Offline mountainroads
#1 Posted : 02 May 2024 05:55:51(UTC)
mountainroads
I'll readily admit this is a strange one. Here are the facts:
1) This loco has been a reliable workhorse until relatively recently. Struggles to make it up one section of track, to the point of stalling, that none of my other mainline locos have problems tackling. Therefore, doesn't seem to be a voltage drop issue with that section of track.
2) Gave it a maintenance service which included lubrication, cleaning the rotor, and replacing the brushes. No improvement.
3) Sent it to a well-known reputable service center for a checkup. They found no issues, gave it a clean bill of health, and sent it back. Still has the same problem.
4) Same behavior whether pulling a load of cars or by itself. My two shunting locos pull the same load of cars up the same hill, with the same throttle setting, no problem.
5) I wondered if one of the pickup shoes wasn't working, so put it on its back on my test bench and used my 6501 test bench trafo to independently apply power to each shoe. Loc seems to run really strong with either shoe connected. Reversing is not an issue.
6) Goes like the proverbial "scalded ape" on the downhill section without any changes to throttle. In other words, will barely pull the hill if given enough throttle and then dramatically picks up speed on the downhill.
7) Telex coupling and reversal unit, if it matters.
Here is where it gets *really* weird:
1) Behavior doesn't seem to manifest itself if I turn the loco around so that it goes up what is normally the downhill section of that loop and then down the normally uphill section.
2) Behavior is not nearly as bad if I put the loco in reverse and then go backwards up the hill section that is problematic.
It behaves as if the motor has greatly reduced torque going in the forward direction, but only on the one section of track Any troubleshooting ideas or suggestions greatly appreciated. I'll try to post a YouTube video to demonstrate what I'm talking about. TIA.
- MR
Edited by user 02 May 2024 18:12:47(UTC)  | Reason: Not specified
thanks 1 user liked this useful post by mountainroads
#2 Posted : 02 May 2024 11:13:09(UTC)
I've experienced similar trouble once with my 8356 hamo croc. I bought it from my dealer in 1991 used. It belonged to a doctor and was on consignment. It ran but eventually stalled and would barely move. My dealer checked the brushes, and said it seemed fine until he tried to run it more than a couple of minutes. He either had to thoroughly clean or replace the commutator. Check yours for wear. Also the small capacitors if equiped. If they have bulges or look melted.
Offline mvd71
#3 Posted : 02 May 2024 11:52:23(UTC)
This may sound crazy, but try running the loco in reverse pulling the same train, and see if it stalls or slows at the same places on your layout.
Cheers…..
#4 Posted : 02 May 2024 15:41:02(UTC)
Hi Paul
My loco is a G800 (the ancestor of the 3047).
The motor is very powerful but you need to check these:
- the commutator surface. The best is to install the rotor on a Dremel-like hand drill (Mine is Proxxon) at LOW SPEED, use a thin abrasive paper (Grade 1000 or finer) to gently rub on the commutator. When finished, don't forget to clean the gap between copper segment using a tooth pick
- the brushes must be new (your case) and the brush guides must be clean (use a cotton swab with some cotton removed)
- the brushes spring must push fairly on them (compare with other Märklin locos with same LFCM motor
- the rotor needs inspection for possible burnt winding and possible mis-aligment of the commutator
- the mechanism must be clean and lightly lubricated (oil everywhere except on the "H"- shaped part linking the rotation of the 2 power trains that must receive a bit of grease
Note: a defective direction & Telex relay may cause a voltage drop to the motor (through the induction windings).
Your Telex relay must look like this
Depending on the loco orientation, the pulling power vastly change because the wheel tires are on the rear axle of each power train. So when the tender is rear, then, maximum pulling power
#5 Posted : 02 May 2024 18:32:32(UTC)
mountainroads
Thanks for the great ideas, gents. I will check all of them.
To add some detail that I omitted from my original post:
I did clean the commutator with my usual method - the rubber eraser end of a pencil and rubbing alcohol. I will give fine-grained sandpaper a try, as suggested. Good point about cleaning the gaps.
I did consider trying to pull the load going backwards, but I wasn't sure how well that would work since there's no proper coupling on the front of the loc. Especially, since there's a curve involved. I'll give that a shot and report back.
Excellent idea about the reversing unit contacts. The service center brought up a possibly bad reversing unit when I told them I still had the same problem. Will definitely take another look at that.
I also wondered about a shorted winding in the rotor or armature, but somewhat discounted that idea because I didn't think that would be direction dependent.
Thanks again. Keep the ideas coming!!
- MR
Offline mvd71
#6 Posted : 02 May 2024 21:09:36(UTC)
The running backwards is a good method to check for wear on the gears, as most people run steam locos forwards 95% of the time. If it is noticeably better, then a detailed inspection of the gears may be worthwhile.
#7 Posted : 03 May 2024 13:24:37(UTC)
I would think seriously about the possibility of the commutator turning on the armature shaft. This could certainly affect the forward/reverse running characteristics.
I don't know off hand how the commutator should be oriented with the armature magnet poles, but comparing it with another armature would help.
If the commutator has moved on the armature axle this could also break a wire on one of the armature windings which would also affect pulling power.
#8 Posted : 05 May 2024 05:28:26(UTC)
mountainroads
Thanks mvd71 and KiwiAlan, as well as others previously. All good ideas/suggestions. Been a little tied up with other projects and hobbies this past week. Will check all of the provided things to look for and report back.
- MR
#9 Posted : 19 May 2024 19:42:19(UTC)
mountainroads
Finally got around to spending some time on this. I took mvd71's suggestion first (since it was the easiest test) and tried pulling the load over the problematic section of uphill track, in reverse. The difference was obvious and dramatic. 3047 pulled strongly and smoothly, even with further reduced throttle. No greatly increased speed on the subsequent downhill section, either.
Bundling responses to other suggestions/comments, below:
1) @Marklinist5999: Previously cleaned the commutator with a rubber pencil eraser as is my practice when servicing all of my locos and/or replacing the brushes. Bright, shiny, and no excessive wear. The capacitors looked fine, but that was a purely visual inspection.
2) @JohnjeanB: All good ideas. I'll take the time to disassemble the motor again to thoroughly check, clean, and adjust, per your suggestions. The tires are new, so I don't think there's a difference in traction and it's definitely a matter of the motor stalling out instead of wheel slippage.
3) @mvd71: I understand what you're saying, but do you really think gear wear could be an issue? Marklin used high-quality steel and I can't imagine there's that much load, but certainly worth looking at. I'll check again while the motor is apart, but didn't notice any visual signs of wear and I also used my finger to drive the wheels in both directions to distribute the oil. I don't remember any difference in effort required depending on direction. Also, loco was recently serviced by authorized service center and all gears and lubrication points received fresh oil. I would think they would inspect and say something if noticeable. Then loco was lubed again by me after returned, as well.
4) @kiwiAllen: I'll take another look at the commutator and compare with other known good spares, but don't remember any obvious misalignment signs. Unfortunately, my spares are for smaller locos, so no swap is possible.
Question for all: Are there any good spots to do a resistance (ohm) check?
Giving my running-in-reverse test results, my primary suspicion now rests on the Telex reversing unit. Specifically the contact(s) in play when in the running forward configuration. (Thanks JohnjeanB for the picture.) Is there a different contact combination for running a Telex loco in either direction depending on if the uncoupler is engaged or not?? If so, I might try running forward with uncoupler engaged, although that could be a challenge when trying to pull a load of cars LOL .
Regards and thanks again,
- MR
Offline Paul59
#10 Posted : 19 May 2024 20:24:24(UTC)
Paul59
MR - sounds like you're getting somewhere.
Don't forget there are two forward positions for the reverser (or four if you're including the position with the coupling raised)...
1 - Forward
2 - Forward with coupling raised
3 - Reverse
4 - Reverse with coupling raised
5 - Forward
6 - Forward with coupling raised
7 - Reverse
8 - Reverse with coupling raised
People often forget that there are eight teeth on the drum 'ratchet' so each position is duplicated. Always worth checking all of them.
As regards resistance checking...
I always do this as a matter of course whenever I have an armature removed since it saves the wasted time reassembling a loco with a faulty armature only to have to take it out again.
1. Check the resistance between pairs of commutator segments - i.e. 1 & 2, 2 & 3 and 3 & 1.
The resistance varies between armatures but will likely be around 7 ohms or so. What is important here is that all three readings are the same (or virtually the same). If they are significantly different then one or more coils is breaking down or there is a detached winding somewhere.
2. After that measure between each commutator segment and ground - ground in this case meaning the armature spindle.
There should be infinate resistance for all three segments. If you get a reading it means that one or more coils are shorting to ground somewhere.
It is quite common (at least with my locos) for them to run a little bit quicker in one direction than the other but it shouldn't be excessively so.
Good luck.
Marklin HO using M track. Now reverted to analogue as I find it has more character - and I understand it!
#11 Posted : 19 May 2024 20:31:35(UTC)
mountainroads
Thank you Paul59. Very helpful. Will test your suggestions and report back.
Does anyone know if there is a resistance value for the (3 pole motor) induction magnet? TIA
- MR
Edited by user 20 May 2024 03:15:42(UTC)  | Reason: Not specified
Offline mvd71
#12 Posted : 20 May 2024 06:45:28(UTC)
The issue of increased resistance causing less power through the motor may well be worth exploring, however I would lean towards worn gears.
Your loco has probably spent 95% of its life running forward, and while the old Märklin locos were great quality, robust, and reliable. The reality is the gears do wear out. Particularly the smaller ones, as they work harder than the larger ones.
I don’t doubt that you have recently had it serviced, but the wear and tear that causes these issues is often not perceptible to the naked eye, unless you have 20/20 eyesight and know what to look for. If you look under magnification and look towards the base of the teeth you may be able to see a wear step, or feel it with a fine dentists tool. Once they get wear like this, they really need replacing. And this wear often occurs on the armature too.
If I was in your position with a loco like that, I would look at buying a complete set of replacement gears, and try to find a new armature that someone has surplus follow a digital conversion. Then replace them all, clean, and lube. That should get you back on track.
Cheers….
Offline mvd71
#13 Posted : 20 May 2024 06:48:43(UTC)
Perhaps look at Ritter restorations to see if you can get a complete kit of parts
https://ritter-restaurat...ines-series-3000/3047-en
#14 Posted : 20 May 2024 13:57:47(UTC)
Gear wear can certainly be an issue. Check the whole gear train for the shape of the individual teeth. They should have nicely 'rounded' (not quite the correct term) tips. But I have seen many a Marklin gear where the tips are like a punk haircut, all spiky. This could induce enough slop in the gear train that the connecting rods jam or have high resistance to movement when driven forwards (which is the most common direction, so worst wear) but be fine when driven backwards. You probably wouldn't notice this using your thumb on the wheels.
The only solution is a complete new gear train, including the wheels that have gears on them, i'm afraid. But the parts should be readily available still.
This page was generated in 1.545 seconds.
