8 Pages<1234>»
pab Offline
#51 Posted : 25 August 2010 14:45:55(UTC)
pab
Looks very good.
I see you have no saftety measurements on the helix and you tracks just fit on the ramps. Not afraid of falling trains when, or if, a derailment happens.
With kind regards
Piet Brijs
Website: http://home.kabelfoon.nl/~pabrijs
Topic in Marklin-users.net: http://www.marklin-users.../topic.asp?TOPIC_ID=8363
Youtube channel: http://www.youtube.com/user/pietbrs?feature=guide
Rinus Offline
#52 Posted : 25 August 2010 19:09:45(UTC)
Rinus
Good evening gentlemen,
Thanks for you comments.
@@ Lord Macca: I havent been able to test the absorption of noice or the prevention of resonance yet. However I dont expect it to appear. The 4 mm cork will take away a lot of vibrations. Furtermore the wooden segments, which are made quite robust, will do their bit too. Besides that the track is glued and not screwed on the cork. Finally the frame is glued together for the larger part. Glue does not transport vibrations like srews and bolted connections.
Will vibrations get through I've gort the option to place rubber rings between the few bolts left and fit rubber shoes underneath the framework.
If all goes well I hope to be able to do some testing of the segmenst this weekend and we will see.
@@ Piet: there will be some safety measures. Allthough the allignement of the track is good, there can allways be something unforeseen that will cause a derailment (for instance my cat). I'm thinking of making some sort of safety fence after I've placed the catenary in the helix.
Question to all: would you place the ringwire in the hidden yard between the tracks or under the surface?
Rinus
Rinus Offline
#53 Posted : 25 August 2010 19:14:03(UTC)
Rinus
nevw wrote:
Rinus wrote:
petestra wrote:
Hi Rinus, looks great and there was so much work on that framework, wow! I don't think that you have made an error in AC over DC. I had DC before Marklin AC and would never ever go back! Cheers, PeterSmile
Thanks Peter!
I'm quite sure about that. There is so much more choice in DC (track, rolling stock) at often better prices. Problem is, I've got quite a lot of rolling stock and track, all AC. It would be much too expensive to change.
Rinus
Not too much problems in running DC Rolling Stock, may have to regauge the wheels or a drastic thing to do is change wheel setc. but usually niot necessaty.
Sorry. With rolling stock I meant trains and locomotives not carriages. My mistake.
In fact I have quite a lot carriages and coaches from Brawa, ACME and Roco. Simply chance the wheels.
Still I regret the fact that Peco and Roco etc don't offer AC track. Those sleek switches and concrete sleeper track are very very nice.
Rinus Offline
#54 Posted : 29 August 2010 12:23:39(UTC)
Rinus
The overhead system in the helix will be build as follows:
Plan is to take a metal strip, bend it in the right radius, position it with and glue it above the track.
Rinus
Rinus Offline
#55 Posted : 12 September 2010 20:04:21(UTC)
Rinus
Hi there! Time for an update!
Work has been done on the overhead system in helix # 1. How? Simple: take a alluminum strip, bend it in the right radius, glue it above the track, allign it, fasten it for 24 hours and done! Cheap and simple.
trein 005 [/url], on Flickr
During the drying of the overhead system, I also found time to build the first hidden yard. Since I only have a plan of the lay out in my head and not from a programm, tis involved a little puzzling. I've chosen to build two 13 track yards. Each with a lenght of +/- 350 cm. Without switches this will result in a useable lenght of 250 cm per track. Razz Razz . I spent quite some effort in keeping the tracks alligned nicely, and this is the result. All was alligned with a laser and fastend with hot glue. Its not fully completed, since I have to order some extra track (2200's).
trein 003 , on Flickr
trein 004 , on Flickr
trein 007 , on Flickr
trein 001 [url=http://www.flickr.com/people/41042613@N05/], on Flickr
Its difficult to oversee the entire lay-out. But to give you an idea of the dimensions: after completing both helix 1 and 2 and hidden yard 1, I've used all the track of my prevuous lay-out!
Have fun,
Rinus
Ian555 Offline
#56 Posted : 14 September 2010 05:55:17(UTC)
Ian555
Hi Rinus,
Great looking work. ThumpUp
Plenty space for parking long trains.
Ian.
Rinus Offline
#57 Posted : 14 September 2010 19:56:58(UTC)
Rinus
Ian555 wrote:
Hi Rinus,
Ian.
Yup, up to 230 cm!
I learnt that because of the steep parts of the Brennerbahn and the limitations of the couplers, the train lenghts in real-life aren't that long as one would think.
For instance a RH 1020 (the austrain equivalent of a German Gator or BD 194/E94) could only manage to pull 550 t. A modern Taurus 650 t.
For this reason they use a lot of double or even triple (2 pull, 1 push) combinations to pull 1300 t trains uphill!
Over here two Taurus locs are needed to pull a 7 couch train.
And here at least two Rh1044 pull a RoLA train.
Imagine the posibilities on my lay-out Razz Razz !
Rinus
muzza Offline
#58 Posted : 15 September 2010 00:24:00(UTC)
muzza
Great photos ,Rinus. Will you have a chance to post more?
Murray
Rinus Offline
#59 Posted : 22 September 2010 21:39:59(UTC)
Rinus
A short video. It captures the testing of the hidden yard last month.
MOVIE
My ALn 442 and a E40 are to be seen as well as my inspector.
Interesting to hear is the noice produced by the old coffee grinder (5 star marklin engine) and the Roco.
More videos will follow.
Rinus
RayF Offline
#60 Posted : 22 September 2010 21:44:31(UTC)
Very good, Rinus. ThumpUp
For a minute I thought the E40 was going to hit the railcar rather hard! Scared
Ray from the Rock.
Mostly Marklin Era III & IV
6021 replaced with MS2
nevw Offline
#61 Posted : 23 September 2010 00:52:31(UTC)
RInus, missed this before BUT you can get centre contacts strips for Peco track.
There area few posts on the forum regarding this. also making peco switches into 3 rail ones.
Nev
wearing the Pink Pinny, which is hard to see and now have a new shiny tin Hip
Rinus Offline
#62 Posted : 24 September 2010 10:25:51(UTC)
Rinus
LOL LOL It would have, if I hadn't made an emergency stop! That would have been 1-0 for the metal E40 vs the ALn 442/448. Crying Cursing
Rinus Offline
#63 Posted : 24 September 2010 10:27:59(UTC)
Rinus
Nev
Hi Nev,
Yes so I have read too. But I wasn't able to find the paticular items on the Peco website.
Rinus
nevw Offline
#64 Posted : 24 September 2010 11:51:10(UTC)
Nev
Hi Nev,
Rinus
A few firms make the strips. I will get the part numer and maker for you.
Nev
Marty Offline
#65 Posted : 24 September 2010 14:26:58(UTC)
Marty
Rinus,
Thanks for posting these updates. I enjoy following your progress. Cool
Marty
nevw Offline
#66 Posted : 24 September 2010 23:54:07(UTC)
Update on the centre rail bit for Peco track.
I am still waiting for that BUT there is a topic or two in past years in the forum.
If you search Peco you should find it.
N
nevw Offline
#67 Posted : 25 September 2010 01:10:52(UTC)
Got it the Peco Part number is:
PSL 17 - stud contact.
also Erbert??or Ebberert Engineering make a stud contact strip.
If you search topics and use Peco there are some topics about april/may 2010 and also 2009
NN
Edited by user 25 September 2010 01:20:25(UTC)  | Reason: Not specified
Rinus Offline
#68 Posted : 10 October 2010 10:55:11(UTC)
Rinus
Update!
Done a lot of testing last month. Apart from the catanary coming down (wrong glue) there were no problems. I'll be doing some installation work next month, before beginning on hidden yard # 2.
And we have a new visitor! The Rh 1012 arrived. What a machine!
Overview
Transaction between helix and hidden yard
Lissy components
New visitor
Rinus
GSRR Offline
#69 Posted : 03 February 2011 01:23:25(UTC)
GSRR
Rinus,
Been some time how are you progressing?
r/Thomas
ETE-ENE ECoS iTrain TouchCab C-Gleis German Era Id & IIIb USA Era IIIb SBB Era III SJ Era IV GC Era V
Rinus Offline
#70 Posted : 06 March 2011 11:11:29(UTC)
Rinus
steventrain Offline
#71 Posted : 06 March 2011 11:20:50(UTC)
Excellent videos.ThumpUp
I see the cat tail.Wink
Large Marklinist layout with C-tracks/Central station 2/Mobile station 2/Boosters 60174s/Marklin collector since 1990s/Collector Marklin from the 1950s/Favorites Steam class BR01/BR03/BR05/BR50/Insider Club membership.
petestra Offline
#72 Posted : 06 March 2011 11:27:25(UTC)
Well done, Rinus! Did you cut the metal works yourself for those Helixes or were they bought that way? I couldn't help but chuckle at kitty's tail in the second video.
Cheers,PeterThumpUp
RayF Offline
#73 Posted : 06 March 2011 11:42:06(UTC)
Nice work! ThumpUp
Ray from the Rock.
Rinus Offline
#74 Posted : 06 March 2011 13:22:26(UTC)
Rinus
Thanks all!
Cheers,PeterThumpUp
I've build them myself as can be seen from post #18 and onwards of this tread.
Our cat is very interested in the trains. Especially those with sound.
I'd love to begin on the upper works of the lay-out, which will feature the station and the main line. However we are planning to move houses, so I'll have to be patient and wait untill then.
Rinus
Marty Offline
#75 Posted : 06 March 2011 22:10:36(UTC)
Marty
Thanks for posting the videos. It looks like the catenary in the helix is really working out well.
Marty
Rinus Offline
#76 Posted : 07 March 2011 17:25:24(UTC)
Rinus
Yes and at a cost of € 2,00 per meter for the strip and some glue, much less expensive than the catenary sysems for tunnels sold by most manufacturers like viessman and faller. LOL LOL LOL
rinus
Rinus Offline
#77 Posted : 18 September 2011 16:47:39(UTC)
Rinus
So we have finally moved over to our new house!
The old train room measured 3.6x3.6m. The new one is 5x5m! I'll extend the old lay out with 1m in lenght and 0.5m in dept and keep some room left to enable myself to walk around te layout.
I've started to asemble the layout. Some pictures of the chaos...
Enjoy!
Rinus
Loadmaster Offline
#78 Posted : 18 September 2011 17:48:51(UTC)
Loadmaster
Thanks for the update.
I hope you move was uneventful and nothing was broken.
I've lost count on the number of moves I made while flying in the USAF.
Robert
petestra Offline
#79 Posted : 18 September 2011 18:03:23(UTC)
It will surely be a winner. Enjoy building.PeterThumpUp Smile
Rinus Offline
#80 Posted : 19 September 2011 19:07:41(UTC)
Rinus
Robert
2nd time we were moving. Glad we decided to. The new place is great, the surroundings very interesting (we now live very near the place where the Market Garden airborne landings took place in WWII) and is saves me two hours of traveling to work a day.
The helix was to large to be moved down the stairway and had to be cut in 4 pieces. The rest went ok. Hope to get things rolling soon!
Bye!
Rinus
kimballthurlow Offline
#81 Posted : 19 September 2011 21:27:53(UTC)
Hi Rinus,
Hope your layout reassembles without too many hitches.
So you still live in the Netherlands?
HO Scale - Märklin digital DB ep III, C Track - other 2 rail HO scale models (US - N&W and Australia - Queensland) - English LNER/BR Hornby Dublo 3-rail - a few clockwork items O gauge Märklin and Hornby.
nevw Offline
#82 Posted : 19 September 2011 22:51:34(UTC)
Great Move.
NN
river6109 Offline
#83 Posted : 20 September 2011 15:20:32(UTC)
Rinus,
I was just thinking about you the other day, I haven't seen any pictures or new locos.
I've added 2 new ÖBB locos to my collection: 68 646 ÖBB Rh 1245 and Rh 2043 both with sound.
Your new train room looks just the right size.
Edited by user 20 September 2011 19:05:54(UTC)  | Reason: Not specified
Rinus Offline
#84 Posted : 21 September 2011 19:09:23(UTC)
Rinus
Rinus,
Have been very busy doing some large renovations on our new house. Its like a big lay-out: there are allways things to do and money to spend on.
No new loco's for me anymore this year, except for a Rh1044 which is on order. My bank account is in a "financial crisis".
You've got the Rh2043 finally? Great move. Orange one?
Bye,
Rinus
Edited by user 02 October 2011 10:30:17(UTC)  | Reason: Not specified
Rinus Offline
#85 Posted : 02 October 2011 10:28:18(UTC)
Rinus
Some pictures of the reconstruction. Repaired helix #2. Repairs on helix #1 continue.
Got the main section extended with 1 m to a length of 4,4 m. Also fitted the topsection segments.
Groet,
Rinus
petestra Offline
#86 Posted : 02 October 2011 14:35:46(UTC)
Nice photos Rinus. It's going to be super! Cheers,PeterThumpUp
Rinus Offline
#87 Posted : 20 November 2011 22:37:21(UTC)
Rinus
Small update;
I've been working on the extention this weekend. The cork bedding arrived and put on the modules. Unfortunately this could not be said of the flex rail 2205 I ordered on ebay a week ago. The selled admitted he forgot to post the package Cursing Cursing Cursing Cursing Cursing .
Hopefully its there next weekend, so I can complete the extention and start working on the top level.
Rinus
FMS Offline
#88 Posted : 20 November 2011 23:38:55(UTC)
FMS
Rinus, great train room! Smile
The layout starts to look great!Smile
Don't you have humidity problems being so close to water? I try to keep humidity away from trains, that's why i ask.
FMS
Rinus Offline
#89 Posted : 21 November 2011 21:11:10(UTC)
Rinus
Thank you!
The water? That was in our old house. Were living in the forest now. Never experienced humidity problems though. I hope to keep it that way. BigGrin
Rinus
river6109 Offline
#90 Posted : 22 November 2011 00:44:26(UTC)
Rinus,
Looks very promising.
Don't you hate this, you buy something, roughly calculate the delivery time and than you find out it hasn't left the sellers address as yet.
Do you have any roof sprinklers installed ?
Rinus Offline
#91 Posted : 23 November 2011 11:11:19(UTC)
Rinus
Hi John,
No, sprinklers won't be installed. Do you have that in your houses in Australia? Its very uncommon here. I will install a smoke detection and C02 detection soon, however. I still have a long list of things to do in our new house Laugh .
I hope to find some time to seriously work on the lay-out though, since I miss the driving with my trains.
Regarding the ebay seller: its the first time this happens to me. Unfortunately I havent received an update from him again since he admitted he had not sent the parcel yet. Makes me wonder. I ordered 14 2205 flexrail and 4 2290 rail, which I need for the extention of mu hidden yard.
I also ordered 20 x 2290 from another seller in germany, which were shipped yesterday.
Rinus
Rinus Offline
#92 Posted : 27 November 2011 19:38:41(UTC)
Rinus
This weekend I was able to work on the extension of the hidden yard.
Pictures:
Next week, I hope to work on the wiring.
Rinus
Ian555 Offline
#93 Posted : 28 November 2011 08:51:17(UTC)
Ian555
Hi Rinus,
Great progress on the layout. ThumpUp
Ian.
Rinus Offline
#94 Posted : 04 January 2012 20:43:30(UTC)
Rinus
Finally!
I got it back togeter working again after moving houses! Cool Cool Cool
I've tested it this evening and my old railcar gave a positive light!
I can now finally continue with the upper level!
Rinus
Ian555 Offline
#95 Posted : 04 January 2012 20:52:17(UTC)
Ian555
Hi Rinus,
Congratulations. ThumpUp
Great looking work.
Ian.
Rinus Offline
#96 Posted : 04 January 2012 21:18:25(UTC)
Rinus
Thanks Ian!
Nothing more relaxing tahn working on my lay-out.
Rinus Offline
#97 Posted : 06 January 2012 22:52:08(UTC)
Rinus
Today I worked on the station section of the upper level.
I picture to make 'Steinach in Tirol'. Allthough I have 4,60m at my disposal, I have to make sacrifices on scale. Therefore I plan the first switch sections in a curve which will not be visible. This will save space and will allow me (hopefully) to give the rest of the station sufficient space.
Here is a picture of the Steinach in Tirols plan. I'll make it upside down, that is Gries (Gr) to the left and Matrei (M) to the right.
With special thanks to www.sporenplan.nl
First steps:
To be continued ...
Rinus
river6109 Offline
#98 Posted : 06 January 2012 23:21:09(UTC)
Rinus,
What a progress in such a short time.
One thing, make sure your board is not too thick in case you intend to use under the board turnout mechanism.
Rinus Offline
#99 Posted : 07 January 2012 08:38:51(UTC)
Rinus
Hi John,
What is maximum in your opinion? I'm now using 9 mm.
Bye,
Rinus
Ian555 Offline
#100 Posted : 07 January 2012 09:29:39(UTC)
Ian555
Hi Rinus,
Great to see the layout taking shape. ThumpUp
Ian.
8 Pages<1234>»
This page was generated in 1.545 seconds.
Map
See the web site statistics
Bookmark and Share
