#1 Posted : 31 January 2010 12:51:58(UTC)
While my layout was powered by transformers, I noticed that my ICE 3 (Märklin 37781) slowed down when I switched the interior lights on.
With CS1 Reloaded (powered by a stabilized power supply) I no longer noticed a slowdown.
Please note: it's a feature of the 6090x decoder that it adjusts its speed proportionally to the track voltage. This is a feature that can be used to make slow speed sections simply by reducing booster voltage at those tracks.
However this feature is no longer supported with the new programmable decoders.
I adjusted the CS1 power supply so that CS1 indicates 19 volts on the track.
Test configuration: I had two trains with interior lights on the track: ICE 3 (37781 plus 3 extension cars, 8 cars total) and train set 25611.
I used the CS1 to measure the track voltage.
I used my laptop (and the freeware PaTacho) to measure the speed of the ICE 3.
I used the power supply that came with CS1 Reloaded and a M* transformer 60052 (60 VA).
Test 1 - standing trains:
Power supply: 19 V with lights off, 18.7 V with ICE lights on, 18.7 V with all lights on.
Transformer: 21.7 V with lights off, 19.2 V with ICE lights on, 18.7 V with all lights on.
Test 2 - ICE running:
Power supply: 231 km/h, 18.9 V without lights, 218 km/h, 18.7 V with lights
Transformer: 257 km/h, 20.2 V without lights, 219 km/h, 18.5 V with lights
Test 3 - both trains running with full light:
Power supply: 218 km/h, 18.6 V
Transformer: 211 km/h, 17.9 V
Conclusion:
Using the power supply, the ICE slows down a little bit (less than 6 %) - I didn't notice the slowdown without speedometer.
With a transformer I noticed the slowdown (almost 18 %).
I didn't pay intention to the intensity of lights.
Booster output with both trains running was about 1.7 A.
CS1 2.0.x has a booster limit of 2.8 A. I wonder how far the track voltage will drop if one takes a transformer to that limit.
Rumours say that you can get a combined booster output of 3.4 A from a CS2. I'd like to see the track voltage at that booster load, too.
BTW: I use a switch-mode power supply for my MS1, too. Haven't made any tests yet, but it sure saves a lot weight when taking a layout to meetings.
Offline klarinettmeister
#2 Posted : 31 January 2010 13:49:23(UTC)
klarinettmeister
Interesting Tom!
This will propably be the reason I'll upgrade my CS.
BTW... did you just use 37781 (5 cars)? It would be intersting to see what happens to a complete ICE-train with 8 cars. I can´t use my complete 37780 with my 5 extra cars very good.It looks like it drops 30% of it´s topspeed when turning on the lights with the CS (not reloaded).
If you also have CZ running and a few lighted cars you´ll exceed 2,8 A and the CS cuts the power.
Using CS and a 52 VA transformer 6002.
/David
#3 Posted : 31 January 2010 15:41:30(UTC)
Hi, David,
I should have mentioned that my ICE 3 has 8 cars.
#4 Posted : 01 February 2010 01:05:36(UTC)
klarinettmeister
H0 wrote:
Hi, David,
Thanks Tom! Then I know what I´m gonna do with my CS1 BigGrin
Offline GSRR
#5 Posted : 15 March 2011 01:01:27(UTC)
GSRR
Tom,
What is the actual stabilized power supply you use with your CS1? Marklin, ESU?
r/Thomas
#6 Posted : 15 March 2011 10:17:08(UTC)
Hi, Thomas,
I use the power supply that came with CS1 reloaded: 90 VA, wide range input voltage, adjustable output voltage, ...
Except for the output voltage (and input voltage) it shouldn't make a difference which switching mode power supply you use.
Offline GSRR
#7 Posted : 22 March 2011 18:28:55(UTC)
GSRR
Hi, Thomas,
Thanks Tom.
I went back to the manuals for the BW ECoS and the color ECoS, specifically page 10 and 11.
I have the 50000 BW and the manual states you can swap the fixed 18V version for a 15V version for N scale, and I see with your 50200 color model the supply was changed with a variable setting on the power supply itself.
Curiously I have a power supply with a small pinhole on the side of the power supply. With this you can choose either 18V or 15V. My ECoS indicates 17V when turned on.
r/Thomas
#8 Posted : 22 March 2011 18:44:20(UTC)
This new kind form of power supply makes even more safety,by feeding power to digital system so tracks don´t need to have suppressor tions.
With AC trafo it happens sometimes you will get some suppressor tions,which disturb trains on the tracks.
This page was generated in 0.462 seconds.
