8 Pages123>»
Offline French_Fabrice
#1 Posted : 29 January 2012 21:06:29(UTC)
French_Fabrice
Hi Märklin fans,
After spending one year of testing, trying various ideas and making a lot of mistakes, I've decided to start a new project.
As I'm constrained by the available space, the layout will be small : 2.84m * 1.48m. It's a variant of a three-level layout described in Marklin Magazin 2010/04.
Here are the plans:
Level 1 - hidden station
Level 2 - hidden ramps
Level 3 - visible
and finally, it should look like this (not all the buildings are visible - missing 3D forms)
Well, quite some work to do...
Here are a few shots of the foundations:
Hmm...my cat is very interestedConfused
Is it rock solid ?
Some view from the underneath command center (S88 feedback)
Today's work: preparing for getting S88 wires
Command center, from the top; Wifi transmitter to the computer network; programming track;
Well, it's ready for level 1BigGrin
Deadline is end of year 2012.
I'll post from time to time, when progress is significant;
Fabrice
Edited by user 31 December 2012 17:57:20(UTC)  | Reason: subject changed
thanks 2 users liked this useful post by French_Fabrice
Offline petestra
#2 Posted : 29 January 2012 22:47:37(UTC)
Hi Fabrice. Very nice track plan. There is a-lot of operation possible in a small area. Have fun building and keep us posted thru its progress. Kitty will enjoy it too as my two do!Scared
PeterThumpUp Smile
Offline Piggy
#3 Posted : 29 January 2012 23:04:19(UTC)
Piggy
Hi Fabrice. Look like you put a lot planning to the track plan. Great thinking planning the brake section at this early stage. I'm convinced you layout have great playability, I'm sure it going to turn very nice indeed. My only question is regarding access to the hidden areas, isn't it going to difficult if you build from 0mm elevation and upwards?
Kenneth
Offline MikeK
#4 Posted : 29 January 2012 23:08:59(UTC)
MikeK
Hi Fabrice, That looks like some very nice bench work, and your wirering is admirable, looks like you really planed this through, can't wait to see how the layout progresses, keep us posted :)
^__^
MikeK
A single track on the floor is better than no track at all...
#5 Posted : 30 January 2012 05:00:54(UTC)
Hi Fabrice,
Congratulations on a very comprehensive approach to the layout building.
I particularly like your wiring planning, mine is embarrassingly untidy, and difficult to trace faults or plan extension.
HO Scale - Märklin (ep III, C Track, digital) - 2 rail (USA and Australia) - 3 rail (English Hornby Dublo) - a few old O gauge.
Offline Ian555
#6 Posted : 30 January 2012 05:52:11(UTC)
Ian555
Hi Fabrice,
Great start to your layout. ThumpUp
Ian.
Offline TrainIride
#7 Posted : 30 January 2012 09:23:47(UTC)
TrainIride
Hi Fabrice,
A nice track plan,
A sufficient place,
A neat wiring,
A cat.
You have gathered all the components to build a great layout.
Congratulations !
Joël
Marklin HO - M track & C track - Analog mode - DC locos conversion to AC - http://www.marklin-users.net/TrainIride - my channel : http://www.youtube.com/user/2mes2mains
#8 Posted : 30 January 2012 18:33:36(UTC)
French_Fabrice
Thanks to all for such a warm feedback ! Love
Fabrice
Offline Marklin in Oz
#9 Posted : 30 January 2012 20:29:19(UTC)
Marklin in Oz
Looks like a fantastic start! Mine's up and running at this point and I WISH I would have put up backdrops first as you have.
Blink
Wink
-Fred
Offline Johnvr
#10 Posted : 02 February 2012 20:16:49(UTC)
Johnvr
Good to lay a solid foundation like yours !
Those s88 boxes : how many control tracks do you plan to have on the layout ??
Regards,BigGrin
#11 Posted : 03 February 2012 22:56:41(UTC)
French_Fabrice
Hi John,
At the present time, 45 inputs over 48 are planed to be used, so 3 are remaining free. It's not a lot if I decide to use for instance some blocks with more than 2 sensors...maybe I should add right now one more S88 unit to be more comfortable...Unsure
You can try to count the contact tracks on the plan. These are the "grayed" tracks (mostly 2295 units and a few "hand made" contact tracks, i.e. 15° curves like 2223, 2233 and 2 momentary contact tracks - the green ones).
Roughly counting, I have 2O blocks, without siding. Some blocks have 2 sensors, mainly on the visible part - level 3, to be able to stop precisely the locos just before the signal. Others have only one sensor.
Fabrice
#12 Posted : 04 February 2012 06:29:44(UTC)
Hi Fabrice!
Looks pretty good, lots of variations and combinations with traffic...(but why am I *not* surprized?Wink )
I see you have mounted the whole thing on wheels, just in case you'd need access to the rear...good precaution
Speaking of access: do you plan to cut out the track pattern (level 1 essentially) out of that big piece of plywood?
If not you may have difficulties if you need to intervene in the diagonal hidden station
Your wiring looks pretty good!
I'll be taking lessons!
Jacques
#13 Posted : 04 February 2012 09:36:47(UTC)
French_Fabrice
Hi Jacques,
You've hit one of the design flaws of my layout : accessibility Crying
It's hard to find the right balance between what I'd like to have and what is doable. Sigh...!
I'm also waiting to have pictures from your Swiss layout project, which will be certainly very impressive.ThumpUp
fabrice
#14 Posted : 05 February 2012 21:08:31(UTC)
French_Fabrice
After making plans, let's start.
Putting tracks and preparing some track beds.
<shot007>
Preparing insulated sections.
<shot008>
Finished for today. 3-way turnouts are done.
<shot009>
It's not ice, but polyethylene foam. Trying that instead of cork.
<shot010>
Station exit
<shot011>
To be processed next time...
<shot012>
That's all folks. Stay tuned.
<shot013>
Fabrice
PS: Server has trouble with uploading. I've attached files
Edited by user 05 February 2012 22:16:06(UTC)  | Reason: attached files
French_Fabrice attached the following image(s):
Offline BR01097
#15 Posted : 06 February 2012 01:35:55(UTC)
BR01097
Our animals always seem to want to be a part of the activity which engages us so. I thought my cat was unique in this: apparemment, il n'est pas du tout unique.
#16 Posted : 06 February 2012 08:49:04(UTC)
Great start, Fabrice! ThumpUp
This promises to be a great layout for playing with! Also, it's unusual for this forum to see a layout built in K Track! I look forward to seeing the fruits of your labour!
Offline petestra
#17 Posted : 06 February 2012 11:17:07(UTC)
Wonderful start, Fabrice. PeterThumpUp Smile
Offline Ian555
#18 Posted : 06 February 2012 12:22:56(UTC)
Ian555
Hi Fabrice,
Great progress. ThumpUp
Ian.
Offline GlennM
#19 Posted : 06 February 2012 13:05:13(UTC)
GlennM
I think you have chosen a very flexible and interesting layout, and you have made a great start. Please keep us undated and lots of pictures.
All the best
Glenn
Offline igf2
#20 Posted : 08 February 2012 21:37:14(UTC)
igf2
Well done Fabrice ! Nice layout for a clever track plan.
#21 Posted : 12 February 2012 23:00:35(UTC)
French_Fabrice
Hello folks,
Great progress this week. It runs !BigGrin
I've setup most of the track beds of level 1, and wired the external oval and the 5 associated blocks.
A few shots:
Next step : finish the remaining blocks in the diagonal, and start the elevations...
Fabrice
Edited by user 17 June 2014 12:21:36(UTC)  | Reason: re-uploaded pictures
Offline Ian555
#22 Posted : 13 February 2012 08:01:13(UTC)
Ian555
Hi Fabrice,
Your wiring is very neat and tidy, looks great. ThumpUp
Ian.
#23 Posted : 19 February 2012 20:35:43(UTC)
French_Fabrice
Hi Märklin fans,
Intensive work this week-end. Layout is growing up...BigGrin
A few shots:
Men at works (1)
Men at works (2)
The 2 ramps are joined
An other shot of the junction
At foreground, the descending ramp
Overall view
Finished for this week-end...
Fabrice
Edited by user 17 June 2014 12:22:10(UTC)  | Reason: re-uploaded pictures
#24 Posted : 19 February 2012 21:39:07(UTC)
Look very good.
I think the Cat is inspection your layout.LOL
Offline petestra
#25 Posted : 19 February 2012 22:42:37(UTC)
Hi Fabrice,
The layout is looking great. Enjoyed the update! PeterSmile
Offline charles Sharpe
#26 Posted : 19 February 2012 22:54:37(UTC)
charles Sharpe
Hello Fabrice
The layout is coming along nicely.
Charles
CHARLES SHARPE
Offline kariosls37
#27 Posted : 20 February 2012 05:36:49(UTC)
kariosls37
Lookin' good FabriceThumpUp
Don't go easy on the supports for the raised section. It will come back to bite you in a couple of years time.
Rick
Offline Ian555
#28 Posted : 20 February 2012 06:22:25(UTC)
Ian555
Hi Fabrice,
Great progress on the layout. ThumpUp
Ian.
Offline efel
#29 Posted : 20 February 2012 09:44:17(UTC)
efel
Then don't forget to short the end shutoff contacts of the turnout motors!
Fred
#30 Posted : 20 February 2012 12:21:37(UTC)
French_Fabrice
Thanks to all for your comments !
@Fred : That seems to be a good idea, but how do you do that (never did it before) ? My turnout motors are 7549. If the explanation is too long, a link or pointer will be greatly appreciated.
Fabrice
Offline efel
#31 Posted : 20 February 2012 15:01:46(UTC)
efel
Fabrice
You can see where to shunt the shut off switches there
Fred
thanks 1 user liked this useful post by efel
#32 Posted : 25 February 2012 21:42:44(UTC)
French_Fabrice
Works on hold...
Inspector is inspecting...
Laugh
Fabrice
Edited by user 17 June 2014 12:27:21(UTC)  | Reason: re-uploaded pictures
#33 Posted : 25 February 2012 22:04:55(UTC)
Mmmmm Chief Inspector does not look too happy, must have found something not quite right.
Looks great though.
Nev
wearing the Pink Pinny, which is hard to see and now have a new shiny tin Hip that is badly in Need of Repair
Offline Yumgui
#34 Posted : 25 February 2012 22:07:59(UTC)
Yumgui
Fabrice,
L'inspecteur semble dubitatif ^^ Laugh
(trans: The inspector seems skeptical ...)
Also, I agree with this:
Be careful of the future ^^ !
Y Tongue
Working on : http://www.arep.fr/en/#/welcome
Inspired by : http://www.nakedmarklin.com/ ... I am not alone in this universe, phew.
Offline petestra
#35 Posted : 25 February 2012 23:21:38(UTC)
Hi Fabrice. Great photo! What is the name inspector chat? Laugh Peter
#36 Posted : 26 February 2012 00:51:47(UTC)
French_Fabrice
"Lili", it's a female.Smile
Fabrice
#37 Posted : 26 February 2012 00:54:00(UTC)
French_Fabrice
Thanks, Peter!
It's name is "Lili", it's a female.Smile
Fabrice
#38 Posted : 26 February 2012 05:55:46(UTC)
Fabrice,
great looking layout, looking at your raised section, I think it will withhold the weight of any train and to compare my supports with yours, mine is still standing and holding up after 35 years and this is with hot glue not wood glue but its always better to overdue it, than as pointed out, having problems down the track so to speak.
Your cat needs a night out or had too many late nights.
You rail connectors: I assume you connect them to a S88 detection module and the rail connectors on the this side are the ground connectors.
Lot of modelers install blocksystems, which is ok but it doesn't give you any guarantee of a free accident scenario; e.g. a train looses some carriages, in this case in the siding with 3 tracks. a train will not enter any siding track if there are any carraiges detected.
Detecting carriages or a loco is by isolating one rail and this is easely done with k-tracks, The S88 detects if there is anything on the track (AC wheels are detected).
regards.,
Offline Johnvr
#39 Posted : 26 February 2012 07:57:19(UTC)
Johnvr
Fabrice,
Really looking fantastic.
All those long evenings which you spent planning this layout are now showing the model railway builders motto :
"Plan twice, cut once !"
Regards,BigGrin
#40 Posted : 26 February 2012 10:46:06(UTC)
French_Fabrice
Yes John, you're right. I have a total of 14 blocks in levels 1 and 2 (added one block last night in the left curve of level 2) to manage all the stuff in automatic mode with Rocrail. All blocks are wired (17 S88 inputs are used now over the 48 available) and OK.
Speaking of loosing carriages, especially while going up, wagons will arrive at the speed of light Crying (I've tried with one tank wagon, happily with no derailment until now) in the hidden station. The software will stop all trains ("ghost block" feature) in such a case, but it will not prevent from a crash on a staying train. I'm thinking of letting the straight track connected to the 3-way turnout always free to prevent disaster. I should have planned an emergency escape laneBlushing ... I'm gonna think about it, maybe it's not too late.
Cheers to all
Fabrice
#41 Posted : 26 February 2012 11:10:04(UTC)
French_Fabrice
Hello folks,
Well, Kitty is sleeping now, so I could finish the ascending ramp.
Here are a few shots:
Yes, power is off !
From a larger point of view...
Overall view of ascending ramp...
Overall view of descending ramp in the background...
The long piece of straight track in the foreground will be the visible part of the ascending ramp...But I think I will start with the visible descending ramp at the rear...I have a lot of wood plates to cut...
Stay tuned
All the best
Fabrice
Edited by user 17 June 2014 12:32:51(UTC)  | Reason: re-uploaded pictures
Offline pab
#42 Posted : 26 February 2012 11:23:56(UTC)
pab
Nice set up Fabrice.
I see a lot of ground connections on just one side of the track. I suppose you know that the rails in K track are not connected. Is there a specific reason for the ground connections on one side?
#43 Posted : 26 February 2012 11:47:38(UTC)
French_Fabrice
All one-sided ground connections are here to provide feedback to the S88 modules. When a loco or a wagon stays in a section (block) delimited by 2295 tracks and linked thru such a ground connector to the S88, the corresponding information on the S88 line is set to "up", and then the software can deal with the fact the corresponding block is occupied...
Does it answer to your question ?
Fabrice
Offline Ian555
#44 Posted : 26 February 2012 12:08:22(UTC)
Ian555
Hi Fabrice,
Looking at the first photo (post 41), how are you securing those supports in position, and is that 6mm plyboard that the K track sits on.
Ian.
#45 Posted : 26 February 2012 12:52:13(UTC)
French_Fabrice
Hi Fabrice,
Ian.
Hi Ian,
-the track beds (on level 1 and 2) are done with 5mm thick plywood.
-all the track beds are screwed to the pillar with two (or four) 2*12mm screws (it's enough, in my opinion, to maintain firmly the track beds to the pillar)
-the pillars have a base plate and a top plate; the base plate is either 5 or 10mm thick plywood; the base plate is screwed to the pillar with at least two 3*20mm screws; the base plate is then screwed to the foundation plate with at least two 2,5*20mm screws (if the base plate is 10mm thick, I use 3*20 screws); the top plate is screwed to the pillar with two 2,5*16mm screws...
I plan to use 10mm thick tracks beds on the upper level, but I'm still thinking...
Don't hesitate to tell me if I wrong !
Fabrice
Offline Ian555
#46 Posted : 26 February 2012 13:16:29(UTC)
Ian555
Hi Fabrice,
Maybe, it's just in the photo's, but the track bed does look a little narrow, the slightest derailment and your expensive wagons/coaches/Loco's, would have a considerable drop to contend with.
Still time for a wider track bed and or some side supports.
Also, 5 or 6mm plyboard will have, over a period of time, some "give" in it, so plenty of your supports underneath.
Ian.
#47 Posted : 26 February 2012 13:54:01(UTC)
French_Fabrice
Hi Fabrice,
Ian.
Mmmm, good to know before it's too late.
Thank you, Ian !
Which minimum thickness do you recommend for the track beds ? 8, 10, more ?
Also, my track beds are 5cm wide...maybe 7cm wide will be better for aerial parts ? (and side supports also)...
Fabrice
Offline Ian555
#48 Posted : 26 February 2012 14:26:26(UTC)
Ian555
Hi Fabrice,
I used 6mm plyboard for my Helix construction and 2.5 years later, no problems with it, but it is wide enough for a double track and also it has plenty of screwed rod supports.
Although, I must say, I do not have any side supports on it, but then, when you're using good old M track, you never have any derailments. Wink Smile
Ian.
Offline pab
#49 Posted : 26 February 2012 14:32:39(UTC)
pab
Fabrice
Yes yjat makes sense, but you also need right side connections for the normal ground connection and left side connections outside the isolated S88 sections. Are those connected in another way?
#50 Posted : 26 February 2012 15:37:09(UTC)
French_Fabrice
Fabrice
I you look at my plan, the grey straight sections are the 2295 tracks (one side sectioned rails). The red sections (for lvl 1 & 2) are feeder track rails (violet for lvl 3), providing both "B" and "O" lines. As a general rule (except when I've forgotten it) most of the time a sectioned block is followed by a feeder track, so I always get both left and right rail connected to ground outside the block. So I can use either the left or right rail inside a block, depending on the way I put the sectioned tracks, to get the S88 signal.
Fabrice
OceanSpiders 2.0
8 Pages123>»
This page was generated in 1.980 seconds.
