laalves Offline
#1 Posted : 03 October 2008 21:54:32(UTC)
laalves
I propose that all CS2 owners document their HW and SW versions and the issues already discovered.
Each owner should start the post with the versions and then list the issues found.
When updating, please edit your post, instead of adding new ones to reduce the mess. Also, please do not discuss the issues, just list them, otherwise readability will be reduced. I suggest other threads to be created for any discussions related to the issues.
Also, if this thread shows up to be useful, maybe the almighty Webmaster could convert this into a sticky.
Webmaster comment:
*Only* issues are to be listed here.
Discussion about the issues are at http://www.marklin-users...topic.asp?TOPIC_ID=11077
Edited by user 11 March 2012 19:16:51(UTC)  | Reason: Not specified
laalves Offline
#2 Posted : 03 October 2008 22:01:15(UTC)
laalves
Luis Alves CS2:
Hardware: 3.1
Software: 1.0.2(1) updated to 1.0.5(3) on 13/10/2008; updated to 1.07(2) on 15/11/2008 updated to 1.0.7.(3) on 17/11/2008; updated to "new" 1.0.7.(3) version on 08/01/2008; updated to 1.3.0.(1); updated to 1.4.0(1); downgraded to 1.3.0.(1) to workaround Issue 19
Issue 1: PC interface is disabled, responds to pings but actively refuses connections Solved, interface is available for Screenshots and online help reading;
Issue 2: Card reader doesn't work Removed, cards must have the chip facing down [xx(]
Issue 3: Update function does not work. Starts by appearing to work and then stops with the message update failed. Update: it worked after a reboot and updated, over the web to 1.0.3 and then 1.0.5.;
Issue 4: It is not possible to change the default gateway IP from 192.168.1.255 to anything else Solved.
Issue 5: Sx socket is disabled and undocumented;
Issue 6: Aux socket is disabled and undocumented;
Issue 7: Sound socket is disabled and undocumented;
Issue 8: The usual F4 icon, the acc/dec delay cancel (triangle) is not available. Locos register with turtle icons, one for F3 the other for F4. It is not available in the list of icons to choose Solved.
Issue 9: When using the virtual keyboard, the lower row of keys is screwed up: it is laterally displaced when lowercase and is actually uppercase, there's no "z" (!!!!!!!!!!); when pressing "b", "V" is the result for example. Solved with update 1.0.7(2)
Issue 10: English version: In loco programming screen, "min delay" and "max delay" actually means "min speed" and "max speed".
Issue 11: I haven't been able to run two of my loks: one has a Loksound 1 and the other is the Brekina Schi-Stra-Bus. They don't run with the CS2, although they ran with the CS1. Solved with 1.0.5
Issue 12: I haven't been able to have the CS "guess" a lok address using that feature Solved, unless using 1.4.0. Works with 1.3.0.;
Issue 13: In the layout feature, it is not possible to create an accessory without an address. In my case, my shadow station has a single address of a K83 controlling two outputs of a relay. One of the outputs controls one switch, the other controls power cuttoff for one track section. This times 10, for 10 track sections. Ideally, I would be able to draw this in the CS with one signal and one switch for each track section, using just one address. In practice with the CS2, I will have to use twice as many address, 10 of them being fakes (and wasted!) and program a route for each track section.
Issue 14: Function mapping is not possible for any type of decoder. There's a greyed out button "Additional settings" in the function settings page, maybe it's a promise of future function mapping options. One of my favourite setting is to modify the headlight settings to "Zoom" in the CS1. This is not possible with the CS2. This is a major downgrade so far Solved with 1.4.0..
Issue 15: As of yet, none of my mfx locomotives registered their function icons correctly. As a rule so far, ALL sound functions are mapped to the standard loudspeaker icon, regardless if I had a whistle, horn or whatever mapped to a given Fx button Solved with 1.3.0..
Issue 16: On 13/10/2008, unattended, exhaled burning smell and died. Returned to dealer on 14/10/2008, out of stock both at the dealer and at Märklin. Solved with a new unit, S/N 3517
Issue 17: New for 1.0.7: cannot change any CVs, not even the address, either by CV or by the address field. Can read all of them, though Issue solved by "new" 1.0.7(3), 08/01/2008
Issue 18: If there are two loks in the list that have the same address, one being an MM and the other a DCC, neither will run correctly (stuttering and flashing lights) even with only one of them present in the track. A similar thing also happens with CS 1 v2.0.4.: two MM loks with the same address will cause stuttering and erratic flashing headlights of both.
Issue 19: After updating to 1.4.0., CV programming for MM2 programmable and DCC profiles does not work. Newer version of 1.4.0., installed on 21/01/2011 corrected this issue
Issue 20: After updating to 1.4.0., function mapping for mfx decoders has been enabled and the mfx CV access has been extensively improved. However, when using the English language UI, these new features are in German and the online help text is outdated and in French. Babylon CS 2.
Edited by user 22 January 2011 01:10:59(UTC)  | Reason: Updated to new issues found in v1.4.0.
Nigel Packer Offline
#3 Posted : 05 October 2008 11:13:05(UTC)
Nigel Packer
Updated 16/02/2009 with version 1.0.5(3)
Nigel Packer's replacement CS2:
Hardware: 3.4
Software: 1.0.2(1) updated to 1.0.5(3).
My issue 0: Can't update from the web site - update attempts to run but gives "not successful" message.
My Issue 1: No support for MM1 function decoders, so cannot use 2681 Kaiser Wilhelm coach lighting, 4999 Waiter car, 4998 Disco car, 49960 Measurement car, etc. 1.0.7(3): Now supported from the loco database, but still no MM1 option on the decoder menu for manually-added locos
My Issue 2: CS2 assumes Decoder=Locomotive, so there's no way of defining a function decoder without the speedometer and all the settings related to running a loco.
My Issue 3: Decoders must be defined as with Dipswitches or "Programmable". If defined as Programmable (which you have to do to set an address above 80), the CS2 insists on trying to program the decoder every time. There needs to be support for "Programmable but already programmed" so that you can use (eg) a 6021 to program the functions. This would of course allow support of other manufacturers' function decoders, but since Märklin doesn't have any programmable function decoders in its range, this would seem a necessary feature.
My Issue 4: No function icons for coaches or trains with interior lighting - I have many of these!
My Issue 5: Programming of a decoder while the CS2 is in "Stop" mode claims to work - but nothing is written to the programming track.
My Issue 6: Keyboard operation of two-motor double slips is not correct, and is not compatible with the CS1. I'm not re-wiring the motors just yet - hoping it will be fixed! Not fixed in 1.0.7(3).
My Issue 7: The loco selection facility starts to get more and more flaky as the number of defined locos increases: sometimes pressing the loco-select button just causes a flash on the screen; sometimes just part of the loco list appears, incorrectly positioned on the screen; sometimes a random (apparently) loco gets selected.
My Issue 8: There's a limit of 72 locos (OK - 90 if you use very short loco names for all your locos)! As more locos are defined, the selection list splits into columns, with a maximum of 18 locos per column, and a maximum of five columns - this fills the screen. If you continue adding locos, they are added to the list, but there's no way of accessing any loco past number 72 or 90 (ordered alphabetically). The control knobs continue to operate the previously-selected locos, and do not allow you to scroll through the list. Likewise, a USB mouse can not scroll the list.
Ratatouille Offline
#4 Posted : 05 October 2008 15:11:15(UTC)
Ratatouille
Hello!
My issues:
1. No functionmapping of mfx-locos[:(]
2. Programming of an mfx-loco which is not available on the track works! (Message: "Programming succesfull") But the changes are only in the cs2, even after replacing the loco on the track.[V]
I´m very sorry for my poor english!
hjmo08 Offline
#5 Posted : 09 October 2008 02:12:49(UTC)
hjmo08
Some additional issues:
1. The CS2 doesn't read the address for delta decoders(locos tested 3456 and 33043). Some problems also with old mxf decoders, probably due to old firmware versions. As an example, for the loco 37141 (mfx decoder), the CS1 reads the factory address correctly and the CS2 reads the same address + 1, i.e. if the address is 30 (correctly read by CS1), the CS2 reads 31.
2. After inserting a loco manually and selecting a 4 dip-switches decoder type, and confirm all the data, when we access for the next time to the 'Configuration locomotive' area for the same loco, the 8 dip-switches type decoder is selected, instead of 4 dip-switches. Only 4 and 8 dip-switches decoders.
3. Some locos have 10 dip-switches decoders (like the 37050) and this type of decoder isn't displayed in the 'Configuration locomotive' area.
4. Impossible to reset the CS2 to factory settings. Only to one of the previous backups.
5. It is not possible to give, previously, a specific name for the backup file.
6. After creating or editing an acessory and selecting a 10 dip-switches decoder type for this acessory, and save all the data, if we access to the properties of the same acessory, the 8 dip-switches decoder type is selected instead of 10 dip-switches.
That's all for now.
 1 user thanked hjmo08 for this useful post.
phc
frankie Offline
#6 Posted : 14 October 2008 13:33:14(UTC)
frankie
Issue 4: It is possible to set it in DHCP mode?
Alessandro
I have a CS1 Reloaded!
nevw Offline
#7 Posted : 28 October 2008 05:24:51(UTC)
Serial Number 1765 . BETA TESTER 1765 but no more
Software 1.02 (1) ow VER 1.0.5(3)
Hardware 3.1
1. Sees the router but starts updating, get pretty red green and Yellow Bars, then a Blue bars. Stop lite went off them Failed to update message.
Have done upteen resets no change.
edit: downloaded the upgrade, unzipped, disconnected the Network cable, inserted the upgrade on a USB stick. Upgrade went through. I think. still running 30 minutes later. DId a restart and upgrade successful Now VER 1.0.5(3
2. will not recognise MFX Locks
edit: on programming track but ok on normal track.
3. loco menu both Left and right pop up for no apparent reason.
3A. Turning say Lights on takes about 3-5 seconds for them to go on or turm off.
edit. turn the speed control, nothing happens for 5 seconds, then train starts moving and gathers speed.
puch, select change direction knob, nothing for 5 secs. then loco starts slowing down and finally stopping
4. Bottom keyboard keys one letter out and I could not find a / key
5. Often Loco selection/menu Key does not work. Need to restart.
6. Cannot load locs and have them work. will not register MFX Locks.
now very very frustrated. very P***ed off. OBvious it has to go back.
probably to a knackers Yard for a peaceful death.
No Function Mapping which is a bore
Nev
Whwn you do a data reset it does not go back to factory setup.
Oh WEll CS 1 Back in action tomorrow
turned off the Cs as per instructions, connected a Network Cable. Turned the power on Nothing Zilth, dead, the smoke escaped
wearing the Pink Pinny, which is hard to see and now an waiting for a new shiny tin Hip
Junior member of the Banana Club, a reformist and an old Goat with a Bad memory
Maxi Offline
#8 Posted : 13 November 2008 13:58:11(UTC)
Maxi
Serial Number 1840
Software VER 1.1.3
Hardware 3.1
1. Network does not respond when unit appears to be ready for use. It would appear that the CS is still loading and initializing parts of the system in the background. The CS will not start responding to the ping command for another 20 seconds or so after the system apears ready for use. Best bet to wait for another minute when the CS apears to be ready for use before all features are fully loaded and ready for use. This may be why the online method of upgrading the software fails most of the time.
pa-pauls Offline
#9 Posted : 13 November 2008 14:33:54(UTC)
pa-pauls
Any problem's that the loco list pops up when using the throttle's confused
Pål Paulsen
Märklin Digital, DB and SBB Era III
nevw Offline
#10 Posted : 13 November 2008 23:37:37(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by pa-pauls
<br />Any problem's that the loco list pops up when using the throttle's confused
Fixable by a trip back to Maerklin for the Cs2.
pa-pauls Offline
#11 Posted : 13 November 2008 23:56:20(UTC)
pa-pauls
I know Nevw as I had to send my back to Märklin because of this but
I have an e-mail saying that a brand new one is on the way to me Smile
So I only wonder if some other had the problem resently...
Pål Paulsen
laalves Offline
#12 Posted : 14 November 2008 00:26:57(UTC)
laalves
I have seen and used one with this problem, my dealer's demo unit. It has a 1600s S/N, like the one I bought and burned.
His unit has another issue, the right hand F5 hard key gets stuck and permanently pressed.
frankie Offline
#13 Posted : 17 November 2008 13:13:23(UTC)
frankie
Has anybody tried to make a consist?
Because we tried during our meeting in Florence http://www.3rotaie.net/forum/topic.asp?TOPIC_ID=3603, but we were unable to load the second loco, no matter what.
We were trying to make a consist out of the two Nohab in the recently released set.
Alessandro
Bigdaddynz Offline
#14 Posted : 09 January 2009 09:45:01(UTC)
<br />So I only wonder if some other had the problem resently...
I think Clapcott's CS2 has this problem. Not sure if Peter has sent it back to Märklin as yet.
pa-pauls Offline
#15 Posted : 09 January 2009 10:28:36(UTC)
pa-pauls
Ooooh, sorry to hear that David [:I]
Tell Clapcott to send it back for replacement or maybe he can get a new one from his seller maybe confused
Pål Paulsen
Bigdaddynz Offline
#16 Posted : 09 January 2009 10:42:14(UTC)
Well PÃ¥l, he did say to me that it would have to go back to the Lokshop for replacement. But given that it would be a 12,000 mile trip for it to go back to Germany from NZ, I don't know if he was in a hurry to send it. We had a MRR exhibition here in late November, and the NZ Marklin dealer was using Peter's CS2 to demonstrate it to people attending the exhibition, since the dealer had not even seen the CS2 at that stage!
plavnostruev Offline
#17 Posted : 18 January 2009 22:47:16(UTC)
plavnostruev
Version 1.0.5
Bottom row of (typing) keyboard acts funny - it selects capitalized letter to the left of the one being pressed, does not seem to be screen calibration issue. I saw this on at least two machines.
nevw Offline
#18 Posted : 19 January 2009 01:20:35(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by plavnostruev
<br />Version 1.0.5
I believe that later updates fixed this problem. ECOS had the same problem when first released.
NN
Charlie Offline
#19 Posted : 20 January 2009 04:29:14(UTC)
Charlie
That is correct, the bottom row of the keyboard is one of the issues that will be fixed with update 1.0.7.
Also expect the DCC option in that release.
steventrain Offline
#20 Posted : 05 February 2009 20:56:59(UTC)
I have a new wireless mouse (with battiers in it) with USB key on CS2 much better now.
No Issue on my CS2 so far.Cool
PS the CS2 was 1.0.7(2) seriel number 1215.
Large Marklinist layout with C-tracks/Central station 2/Mobile station 2/Boosters 60174s/Marklin collector since 1990s/Collector Marklin from the 1950s/Favorites Steam class BR01/BR03/BR05/BR50/Insider Club membership.
sudibarba Offline
#21 Posted : 16 February 2009 04:27:29(UTC)
sudibarba
<br />I have a new wireless mouse (with battiers in it) with USB key on CS2 much better now.
How did you get 1.0.7(2) ?
Eric
sudibarba Offline
#22 Posted : 17 February 2009 00:15:38(UTC)
sudibarba
[size=1" face="Verdana" id="quote]quote:Originally posted by sudibarba
"Mystique"!!! (I'd say by either downloading it from the Märklin server or directly factory installed). biggrin
Well you certainly have me confused. I thought the only available update was 1.0.5 (3). I guess I'm losing my sense of humor.
Eric
john black Offline
#23 Posted : 17 February 2010 16:34:37(UTC)
sudibarba wrote:
hemmerich wrote:
"Mystique"!!! biggrin
Well you certainly have me confused. I guess I'm losing my sense of humor
Don't do this, Eric. It's the only way to stand his mumbo-jumbo
laalves Offline
#24 Posted : 31 December 2010 14:42:29(UTC)
laalves
Updated list of issues with 1.4.0(1)
NZMarklinist Offline
#25 Posted : 22 March 2011 04:02:46(UTC)
NZMarklinist
No problem with consists on CS1-R Alessandro Confused BigGrin
Glen
Auckland NZ
RUBEN SPAIN Offline
#26 Posted : 19 December 2011 17:06:20(UTC)
RUBEN SPAIN
Hello
I have a 60214 Hw 4.33 Sw: 2.0.1 S/n 19655
This CS2 is from a Mega Starset. It came with 1.6.4 sw.
Problems with DCC:
Since I updated (by Internet connection) to 2.0.1 I can´t read parameters of DCC decoders neither address in the main menu.
When I make changes in some parameters(like vmax, brake delay...) into the main menu for locomotive config, the parameters are not transfered to locomotive. In some moments, when I try to read the decoder the CS 2 shows a overload message.
I can only read and write parameters into the CV menu.
My DCC decoders are ESU lokpilot V3 and Loksound V3.5.
Mfx decoders works perfectly and the reading of parameters is very fast. The function mapping works properly to mfx decoders but function mapping is not there to DCC decoders.
Some News:
Yesterday I was working with several locomotives. I used some pieces with Uhlenbrock 76320 (DCC / motorola) decoder working in DCC mode. With Uhlenbrock decoder CS 2 works right.
The problem was only with all my ESU lokpilot V3 and Loksound V3.5 decoders. Someone knows why?
I don´t know whats the matter with V4 because I don´t have this model of decoder.
And I don´t know whats the matter with other brands (like Lenz or cT Electronik) because I only have ESU and Uhlenbrock decoders.
Rubén.
Languages: If I change language to Spanish help menus are in french and too much operation messages from CS2 are in dutch or german.
Edited by user 20 December 2011 08:57:45(UTC)  | Reason: Not specified
Nilkram Offline
#27 Posted : 19 February 2012 16:27:58(UTC)
Nilkram
Dear Märklin users,
I have a problem!
Today I updated my CS2 to version 2.0.1 by means of an USB stick. The update was succesfull, so said the CS2. After I had started up again it appeared that all my signals and points were not anymore switched on when a train touched a contact track (ground detection). My complete block system and full automatic entry of the shadow station, nothing did it! Not one signal turned red when a train passed and not a point was set to the right empty track in the shadow station. I have sent an e-mail to the Märklin helpdesk in which I describe the problem and hope to get an answer soon. I think it has something to do with the new drivers for the S88. I use S88 article number 6088, some 15 tot 20 years old and also the K83 and K84 of the same age. Under version 1.6.4 everything worked perfect.
Any one of you Märklin users had the same experience?
Kind regards
Jan
charles Sharpe Offline
#28 Posted : 19 February 2012 16:57:45(UTC)
charles Sharpe
Hello.
Yes I have. I can do a update by USB or bring CS2 down to the house and connect it to the internet and do it that way. I loose most of my signals and some times I get 2 signals take the same address. We did a back up the a rest then added the new update. We had to do that 4 times then all ok.
Charles.
CHARLES SHARPE
sampiero Offline
#29 Posted : 10 January 2013 20:42:55(UTC)
sampiero
Hello every body,
My CS 60214 cannot be updated. A message of failire appears each time I try to do it.
Also, I have a 26549 Br 38 DB. All the sounds are working fine but the brakes are mute when stopping even when the icon is on.
I came back then to my testing unit with 6021. The brakes are not sounding too. I thought F5 was permently activated with 6021. Indeed, all the other sounds are working fine.
No problem with 37033 Serie 64 SNCB.
if somebody could help... Thanks and happy new year to all,of the site members.
H0 Offline
#30 Posted : 10 January 2013 21:41:59(UTC)
When the icon is on, brake sound is off. Make sure operating sounds are on. You may have to increase the "hardware" braking delay of the decoder (on the CV screens) and/or reduce the "software" braking delay of the CS2 (before you enter the CV area).
Suaviter in modo, fortiter in re
This page was generated in 1.749 seconds.
Map
See the web site statistics
Bookmark and Share
