Offline db ice3
#1 Posted : 11 February 2015 11:43:33(UTC)
db ice3
this is a silly question i know,
i keep my rails clean - but being new to marklin - what about the centre studs? i use c-track. do the centre studs need to be wiped / cleaned or maintained in some way?
many thanks and sorry for the silly q!
Edited by moderator 22 March 2016 11:27:54(UTC)  | Reason: Topic titles should always start with a capital!
Offline amartinezv
#2 Posted : 11 February 2015 12:03:28(UTC)
amartinezv
There's not silly questions, the only silly question is that has not been formulated... BigGrin
Now to question... the best way to keep the pukos (centre studs) clean is to run the trains very often, every day if possible. But if the pukos get dirty use isopropylic alcohol or a cleaner for electrical devices, like Kontak 60. Never use abrasive metods.
Antonio Martínez
www.raildigital.es/davidruso
thanks 1 user liked this useful post by amartinezv
Offline db ice3
#3 Posted : 11 February 2015 18:25:27(UTC)
db ice3
thanks amartinezv for the info about the studs!
just what i needed to know!
i wonder what folks think of or has anyone used the Lux track cleaning wagon?
its kinda pricey but if it worked?
lux track cleaner
Offline LeoArietis
#4 Posted : 11 February 2015 21:16:02(UTC)
LeoArietis
I place "Noch 60157" on various wagons to keep the tracks clean. Works great.
About the centerstuds, you just have to run trains, and of course keep all greasing down to a minimum to prevent dirt accumulating. Also helps to keep the room for your model rail-road tidy.
Current layout:
The former project:
thanks 1 user liked this useful post by LeoArietis
#5 Posted : 11 February 2015 23:42:54(UTC)
As Leo has said, regular running of trains is usually all you need, and his Noch solution (a little hanger from one axle) is ideal.
You buy them in packets of 4, and I fit them to each of my Pwg gepackwagens.
However, if I do not run trains for 3 weeks, I find the centre pukos in a few spots, develop a mild insulation or oxidation, and trains will halt or hesitate.
This only occurs in a few places, and always the same places.
It may have something to do with quality of the metal in pukos.
Each doubtful section is only an inch or two, and in 40 metres of track, limited to about 6 places.
I use VERY fine sandpaper (at least 1200 grit) which you can get from a hobby store.
It is so fine it is like a polishing action, and does not hurt the pukos.
It cleans the spot up for running in no time.
Offline Token
#6 Posted : 12 February 2015 08:06:23(UTC)
Token
Thanks for the added advice Kimball - I confess in my past I have used track cleaning blocks on the pukos to an extent that the paint had worn off (which is not good from a presentation perspective) but I wasn't aware of the potential damage.
I have also used a product obtained from my local hobby store but detailed in this link;
http://www.modeltrainstu...-Cleaner-p/clp-60031.htm
The version I have was built into a Marklin 4 axle chassis (probably an older caboose or something of that nature). A post of mine from some time ago has the pictures where I went overboard and created a track maintenance train which appeared to work well with two Marklin cleaning wagons 46042, one noch brush below my repair facility car 45072 in addition to the converted wagon mentioned above;
Maintenance Train
Forgive the poor image quality. The train was a little overboard but sounded great with two 86's loaded with sound (thank you Norm)!
I would run this a couple of times around the layout before I ran the good stuff LOL
https://www.marklin-user...ning-Car.aspx#post328760
Michael.
thanks 3 users liked this useful post by Token
Offline madhu.gn.71
#7 Posted : 12 February 2015 08:26:16(UTC)
madhu.gn.71
India
If you are a DIY kind of a person, you could try this... All you need extra is a pickup shoe. Other members can comment on how effective this method could be.
Disclaimer: I have not tried it and this is a result of my old youtube search:)
thanks 7 users liked this useful post by madhu.gn.71
Offline Token
#8 Posted : 12 February 2015 08:37:16(UTC)
Token
Great idea Madhu - thanks for sharing. I wonder if we would be better to use isopropyl rather than oil?
Any thoughts from anyone?
Michael.
Offline db ice3
#9 Posted : 12 February 2015 12:54:25(UTC)
db ice3
hey madhu! - thankyou so much for that great little video - i thoroughly enjoyed watching it - especially in the beginning wondering what was going on with the paper! - its really great!
i might try this simple method - much better than paying 150euros for a Lux track cleaning car!.
thanks 1 user liked this useful post by db ice3
Marklin HO 46049 Track Cleaning Car 3-Rail (General MRR)
by mjborelli 19/02/2023 23:19:59(UTC)
Track cleaning machine (Big scale)
by nygma 21/05/2019 19:01:28(UTC)
Science of track cleaning (General MRR)
by Danlake 19/05/2019 09:26:10(UTC)
Track cleaning car comparison - Lux vs Dapol (H0-scale)
by Minok 10/03/2019 22:46:06(UTC)
LUX Track Cleaning Car 9130 (Reviews of rolling stock)
by PMPeter 13/12/2018 22:34:32(UTC)
Track cleaning (z scale) (Small scale)
by Trainiac 23/06/2018 15:39:07(UTC)
Track Cleaning (H0-scale)
by Kapalua 29/10/2017 09:15:00(UTC)
Marklin Track Cleaning Car (Small scale)
by BillO 02/11/2016 03:05:17(UTC)
Track Cleaning Car (H0-scale)
by Jabez 12/09/2016 23:23:57(UTC)
Track cleaning (General MRR)
by Varun R 24/05/2015 06:16:24(UTC)
Marklin German Track Cleaning Car of the DB (H0-scale)
by baggio 28/03/2015 18:08:24(UTC)
Märklin 46010 Track Cleaning Wagon (General MRR)
by Shamu 27/08/2014 12:15:50(UTC)
M-Track Cleaning (H0-scale)
by Makistrain 21/01/2014 23:13:12(UTC)
Track Cleaning Idea- is it pratical? (H0-scale)
by Harvey 15/10/2013 03:23:58(UTC)
Advice on Track Cleaning Product (H0-scale)
by Mike M 07/09/2013 23:25:39(UTC)
Track cleaning - Chemicals and metods (General MRR)
by Martin T 09/07/2013 09:39:24(UTC)
Can anyone identify this track cleaning car? (General MRR)
by kc6uvm_George 21/11/2012 20:33:27(UTC)
Cleaning Track Pads on 46042 Track Cleaning Car (General MRR)
by petestra 20/03/2012 16:16:37(UTC)
by swanpondwv 19/12/2011 01:53:43(UTC)
Track cleaning (Small scale)
by Jon11 25/08/2011 00:33:25(UTC)
HO track cleaning pads (H0-scale)
by Tex 11/08/2011 04:32:19(UTC)
ANY GOOD Z SCALE TRACK CLEANING CARS (Small scale)
by darticus 09/12/2010 02:18:44(UTC)
Track Cleaning Cars (H0-scale)
by Ranjit 21/10/2009 22:50:07(UTC)
Home madeTrack Cleaning Car (General MRR)
by FMS 31/05/2009 00:08:21(UTC)
Track cleaning cars (Small scale)
by ozzman 17/12/2008 01:21:51(UTC)
What track cleaning car would you suggest? (H0-scale)
by Eisenhower 10/11/2008 23:18:49(UTC)
Pulling Power for track cleaning (H0-scale)
by Martin T 03/09/2007 18:07:14(UTC)
C-Track Cleaning (including roadbed) (H0-scale)
by pmgsr 29/06/2007 17:09:50(UTC)
Track Cleaning (General MRR)
by bobhunt 07/02/2007 10:53:25(UTC)
Track cleaning... (General MRR)
by shaygetz 22/12/2006 05:38:02(UTC)
46042 Track Cleaning Car (H0-scale)
by MHauge 30/11/2005 08:09:17(UTC)
Track cleaning car (H0-scale)
by Winst0n 27/01/2004 17:17:35(UTC)
Track cleaning cars (H0-scale)
by PeFu 26/09/2003 12:09:42(UTC)
K + M HO Track Cleaning (H0-scale)
by Ranjit 24/06/2003 00:14:26(UTC)
by capn_tinkydink 26/01/2002 04:01:08(UTC)
This page was generated in 0.587 seconds.
