Offline johnhmccauley
#1 Posted : 03 December 2008 04:06:57(UTC)
johnhmccauley
I have been experimenting with RFID to allow me to determine which engine and carriages are passing a certain location.
I have uploaded a video to YouTube if you are interested.
Offline Seetal
#2 Posted : 03 December 2008 04:19:52(UTC)
Seetal
Hi John,
I checked out your other two videos. Excellent. Multiple trains on the same line, lots of interesting movement, synchronized semaphores. Real pleasure to watch.
As for RFID how are you finding it? Do you "tag" the locomotive and the trailing wagon/coach?
#3 Posted : 03 December 2008 04:39:43(UTC)
johnhmccauley
I have found the tag is read most reliably when it is attached to the carriages. The train can go fast and it still detected. The Large Glass Ampoule is the best, but the 18mm button works well enough to be used.
I have found a different RFID reader which is under $20 and small enough to fit under the track. I want to try this one next.
Offline tekin65
#4 Posted : 03 December 2008 09:08:08(UTC)
tekin65
Turkey
John hi,
I firmly believe that RFID is the way to go when it comes to entity recognition. I also believe that the reader prices will go down as the technology becomes widely available.
There are many needs in the industry and small, low power readers are unfortunately not the first on the list. But in any case this is it.
One question: what sort of interface are you using for the readers? Going through computer?
Also, I would like to know more about the new ones you've found ... please keep us informed.
Cem.
Now all eras but no ICE
Offline mascagni
#5 Posted : 03 December 2008 14:39:48(UTC)
mascagni
Hi: The LISSY system the Uhlenbrock has seems similar in function to RFID. However, with the cheap tags, an updated LISSY-like system would be a very good idea using RFID off the shelf. This could them be incorporated into other controllers or to a computer in the standard ways.--MM
Michael Mascagni, Tallahassee
#6 Posted : 03 December 2008 19:35:57(UTC)
Very interesting, Thanks for the link.
Offline pa-pauls
#7 Posted : 03 December 2008 20:09:28(UTC)
pa-pauls
RFID confused
Nice video Smile
Pål Paulsen
Offline rugauger
#8 Posted : 03 December 2008 22:02:53(UTC)
rugauger
[size=1" face="Verdana" id="quote]quote:Originally posted by pa-pauls
<br />RFID confused
See here: http://en.wikipedia.org/wiki/Rfid
Richard
Offline perz
#9 Posted : 04 December 2008 00:07:54(UTC)
perz
Very interesting.
When I was looking at different train identification methods some years ago, my conclusion was that RFID would be the theoretically best method. It has some advantages that are difficult to meet alltogether with other methods:
- Identification, not just detection
- No need for line of sight
- No mechanical contact
- No need for modification of loks
- No need for power supply to the tag, allows detection of unpowered units too
However, at that time all RFID readers I could find were bulky and expensive, and I considered it too big a project to design something better myself. So I developed an IR based system instead.
Still RFID technology is much more expensive than IR technology. The IR system I built costs only 2-3 Euro per detection point, which is very hard to beat with off-the-shelf RFID readers. Some big manufacturer should really make a development effort and create a cost-effective RFID system optimized for model railroads. But it is a big development investment if you want to make it really good.
Another factor that may stop it is that there are patents on this, and the "inventors" want to have their (I assume not so small) share of the possible profit. I write "inventors" with quotation marks because I think there is not so much invention in the idea itself.
When it comes to technology, I think it would be better to use the 13.56 MHz frequency rather than the 125 kHz frequency. According to what I found out it would be easier to build small tags and small readers with that frequency. You would also get a shorter reader range, which would minimize the risk for erroneous readings from e.g. parallel tracks or tracks on different levels. But as a hobbyist you are limited to the equipment you can buy for reasonable money, and there I think the 125 kHz systems still dominate.
#10 Posted : 04 December 2008 01:46:56(UTC)
johnhmccauley
At present I am using a computer, long term I plan to use a PIC controller.
The other RFID reader I am looking at:-
http://www.priority1desi...html#mrfid_reader_writer
This page was generated in 1.040 seconds.
