4 Pages<1234>
huttel Offline
#51 Posted : 07 March 2006 10:04:42(UTC)
huttel
Hi Richard, Ira and Timaximus
Very valid input and I agree that it would be a much better solution, so I will try to move the station to the sugested position and also work on access to the station. Would be better if the branch line exits from the main station I think.
I will be back! wink
Rgds,
Thomas
Carpe Diem!
Märklin HO | Insider | C-Track | Digital | Era III+IV | PC Control with CS2 (60215), Intellibox & Win-Digipet | http://huttel.dk/marklin
hxmiesa Offline
#52 Posted : 07 March 2006 12:51:06(UTC)
I see that you have changed the layout a little, where you have the crane. I liked it better before ;-)
Anyway, the MOST important change, should be to install two points in the northern-most part of the main line, allowing east-bound trains access to the BW area.
huttel Offline
#53 Posted : 07 March 2006 21:56:54(UTC)
huttel
Hi Guys
Moved the branch station. Still have problems with letting it exit from the main station because of the "right handside only" driving. Will have to think a bit more about that. Want to include bridges in the NE and SE corners - think that will look very good. Also included the 2 switches as suggested by Henrik. (Not visible..!)
//Thomas Smile
Carpe Diem!
HueyCE Offline
#54 Posted : 08 March 2006 00:48:47(UTC)
HueyCE
I think the placement of the crane is fine, if you provide a reason for it to be there, such as a small industry or a goods shed. The layout still looks very nice.
Ira
Building German Era I-II layout(Mk IIIc).
huttel Offline
#55 Posted : 12 March 2006 21:32:37(UTC)
huttel
Hi all
Think I am close to be finished with the actual layout and as the setup is to be controlled by an IB and WinDigiPet I decided to give the WinDigiPet trackplan a shot. Might have to look into the setup of the turntable but this is the result so far.
//Thomas
Carpe Diem!
Timaximus Offline
#56 Posted : 12 March 2006 21:43:18(UTC)
Timaximus
Hello Win-Digipet colleague.
That WDP track plan looks great!
Timaximus
huttel Offline
#57 Posted : 12 March 2006 22:05:27(UTC)
huttel
Hi Timaximus
Always good to hear from you. I don't have much experience with designing trackplans in WDP. Is it the way you would have done it or am I overlooking some good points here?
//Thomas
Btw I recon 2 boosters and the IB should be enough for power - agree?
Carpe Diem!
steventrain Offline
#58 Posted : 12 March 2006 22:18:06(UTC)
Two boosters would be ok.
How many locos do it run?
Large Marklinist layout with C-tracks/Central station 2/Mobile station 2/Boosters 60174s/Marklin collector since 1990s/Collector Marklin from the 1950s/Favorites Steam class BR01/BR03/BR05/BR50/Insider Club membership.
huttel Offline
#59 Posted : 12 March 2006 22:22:30(UTC)
huttel
Hi Steven
I expect to have between 8 and 12 trains at the layout in total with 8 running. Most of the trains will be with 4-6 passenger wagons – all with lights.
//Thomas
Carpe Diem!
steventrain Offline
#60 Posted : 12 March 2006 22:40:05(UTC)
Hi Thomas,
Ok you can use IB and two boosters (just like 6021 and two 6017).
Look forward to start process on layout soon.
Timaximus Offline
#61 Posted : 12 March 2006 23:34:33(UTC)
Timaximus
Hello Thomas,
With 8 running trains and 4 waiting trains and a lot of coaches plus light (2 lamps per coach) a correct sectioning and train sequence should be considered.
Personally I would give the main station area an own boosters.
And two boosters for the other stations plus main tracks.
And the IB just for the decoders and the turntable area.
But you can start with your 2 boosters and the build in booster of the IB.
If you see problems with the power you can always place an extra booster to your layout.
Timaximus
huttel Offline
#62 Posted : 20 March 2006 15:39:15(UTC)
huttel
Hi all
A quick question. In my layout I am limiting the traffic to "right-handside" only. I therefore have several switches which will always and only receive traffic. To save the expense of decoders and "Elektrischer Weichenantrieb" for those switches I was wondering if anybody have experience with de-railing etc. of trains where the receiving switches are not in the correct position. I am using C-track.
I hope the problem formulation makes sense to others than myself...Smile
Rgds,
Thomas
Carpe Diem!
jerdenberg Offline
#63 Posted : 20 March 2006 16:36:00(UTC)
jerdenberg
Hi Thomas,
The only problem I have had with wheels not succeeding in "opening" a "closed" turn-out was with extremely light cars with RP25 wheels; "normal" cars do not cause problems here.
Jeroen
Timaximus Offline
#64 Posted : 20 March 2006 17:39:11(UTC)
Timaximus
I use drive open turn-outs (C-rail) too.
Also for saving activators and decoders.
Until now I never had any problems with it.
Timaximus
huttel Offline
#65 Posted : 22 March 2006 11:30:41(UTC)
huttel
Thank you guys for your fast replies. I will go for open turn-outs too (save the money I can Cool)
//Thomas
Carpe Diem!
huttel Offline
#66 Posted : 04 April 2006 23:10:15(UTC)
huttel
Construction time again. Train room to be... [:p]
//Thomas
Carpe Diem!
HueyCE Offline
#67 Posted : 05 April 2006 00:57:46(UTC)
HueyCE
Definate potential.
Ira
huttel Offline
#68 Posted : 20 May 2006 10:08:03(UTC)
huttel
Hi all
Does anyone know the minimum recommended distance from C-track to a wall both on turns and straight lines?
//Thomas
Carpe Diem!
HueyCE Offline
#69 Posted : 22 May 2006 01:30:52(UTC)
HueyCE
I don't know what the recommendation is, but from personnal experience I would say 3 cm.
Ira
nevw Offline
#70 Posted : 22 May 2006 08:21:03(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by HueyCE
<br />I don't know what the recommendation is, but from personnal experience I would say 3 cm.
Ira
From a Novice Experience i would make it 5 CM. the extra 2 Cm makes a difference. More room to cater for falling over Cars.
Nevwink
wearing the Pink Pinny, which is hard to see and now an waiting for a new shiny tin Hip
Junior member of the Banana Club, a reformist and an old Goat with a Bad memory
huttel Offline
#71 Posted : 13 July 2006 23:47:44(UTC)
huttel
Hi all
Finally the room for my new layout is finished. New floor (pretty hard so no falling trains Smile), new radiator etc. Only need to get some new lamps up...and thus construction has finally begun.
At the picture you can see what will eventually become my shadow station (level -1) and at the wall initial mountings for level 0.
Still a long way to go though...but that's the fun of it...
//Thomas
Carpe Diem!
viragoLDR Offline
#72 Posted : 14 July 2006 01:06:00(UTC)
viragoLDR
Looks a lot less like a shabby, murky cell now, it actually looks like quite a comfortable room =)
- Martijn
HueyCE Offline
#73 Posted : 14 July 2006 01:19:42(UTC)
HueyCE
It's always fun to get started on the layout. Keep us posted. Nice upgrades to the room.
Ira
PierreGILLARD Offline
#74 Posted : 14 July 2006 01:23:05(UTC)
PierreGILLARD
It seems to be a very clean room now.
Have fun now with the construction of your layout !
Pierre.
steventrain Offline
#75 Posted : 14 July 2006 21:51:12(UTC)
Good luck to start construction of your layout.
huttel Offline
#76 Posted : 21 July 2006 01:18:43(UTC)
huttel
Hi all
Got a little further with the construction of the table as you can see. The table for the shadow station is basically finished wink
//Thomas
Carpe Diem!
steventrain Offline
#77 Posted : 21 July 2006 07:42:20(UTC)
Excellent keep the good work.Smile
huttel Offline
#78 Posted : 20 August 2006 23:29:44(UTC)
huttel
Hi all
A quick update as work is progressing (slowly) but anyway here are some more pictures...
The pillars of the bridge are only temporary...
The shadow station is finished and I managed to get the loop in place and got some trains up and running....ahhh....how I have missed that Smile
//Thomas
Carpe Diem!
#79 Posted : 21 August 2006 00:31:22(UTC)
PierreGILLARD
It will become a great layout for sure wink.
Pierre.
HueyCE Offline
#80 Posted : 22 August 2006 01:12:36(UTC)
HueyCE
Yet another layout that is coming along nicely.
Ira
huttel Offline
#81 Posted : 26 August 2006 15:58:59(UTC)
huttel
Hi all
Basically finished with fitting the plates for the 4 levels. Now need to paint, build ramps, lay tracks, build control table, doors for the cabinets etc...and then comes all the wiring and programming...biggrin
...and did I forget to mention that my wife is suposed to give birth in a week or two...
//Thomas
Carpe Diem!
Timaximus Offline
#82 Posted : 26 August 2006 18:52:02(UTC)
Timaximus
Hi Thomas,
Your layout is growing nicely.
Now we can see the real 3D idea of your track plan.
It looks very good.
Timaximus
HueyCE Offline
#83 Posted : 27 August 2006 01:37:55(UTC)
HueyCE
How have you managed to get so much done with a little one on the way? Congradulations on the pending birth.
Ira
steventrain Offline
#84 Posted : 27 August 2006 10:33:02(UTC)
Excellent process,keep the good work.
huttel Offline
#85 Posted : 23 September 2006 00:59:55(UTC)
huttel
Hi all
Had a few "family free" days and were able to get some real progress with the layout. Have more or less finished the table (needs to fit cabinet doors) and started on laying out tracks, installing RM modules, cables and WDP programming.
Decided to use 3 70VA transformers for the trains and keep the IB for feeding decoders and signals. Worked out fine and I don't seem to have power problems
Finished most of the programming this evening and managed to have 12 trains running at the same time with limited problems (only two major incidents). Nice Smile
Inspired by the oringinal Märklin layout I went out and got some trees to add some color to a rather white layout.
Screenshot from the WDP PC control
...and the everlasting spagetti
And more important...We had a beautiful daughter 2 weeks ago. 3.450G and 51CM's of pure hapiness [:I]
La vie est belle!
//Thomas
Carpe Diem!
nevw Offline
#86 Posted : 23 September 2006 01:09:39(UTC)
Congratulations.
Both "projects" Look perfect. Now you have to buy a Pink Train for her. Smilewink ]
(for daughter) [:X][:X]
Nev
steventrain Offline
#87 Posted : 23 September 2006 08:36:47(UTC)
Great layout (nearly finish?).
Lovely daughter[:X]
David Dewar Offline
#88 Posted : 23 September 2006 10:21:21(UTC)
Congratulations....beautiful girl.
Have you ordered the M start set for her Christmas !!
David
hxmiesa Offline
#89 Posted : 23 September 2006 11:34:40(UTC)
Congratulations Thomas!!!
Zora la rousse Offline
#90 Posted : 23 September 2006 13:13:44(UTC)
Zora la rousse
[size=1" face="Verdana" id="quote]quote:Originally posted by huttel
La vie est belle!
//Thomas
Sweet Smile.
Congratulations wink.
Timaximus Offline
#91 Posted : 23 September 2006 13:29:31(UTC)
Timaximus
First: Beautiful daughter.
And congratulate your wife too for all the hard work she did the past 9 months.
Second: Now you have painted the layout structure it looks fantastic.
Just like the old layouts from the Märklin catalogues in the past.
Three: your wiring is a mess wink (looks familiar).
Timaximus
HueyCE Offline
#92 Posted : 23 September 2006 16:48:30(UTC)
HueyCE
Congratulations on the birth of your daughter.
Your layout looks very clean, it's great that you got 12 trains to run simultainiously.
Ira
Rowan Offline
#93 Posted : 23 September 2006 20:39:01(UTC)
Rowan
To you and your wife ,congratulations.
The layout is looking very good Thomas.
huttel Offline
#94 Posted : 23 September 2006 23:24:56(UTC)
huttel
Hi all
My dear (and rather tired) wife and I thank you all for your kind words. It is our second daughter and completes our lives in a beautiful way.
As for the layout I´m struggeling with WDP but it is slowly coming together. I will post more pictures as I get along and I am quite pleased with the results so far inspired by the old 1984 Märklin layout:
//Thomas
Carpe Diem!
miccar Offline
#95 Posted : 24 September 2006 01:22:19(UTC)
miccar
Congratulations on the newly born!
rugauger Offline
#96 Posted : 24 September 2006 23:15:09(UTC)
rugauger
Many congratulations on your new arrival, Thomas!
Richard
Purellum Offline
#97 Posted : 25 September 2006 03:34:39(UTC)
http://www.dieselairhorns.com/sounds/NathanP7x.mp3
Congratulations to your wife and you! [^]
foumaro Offline
#98 Posted : 25 September 2006 08:12:00(UTC)
Congratulations for the new member of family.There is nothing more
important of a baby in a family.biggrin
ulf999 Offline
#99 Posted : 25 September 2006 20:53:09(UTC)
ulf999
Congrats Thomas! btw very promising layout
huttel Offline
#100 Posted : 16 October 2006 15:00:45(UTC)
huttel
Hi all
A few more pictures as the new layout is coming together...
Ramp to upper levels
South-West corner
North-West corner and bridges
Main control table and cabinet doors are finished. Cabinet doors heavily inspired by Timaximus' solution Smile
BR110 coming down as the V80 is going up
My new VT08.5 meeting the SVT137 - or as I understand it new C-sine meeting old C-sine. I have had a lot of trouble getting the VT08.5 to run as I want it to and I will probably have to take it back to be fixed.
I also tried to put a web photo album together. Needs more work but it is avaliable here http://www.huttel.dk/marklin/photo/mphoto/ - if you are up for more pictures
I have been concentrating on the WDP programming and are very satisfied with the results so far. When finished I will start adding more "color" (i.e. trees!) to the layout. But it is funny to sit and look at the first pictures and original layout and now actually be able to have trains running. Been a long but very good journey - and the best is that i'm only half-way Smile
//Thomas
Carpe Diem!
4 Pages<1234>
This page was generated in 1.242 seconds.
Map
See the web site statistics
Bookmark and Share
