Offline stlcards54
#1 Posted : 07 February 2015 20:43:04(UTC)
stlcards54
Hi, I'm going digital with the ms2. The ms2 control my trains fine. Now I'm hooking up my old m track switches using my old blue transformer. The switches work fine but the light in the switch doesn't light up. I know it's because there is no brown return from the track.
My question is, is it safe to hook up the blue transformer ground brown wire to the track at the same time with the ms2 brown wire attached. I don't want to fry anything.BigGrin
Offline rrf
#2 Posted : 08 February 2015 13:37:08(UTC)
rrf
Whenever I use multiple transformers (digital and/or analog), I always create a common ground with the brown terminals. On my last "Tisch Bahn" layout, I had the brown from my MS2 connected to the brown from a transformerswhich was providing power for lighting.
One additional thought (which hopefully others will comment upon):
I was persuaded by folks on the forum to stop using my old Blue transformers and replace them with new ones. Apparently the older transformers start to have voltage tolerance problems that can damage some of the digital electronics on the newer locomotives. For lighting purposes only I believe you should be fine, though technically I must state that I have never used an old Blue transformer with a modern Märklin digital controller.
Rob
Mackenrode Wende Bahn
thanks 1 user liked this useful post by rrf
#3 Posted : 08 February 2015 18:23:26(UTC)
That is mainly an issue with the reversing voltage.
Another problem (with very old transformers) is mains voltage at the transformer case (brittle insulation).
With respect to light bulbs: increasing the voltage by 5% reduces the lifetime by half. A new transformer with a lower output voltage will save you some light bulb money (for countries that switched from 220 V to 230 V or from 110 V to 120 V).
Shouldn't make a difference if you replace the light bulbs with LEDs.
This page was generated in 0.440 seconds.
