Wish to join the discussion?! Login to your marklin-users.net community | Forum accountor Register a new forum account. Or Connect via Facebook
Edited by user 18 August 2014 09:09:14(UTC) | Reason: Not specified
If the coaches has a NEM-pocket and a guide mechanism you are fine (most coaches do). The purpose of the guide mechanism is to keep the couplers straight - even in very tight curves. I use the Roco close coupler between my coaches and they negotiate R1 just fine. It looks crappy while they do, but they get the job done. I tend not to use R1, but currently I have no choice (the table is too small ).
Your only potential problem is the accessories that you may have a long the track. There is no way a true to scale UIC coach will be able to pass a C-track mounted signal. The 1:100 coaches just barely does.
Funny enough, yesterday I wrote an article about tighter curves and coaches (true to scale and shortened versions), and the problems you may face (or at least need to think about when designing your layout). It visualizes some of the problems and might be of some use to you: http://www.bahnfan.net/post/2014/08/17/true-to-scale-coaches-vs-the-shorter-length-coaches
LOL. That is a clever idea! I expected the 282 mm coaches to have some changes made to them in order to get pass a signal. It does not matter to me how the model is technically designed. If it helps smooth the operation, I welcome it. I am more on the visual part which is also why 1:100 coaches are kind of off limit. But I am not sure about the 282 mm coaches. Some of them are quite nice IMO.
