4 Pages«<234
Offline klarinettmeister
#151 Posted : 25 March 2013 13:30:28(UTC)
klarinettmeister
Hi all!
It´s not easy having the time you need to plan the layout when you work alot and I´ve not finished moving Everything from my apartment. Today I´ve got some tima to spare and I´ve come up with a definitve version of the plan. I´ve also included all the Contact Points. It´s gonna be a Little bit complicated. There will be 3 coal trains (37970, 37973 and 37976) from the tracks closest the water and they are gonna run on the same tracks using the shuttle train function. Therefore I´m gonna use 2 7244 on Contact Points 11 and 7 and be activated by using the route function of the CS2 thereby fooling the S88. Pretty complicated but I Think it will work. I´ve got lots of problems using RocRail so I plan on only using the 60215.
I also intend to build the framwork mostly in plywood as open framwork in 4 different modules for easier seperating them if I move.
Also a new improvement are all the switches. The single track will be the one that connects to the rest of the layout. Now I "only" have to find a good way to use the Rolling mill, the Bonn station and the Faller military Buildings... and also find some good way to use all 4 Big Boys... and maybe some hidden shadowstations.
Please come with suggestions and comments. BigGrin
thanks 4 users liked this useful post by klarinettmeister
Offline kbvrod
#152 Posted : 25 March 2013 21:41:03(UTC)
kbvrod
David,I would use good quality pine board or MDO for the module frames,pine will be a lot lighter if you move.MDO is very rugged and again fit and finish is very important.
Also have a system to plug each module wiring into the next easily.
Dr D
thanks 1 user liked this useful post by kbvrod
#153 Posted : 26 March 2013 00:01:00(UTC)
klarinettmeister
Dr D
Thanks for the tip! The sheets of pine are quite expensive here and they are only 7,5 mm thick and there are also some pattern on them. I aim for 12 mm plywood. I´ve only been looking at 2 different stores.
I can´t find MDO and haven´t heard of it Before. Maybe there´s a different name for it here in Sweden... Or maybe it´s not used very often.
thanks 1 user liked this useful post by klarinettmeister
Offline Ian555
#154 Posted : 26 March 2013 06:47:05(UTC)
Ian555
Hi David,
"It's gonna be a little bit complicated".
Sure is for me anyway.Smile
I'd stick with plywood, if you want heavy weight go 18mm. ThumpUp
Ian.
Offline kbvrod
#155 Posted : 26 March 2013 13:34:31(UTC)
kbvrod
Hi David all,
all,
>Thanks for the tip! The sheets of pine are quite expensive here and they are only 7,5 mm thick and there are also some pattern on them. I aim for 12 mm plywood. I´ve only been looking at 2 different stores.<
I was thinking pine boards for the framework.Smile When you said modules and maybe one day -might- move again the lighter weight is better.The ETE module group teaching me a lesson.Scared
>I can´t find MDO and haven´t heard of it Before. Maybe there´s a different name for it here in Sweden... Or maybe it´s not used very often.<
MDO is explained here: http://en.wikipedia.org/wiki/Medium_density_overlay_panel
Big use in the US is road/highway signs and architectural uses on houses.The reason I used it on my old home layout was I couldn't find a true flat sheets of plywood! I need that for the large Bw I was building.MDO is perfectly flat,easy to cut,...
Dr D
#156 Posted : 19 January 2015 21:06:33(UTC)
klarinettmeister
Hi all!
Some time has passed since last update. I´ve been quite busy working and I´ve had alot of problems with my neighbours but at last some results are taking place.
After alot of sweeping on google I finally took ideas from a few layouts and changed them for my needs and rethinked them. Here´s the result:
Unfortunately I ordered all my wood after an older plan and that one didn´t need that much wood so I´m off shopping more wood.
This is going to be the profiles for the tables.
I had to have some inspiration when I was in New York.
Here´s one of the buildings I purchased at "the Red Caboose" while in New York.
This is everything trainrelated I could bring from the U.S.A.
Yes! It´s time to saw!
My first table is up and running.
And here´s my harbour comming together.
My first table with profileboards is done!
Here alot of profiles are waiting to be installed.
[url=https://flic.kr/p/qzK6Et]UserPostedImage
thanks 12 users liked this useful post by klarinettmeister
Offline Timaximus
#157 Posted : 19 January 2015 21:17:55(UTC)
Timaximus
Nice harbor MRR items.
Timaximus
thanks 1 user liked this useful post by Timaximus
#158 Posted : 20 January 2015 11:20:15(UTC)
Nice to view your matured layout design.
I adore that passenger station. I have the same, bought from a German online shop specializing in US MRR articles, which is located in Owschlag near the Danish border: http://www.moba24.de/catalog/index.php
Other online shop specializing in US MRR articles: http://www.rd-hobby.de/en-us/Home/Index
I never tried them, but the website looks promising.
Seeing your stub ends: On my US themed layout I use the C track end pieces, but removed the European style buffer stop: The "remaining" ballast heap looks prototypical and is strong enough to hold back cars. At least RELEX couplers of F7 locos and tin plate freight cars do not mind.
Greetz - Ak
#159 Posted : 08 February 2015 15:00:38(UTC)
Photographic evidence attached.
Greetz - Ak
OceanSpiders 2.0
4 Pages«<234
This page was generated in 0.903 seconds.
