Offline JanThyregod
#1 Posted : 14 October 2014 09:17:19(UTC)
JanThyregod
You have been a member since:: 12/09/2014(UTC)
Hi Guys
I have a Marklin 37901 where I believe the motor control board to be dead as everything on the train seems to work except motor control.
I have been searching for the part "marklin 611625" but not been able to locate it, and it seems not to be an available spare part. MArklin 37901 spare parts
Have heard that a lot of C-sine motors have had a similar problem so here goes :
1. Anybody know where to get the part ?
2. Is it possible to rebuild the loco to use a different motor ?
I will really prefer not having any C-sine trains. A life span of 3 years is just not acceptable as it has been driven extremely little.
Thanks for any help
Jan
Offline Oliver SBB-CFF-FFS
#2 Posted : 14 October 2014 09:28:50(UTC)
Oliver SBB-CFF-FFS
As I can only answer you second question I will jump straight to that.
I have once converted a 39560 green croc from a sinus engine to a normal high efficiency propulsion enginge + 60947 decoder. This was because the driver board/decoder was dead.
So it is possible.
Hope it helps,
Oliver
SBB Era IV - VI
thanks 1 user liked this useful post by Oliver SBB-CFF-FFS
Offline JanThyregod
#3 Posted : 14 October 2014 09:33:02(UTC)
JanThyregod
Just checked the later model but with a motor pice of EUR 180 that is a drop dead conversion.
I will rather buy a new Brawa model instead...
Tried to search C-sine on ebay.de just now.... A LOT of Marklin for sale !!!
Marklin should review and act on what people think of their products, I am certainly not impressed any longer.
Offline Moritz-BR365
#4 Posted : 14 October 2014 11:15:37(UTC)
Moritz-BR365
The 37901 has a C-Sinus in compact format (similar to SDS), so it isn't possible to install the 5-pole HLA DCM motor. But it should be possible to find a replacement, either a bell shaped amature motor or a standard DC motor.
Offline JanThyregod
#5 Posted : 14 October 2014 11:34:29(UTC)
JanThyregod
Thanks for your reply, any idea where I can look for a replacement motor ?
I am busy building my track and prefer not to "waste" to much time at this stage looking for alternative.
If someone has a "turn-key" rebuild solution I would be most grateful, and I don't mind changing to a non-Marklin decoder. Don't dislike Marklin, but I find their parts supply quite odd Confused and would prefer easily available parts. BigGrin
Thanks again for leading me on the right track ahead as I really like this Loco BigGrin
/Jan
#6 Posted : 14 October 2014 12:02:10(UTC)
Don't SB Modellbau make replacement motors for C-Sine motors?
http://www.sb-modellbau.com/
#7 Posted : 14 October 2014 12:11:34(UTC)
Motor kits for Br212 / V100 here...
http://www.sb-modellbau....498&cPath=256_27_139
I'd email them and ask for details on what you need for your specific locomotive.
#8 Posted : 14 October 2014 12:15:41(UTC)
OK, my bad - your loco is the BR290.
As I say, email SB Modellbau with your loco specifics.
#9 Posted : 14 October 2014 12:53:55(UTC)
Moritz-BR365
The problem is, that on the mtc21-Board, there is a special driver electronic to supply the C-Sinus motor. For a standard DC motor, You need a standard mtc21-board. But this is a good thing, because an mtc21 board costs only ~10€ and You can continue using the original mfx decoder of Your loco.
Now, to find an replacement for Your motor, You need to know the dimensions (lengt, Diameter, diameter of the axle). Probably, You could aks the Märklin service if there is a standard DC motor, that fits into this loco.
Offline JanThyregod
#10 Posted : 14 October 2014 13:27:11(UTC)
JanThyregod
Thanks BigGrin
In the meantime I have found that the decoder is manufactured by ESU and when you perform a RESET, the decoder forgets it has a C-Sinus motor.
Next step this evening is to connect my lok programmer and set the right CVs according to ESU manual for C-Sine.
I gave the train a reset as I had problems connecting to the engine. Hate that I followed the manual but should not have done so !!!
I will go for the DC motor change and have written to the company above, but throwing more than EUR 110 after a loco that cost less used a year ago is really a little silly Blushing ... think I will try to sell it as faulty and buy a new one from Brawa or Roco as a replacement.
#11 Posted : 14 October 2014 14:23:34(UTC)
Moritz-BR365
Maybe, You had reset the decoder and now, You only have to set AUX4 to always on? I remember thet AUX4 must be activated to provide power to the C-Sinus driver board.
Offline JanThyregod
#12 Posted : 15 October 2014 11:03:03(UTC)
JanThyregod
It seemed to do the trick, now the train moves like a bullit !!! need to adjust something I believe.... problem is you have no access to CV programming from an ECoS. Programming this on an ECoS is little tricky and I needed to do several tests, but it works :-)
Thanks for all your help BigGrin
Offline supermoee
#13 Posted : 15 October 2014 12:06:09(UTC)
supermoee
the C-sine compact/SDS driver boards are still available at Märklin as spare parts. you cannot order them as spare parts, but you can send in the loc to Märklin for repair.
I had some problem on a 39501 Br150 because I built in a wrong decoder and the driver circuit died. I sent the loco in approx 8 month ago an get it repaired for approx 38 Euro included shipment costs.
A second hand 39803 loco had still the wrong working board from 2006. I sent it in for replacement one approx one year ago an got it replaced for free.
I have 25 locos with C-sine, from the Br103 Insider on (so nearly to 10 years old), and never had a problem with this engine. The only death I had was caused by myself. a fantastic motor.
rgds
Stephan
thanks 4 users liked this useful post by supermoee
This page was generated in 1.184 seconds.
