Offline midwestbls
#1 Posted : 15 December 2017 15:55:45(UTC)
midwestbls
You have been a member since:: 04/06/2012(UTC)
Does anyone know if there are kits or plaster casts in HO scale for the Simplon Tunnel portals??? I'm looking specifically for the north portal, but a kit with both N. & S. is fine. I can only find the Pola/Faller N-scale version ... why not an HO?! Maybe there are some local, speciality kit makers in Europe/Switzerland that I just can't find ... Thanks in advance for any ideas!
#2 Posted : 17 December 2017 09:10:49(UTC)
I coulden't find any and the only ones mentioned are N gauge (Faller & Pola) and out of stock
Offline Unholz
#3 Posted : 17 December 2017 13:38:06(UTC)
Unholz
Same result here.
#4 Posted : 17 December 2017 17:46:49(UTC)
I would think that this would be a reasonable project for somebody who had a 3D printer.
#5 Posted : 19 December 2017 07:19:52(UTC)
I found some tunnel portals, including the BLS Goppenstein (Loetschberg South Portal), but not a HO model of the Simplon Portal in Brig:
http://www.mbapiro.ch/pr...rp_id=2&content_id=6
Maybe this shop has a suggestion on where you might be able to locate the model you are searching for (if it exists).
#6 Posted : 19 December 2017 15:30:25(UTC)
www.steinbogenviadukte.de under tunnel portals. Looks like he does at least one of them in N, I'm sure would be no problem for him to do in HO
He does stellar work, and even if not shown I'm sure he can build it. I've had him do a custom curved viaduct for me and the results were breathtaking, with pricing in my opinion being downright economical for the amount of work involved in building in.
Offline midwestbls
#7 Posted : 19 December 2017 21:37:23(UTC)
midwestbls
Thanks for the ideas and website leads!
Offline michael.holm
#8 Posted : 05 May 2024 15:43:27(UTC)
michael.holm
Did you find a solution that worked for yoU ? I am about to get into the same project now
This page was generated in 0.711 seconds.
