Offline morsing
#1 Posted : 05 May 2015 22:23:10(UTC)
morsing
I serviced my Roco MZ 1414 but now it runs with red lights at the front and white at the back!? This confuses me as I don't recall any plug-in wires...?
What have I done?
Another question, I really want to fit a little driver and possibly lighting in the cab, but can't figure out how to get the cab out? I think I need to take all the outide bits off, but how do I release the cab insert without breaking anything?
Marklin C-track + CS3+
#2 Posted : 05 May 2015 23:02:57(UTC)
Originally Posted by: morsing Go to Quoted Post
What have I done?
When this happens with Z gauge locos, then the motor was installed the wrong way around.
How thoroughly did you service it? Did you take the motor out?
Offline rorosha
#3 Posted : 06 May 2015 01:17:48(UTC)
rorosha
What have I done?
Didn't know Roco made any Z gauge Locos.
#4 Posted : 06 May 2015 05:29:20(UTC)
Tom refers to Maerklin Z scale, which like Roco HO is 2 rail DC. If the motor was removed and reinstalled with the + and - connections inverted, it would work in the opposite direction.
Offline morsing
#5 Posted : 06 May 2015 07:40:19(UTC)
morsing
The motor can't be put in wrong, I'm pretty sure, as the tabs from the print board can only touch one end of the motor. Unless I put both the motor and print board in wrong...
I'll have to take it apart again, I suppose. I can't really remember the wiring for the lighting, so I suppose I could have got that wrong.
#6 Posted : 06 May 2015 07:47:26(UTC)
This can happen with symmetric plug-in motors of any gauge.
#7 Posted : 06 May 2015 10:28:13(UTC)
the motor can only be put in one direction and can not be switched over, you are right there, but the motor can be turned upside down.
Offline morsing
#8 Posted : 06 May 2015 15:22:03(UTC)
morsing
Ah, of course, I will look in to that this weekend :-) Thanks
Offline morsing
#9 Posted : 30 May 2015 23:43:01(UTC)
morsing
Thanks, I finally found the time to take it apart again, and yes, the motor was upside down :-)
#10 Posted : 31 May 2015 06:51:48(UTC)
Thanks for the feedback.
The motor can't be put in wrong [...]
This page was generated in 0.553 seconds.
