#1 Posted : 28 August 2008 23:14:59(UTC)
Rear detail of the CS2, Look at the screwlegs.wink
#2 Posted : 28 August 2008 23:20:34(UTC)
Steven,
I see the screw as being for fine adjustments. I see the pressure taps on the inside leg support as being used for quick course positioning. If so - nice.
Sound! At last some ergonomic feedback (beep) instead of the absence of tactile sensing
The 8pin connector (usually associated with connection to 24088 (ugly box) has SX over it.
Appear to have returned to original (legacy) booster connection
I guess that leave "Aux" as the connector to a 2nd CS2 (as per schematic via cable 60123.
#3 Posted : 29 August 2008 00:26:59(UTC)
And the ethernet port is around the right way......winkwink
#4 Posted : 29 August 2008 00:35:56(UTC)
<br />And the ethernet port is around the right way......winkwink
Yes and another plugs at front for mobile stations, I think so.
Offline mmervine
#5 Posted : 29 August 2008 00:54:18(UTC)
mmervine
Thanks for posting the picture! It looks like they have done a nice job with the design.
#6 Posted : 29 August 2008 01:24:48(UTC)
Godd picture Stephen. Your the man.
David
#7 Posted : 29 August 2008 04:48:10(UTC)
That guess is slightly missing the target. Cool
PS: Stephan posted the link containing the original picture already two days ago here: https://www.marklin-users.net/fo...ult.aspx?g=posts&t=10636 wink
Where does the Aux Connect to Lutz?
#8 Posted : 30 August 2008 00:52:08(UTC)
gothcha Lutz, you're far too predictable
#9 Posted : 30 August 2008 01:12:54(UTC)
biggrin
#10 Posted : 30 August 2008 01:18:39(UTC)
But he has not answered the question. [xx(][xx(][xx(]
NN
Offline efel
#11 Posted : 30 August 2008 01:27:24(UTC)
efel
Quite interesting Steven.
#12 Posted : 30 August 2008 04:55:59(UTC)
now that one can connect a mouse to the controller, perhaps more people will understand that this box is a computer, thus putting an end to statements that they don't want to use a computer but do run digital... and at last, compare the screen and user interface to what you can get with more 'traditional' looking computers... :-)
#13 Posted : 30 August 2008 09:34:49(UTC)
I know what Sx stands for...!
It means:Standing extreme... wink
HA HA HA...
Goofy biggrin
#14 Posted : 31 August 2008 13:11:09(UTC)
Slightly technical question, maybe.
Do you still need an "ugly box" track section for connection of the CS2?
Or do the two O/B outlets do the job, and perhaps in parallel?
#15 Posted : 31 August 2008 14:15:50(UTC)
Kimball, it looks like the track outputs are the same as the CS1. In that case, you can use either the ugly box, or the 2 wire track output nearest the power socket (with adapter).
You can't use both 'O B' outputs at the same time, one is for a programming track (marked 'PROG'), the other as I say is for the normal 2 wire track output.
This page was generated in 0.519 seconds.
