(UTC)
Brakepad
Oscar, actually all the information given is based on analog operation, for all locos. The "newest" BR89 runs very poorly in analog mode, and it does not improve much in digital mode. As for other Delta locos I own, I assume that the Delta module does affect also the analog operation, so, if you want to run your locos in analog mode, nothing beats an analog loco, in my opinion.
For DCM vs SFCM, DCM motor is more compact, and probably power is similar, while the current consumption is lower. However, the useful bearing foams that had been fitted on LFCM/SFCM units were discontinued for DCM motors. That means, in practice, that DCM motors need more maintenance than older ones. There are lots of DCM motors in my locos and they all run fine, but I know that if they have been sitting for long, oiling is compulsory, while with SFCM/LFCM chances are that they can be put on the track and run as smoothly as if they had been used yesterday in most cases.
There's also another thing that was already written in another topic regarding DCM motor..."old" ones had a brass bearing in the motor cover, while new ones have not. It's clear that this will affect durability, but in my case it's too early to say exactly how much. I believe that original DCM is a good pancake motor which has been affected over the years by some improvements (5-pole) but also by some cost-reductions (missing bearings) that makes it "worse". However, it would have been much better with the bearing foams, and, further, ball bearings would convert this "old design" pancake motor in the ultimate DC motor.
Offline Brakepad
#5 Posted : 22 August 2009 01:53:00(UTC)
Brakepad
Hi Ray,
I have another CM800 as well, although this one is in need of a complete overhauling (as some others).
I had a loco once which did exactly the same as your CM800. It ran smoother in one sense than in the other. At the end the problem was that, due to the fact that it had been run mostly in one sense, the hard brush got an "angle" wear. In my case, a new brush solved the problem.
Offline jeehring
#6 Posted : 25 August 2009 04:26:58(UTC)
jeehring
Marklin themselves have been publishing some comments : the contact between brushes and collectors are better with DCM than with LFCM Flat commutator....Everybody could make an experience : with a LFCM just give a little bit more pressure on brushes and you should notice a difference...( position & tension of springs must be OK )
About running characteristics : there are several factors, it's not all from the motor....
About the noise of the Loks : if you take any electric motors ( low voltage), including Marklin DCM or LFCM , working freely without any transmission : they are quite silent , that's the nature of electric motors .
If some Loks are noisy or not doesn't come from the motor .
Basically what we are expecting from a motor itself is torque, power, steadiness and ability to be finely regulated...
BTW : don't hesitate to replace brushes, sometimes those brushes can be just cracked it can be almost invisible to the naked eye ( sometimes it's also very visible).
All those Marklin traditionnal motors need maintenance and must be carefully cleaned from times to times ( they have semi open carter , brushes make dust , giving electric arcs ,etc... Bad maintenance = erratic behaviour. One day a dealer shows me a motor with a real poultice of scum inside, dust mixed with oil. It belonged to a child who used to run at maximal speed...
On train model efficiency is another important factor . Motors must be miniaturized as well , to allow accurate model . ( It must be hidden ) . So a manufacturer has to find the best compromise between all these factors ( small, efficient, powerful,...)
Which is also the reason why I find brushless motors like Marklin C-Sinus or SDS are an excellent solution on many points...
Communicating today with terms like "C-sinus" or " SDS" I think Marklin is making a <u>big mistake </u>of communication & marketing .
They'd better use the term " Brushless motor" , because today a lot of people heard about " brushless motors" . " Brushless motors" have excellent reputation and are used in many other fields...Even if they don't know about "brushless motors" people will search and easily find plenty of information about it . Positive information.
While searching about " SDS" or " C-Sinus" they'll find nothing...and it looks mysterious ( only Marklin use these terms )
Introducing these brushless motors 10 years ago , Marklin is perfectly right and technically they have choosen the right way...
On catalogs they should say " SDS brushless motor", or "C-Sinus brushless motor"
Offline TimR
#7 Posted : 25 August 2009 06:02:17(UTC)
TimR
Indonesia
[size=1" face="Verdana" id="quote]quote:Originally posted by jeehring
<br />Communicating today with terms like "C-sinus" or " SDS" I think Marklin is making a <u>big mistake </u>of communication & marketing .
Hi Roland,
I think your post summarize it well in regard to the variety of Marklin motors and what leads to the present.
On the subject of marketing/communication of their Sinus motor - I can't agree more completely. Marklin obviously trying to look distinctive - pointing out that their version of brushless motor is more superior than all other types, but ends up confusing customers.
(well, to be fair, car companies started this "marketing" practice with dozens of different acronym pointing to the same thing - like VTEC, VVTi, VANOS or VSC, VSA, ESC, and so on..)
"SDS" hype in particular is misleading to existing customers as the basic motor in use is still exactly the same as the original Marklin "compact-design (sinus) motor" introduced in 2005 - as it turns out, this only points to updated electronics for models with this motor.
But then models released before 2007 that are still being produced now are still regarded as non-SDS in the database although the newer batches are obviously would had been built with up-to-date electronics. Confused yet?
Now collecting C-Sine models.
