6 Pages123>»
#1 Posted : 15 September 2013 00:49:09(UTC)
Good evening,
Moving houses again soon... And Slumburg-Alltoofar will probably not make it into the new home. Probable scenario is an available surface of 183 x 105 cm in laundry room. Thus, I began brainstorming. Construction will be "foam-based". The result is a tri-level amalgamation of all past layouts I built over the past 10 years. Since this is difficult to digest from a single drawing, I attach two separate plans: once for lower levels 0 and 1 plus once for upper level 2 - see screenshots.
Cheers - Ak Blink
Edited by user 21 June 2014 01:01:43(UTC)  | Reason: Not specified
Offline seatrains
#2 Posted : 15 September 2013 19:27:26(UTC)
seatrains
AK, I will miss Slumburg. You have done a great job working in a small space. Will it be attacked by rockets like Dummtor? BigGrin
Thom
thanks 1 user liked this useful post by seatrains
#3 Posted : 15 September 2013 22:52:22(UTC)
Maybe a comet shower or raining rocks this time ... Crying
Offline petestra
#4 Posted : 15 September 2013 23:10:31(UTC)
Looks like a-lot of fun in a tight space, AK. I'm sure you'll have lots of fun building
this layout. Cheers,Peter ThumpUp Smile
Offline BrandonVA
#5 Posted : 16 September 2013 15:50:48(UTC)
BrandonVA
You certainly have a gift for fitting the maximum amount of excitement and features in the smallest space. I am fascinated by this style of layout building. I look forward to this new version....I hope your move goes well!
-Brandon
#6 Posted : 29 December 2013 19:57:36(UTC)
Hi there,
And now for something completely different.
On the occasion of the 50th anniversary of the opening of the Fehmarn Sound Bridge in Northern Germany and inspired by the outcome of the prototype post "Is this prototypical?" (https://www.marklin-users.net/forum/yaf_postst28881findunread_Is-this-prototypical.aspx#post433921) as well as by lessons learned by the construction of the small "Thunder Mountain" layout, I got another layout idea. The Fehmarn Sound Bridge is part of the Vogelfluglinie (German) or Fugleflugtslinjen (Danish) - literally: bird flight line - transport corridor between Copenhagen,Denmark, and Hamburg, Germany, which is a non-electrified single track mainline North of Lübeck. The core of the connection is the 19-kilometre (12 mi) combined car and train ferry link between Denmark and Germany. This sounds promising, does it not?
Please allow me to focus on international passenger trains on the German side. Before the opening of the bridge, an international train ferry service linked Grossenbrode quay on the German mainland with Denmark. E.g. the ferry "Danmark" had only a single track holding up to four coaches. Later ferries had three tracks which could hold three times four coaches. Thus, longer trains had to be broken up. During the 1950ies/1960ies, BR 50 and BR 03 steamers pulled a mix of national and international trains. After the construction of the bridge, the ferry called the new port of Puttgarden on the island of Fehmarn instead. Subsequently, DB class 221 diesels prevailed. The following international passenger rains were operated in the summer of 1965 (http://www.bahnen-im-norden.de/jalbum/vogelflug.html#Reisezug):
Nord-West-Express, Hoek van Holland - København (through coaches to/from Amsterdam, Oostende, Stockholm)
Paris-Skandinavien-Express Paris - København ((through coaches to/from Stockholm)
København-Express Hamburg - København
München-Express München - København (through coaches to/from Wien/Vienna)
Alpen-Express Roma - Brenner - København (through coaches to/from Venezia)
Nord-Express Paris - København
Schweiz-Express Basel - København (through coaches to/from Milano, Roma, Chur)
Italia-Express Roma - Gotthard - København (through coaches to/from Ventimiglia, Wien/Vienna)
Holland-Skandinavien-Express Hoek van Holland - København
Hamburg-Express Hamburg - København
Wiking-Express Hamburg - Hässleholm
Hispania-Express Port Bou/Cerbere - Genève - København
D289/290 Garmisch-Partenkirchen - København
As demonstrated in above mentioned prototype post, in 1978 there were short two-coach IC trains pulled by a DSB NOHAB and a DB class 221, respectively, as well as pure French SNCF trains pulled by Danish and German diesels, respectively.
Nowadays, regular passenger service (no more freight traffic) is offered by DB four car ICE TD high-speed DMU (formerly served by DSB IC3 units) boarding the ferry, while DB twin-car commuter service DMUs and seasonal double traction DB class 218 IC trains terminate at the German ferry port.
In a nutshell: big steamers, large red diesels, international mix of coaches, mostly short trains, single track main line without overhead wire, flat green landscape. Say no more, say no more, say no more: This is the ideal excuse for my below - surprise, surprise - compact layout and operations concept.
Now, the basic layout idea is to have a quayside scene with a mock-up train ferry in the background of a quay, which serves as a fiddle yard for a short international train. To the left the ferry port is linked to the single-track mainline - set in a green flat landscape, which has a gently swinging large radius curve. Northbound express trains arriving via the - fictional - lower wye track (which the former Grossenbrode ferry port on the mainland actually had), and the loco backs the train onto the ferry; subsequently, the loco uncouples and drives to the quay. Once the ferry "returns" from Denmark, the reverse operation is carried out for the southbound train, which eventually disappears for its long trip via the - fictional - upper wye leg. The front sidings are for a commuter train or serves as layover track for freight cars. When riding the mainline, the hidden loop extends travel time and allows to conceals the train, adding a level of realism and avoiding the train to chase its own tail. Trains can be short and colorful: Anything goes on 180 cm x 90 / 40 cm - see attached track plan !
Cheers - Ak
P.S.: To be continued / elaborated...
#7 Posted : 29 December 2013 21:46:31(UTC)
Hi there,
Here comes phase 2:
In the tunnel, which is representing the large outside world, two short sidings are added. One for a German loco and one for a Danish loco. While the German consist is circling, the Danish loco, e.g. a DSB NOHAB is hiding on tunnel siding 1. The German loco, e.g. a DB V200, backs the train onto the ferry and disappears in the tunnel and is parked on tunnel siding 2. Now we pretend that the ferry arrived in Denmark. The NOHAB appears outside and pulls the train from the ferry. After some time the Danish train returns from Copenhagen, backs the train onto the ferry, and goes into hiding again. The ferry reaches Germany, the V200 re-appears to pick up the train etc etc.
Cheers - Ak
Offline Yumgui
#8 Posted : 29 December 2013 21:49:01(UTC)
Yumgui
Man, this compact C-track stuff + semi-prototypical overlay is quite dense ... I've even lost count of the number of layouts you are working on atm ...
I'm sure the kids get it faster than I do ... ;)
Only photos and further documentation will allow me to wrap this new concept around my feeble head ^^ !
Go for it,
Y ThumpUp
PS: "Now we pretend that the ferry arrived in Denmark..." <-- LOL
thanks 2 users liked this useful post by Yumgui
#9 Posted : 30 December 2013 00:00:16(UTC)
Howdy y`awl,
I found a historic Wikimedia Commons photo showing the single track train ferry "Danmark" in the Danish port of Gedser - see attached. The vessel is docked so tightly in the basin that for the sake of realism it is not necessary to model a depressed port basin. This makes the job even easier - and less depressing (pun intended). And it should ease the pain for some people with photographic memory to follow the thread.
Gr. - Ak LOL
#10 Posted : 30 December 2013 09:32:41(UTC)
Hi there,
Here comes phase 3 - see track plan:
It seems as if the bending widely accepted concepts of space and time is too overwhelming. So, let us keep the location in one country. RollEyes
By inflating the measures of the loop module to 100 x 140 cm:
(1) A modest fiddle yard could be installed in the tunnel; each siding could hold one loco plus four 27 cm coaches, allowing to have meets in the tunnel or even simulate loads in / empties out freight operations;
(2) a outer "ring siding" could be added, giving more operational potential.
(3) By stretching the ferry port leg from 40 x 60 cm to 40 x 145 cm, longer trains could be run and a real wye could be built, allowing to turn steamers and sending trains into both directions. In general, the layout would obtain a more grown-up appeal (at the cost of space though).
Cheers - Ak Smile
P.P.S.: I added a photo of the steamer "Danmark" (single-track train ferry) for the ones requiring a visual stimulus.Laugh
Offline utkan
#11 Posted : 30 December 2013 10:29:58(UTC)
utkan
Turkey
Minimum Space vs. Maximum Fun
....it suits the layout 100 %.....BigGrin ThumpUp ThumpUp
Happy New Year, Ak.....Smile
mehmet
#12 Posted : 30 December 2013 12:03:39(UTC)
Good morning - phase 4:
A decent and self-respecting man can never have enough sidings. By slightly enlarging the ferry port leg to 50 x 145 cm and by replacing a normal by a three-way layout a couple of sidings can be added. Good use could be made of the outer loop siding as switching lead - see track plan.
Cheers - Ak
P.S.: I add another visual stimulus - see historic Wikimedia Commons photo of DMU leaving a more modern ferry in Grossenbrode.
Edited by user 30 December 2013 19:41:19(UTC)  | Reason: Not specified
#13 Posted : 30 December 2013 23:54:06(UTC)
Hi there,
Here comes phase 5 - split the train, double the fun:
By inflating the loop module a little bit in lower right hand side and adding 10 cm to the front of the ferry port leg, a double slip switch could be added in front of the ferry access bridge, thus allowing to have a double-track "mock-up" ferry. Further, adding a switch plus siding here and there would add versatility - see attached track plan.
Some photos of the pre-bridge period: http://www.burg-fehmarn....ssenbrode---gedser.html: Photo #11 shows a larger ferry with two train heads (actually having three tracks with the middle track being concealed by the the trains). On photo 10 the three tracks are clearly visible.
Cheers - Ak
P.S.: Now I really ran out of ideas.
P.P.S.: Another source of inspiration in this context - A small layout project with a working small train ferry based on a very large turntable, much like a kitchen Lazy Susan: "The basic idea is a half round (180 degree) movement for the ferry with the water surface painted on an 80cm diameter disc to which the ferry is fastened. Half of the disc is always under the layout surface, and the edges of the stream are camouflaged with scenery." http://www.carendt.com/scrapbook/page80/
#14 Posted : 30 December 2013 23:59:33(UTC)
Oh yes, and some bonus photos from Wikimedia Commons of single-track train ferries in the past and today.
Happy New Year - Ak
Offline LeoArietis
#15 Posted : 01 January 2014 14:54:43(UTC)
LeoArietis
Hi there,
Cheers - Ak
I really like that track-plan!
Current layout:
The former project:
thanks 1 user liked this useful post by LeoArietis
#16 Posted : 02 January 2014 14:39:08(UTC)
Good day,
Food for thought on 130x180 cm for out-of-the box thinking by another mind, or how flexible C track can be - see link:
http://imageshack.us/pho...s/195/cplan130180tx.jpg/
Cheers - Ak
#17 Posted : 03 January 2014 16:28:40(UTC)
Good afternoon,
A perfect prototypical excuse for having mixed epochs and/or even continents represented on a small pike could be a railroad museum. Several US railroad museums are having a circuit of track for running trains in a continuous manner - aerial views:
- National Railroad Museum, Green Bay, Wisconsin:
http://www.bing.com/maps...e=15775236&encType=1
- Nevada State Railroad Museum, Carson City, Nevada:
http://www.bing.com/maps...ne=8836121&encType=1
- Colorado Railroad Museum, Golden, Colorado:
For C-track, this could be translated into the attached 35/95 x 175 cm (C-)track plan. For quick set-up a "flat mine" could serve well: either an electric M-track or a manual KIBRI turntable (the latter to be equipped with K-track).
A further, example is the mixed M- and C-track layout of a German gentleman: Starting point was a 120x120 cm C-track test circle which was subsequently equipped with a M-track turntable in the middle ( http://www.stummiforum.d...pic.php?f=64&t=84854 ) and grew slightly by two outer sidings and got a large backdrop ( http://www.stummiforum.d...amp;t=84854&start=25 ). The result allows for the display of a loco collection and the occasional running of trains, as well as for nice photographing: From the inside of the curve even coaches look nice.
Greetz - Ak BigGrin
#18 Posted : 27 February 2014 10:58:50(UTC)
After a lot of theory, the example of two "circular" layouts (I) really built, the single level 2006-7 Foursquare Circles (95 x 95 cm) and the tri-level 2013-? Thunder Mountain (100 x 128 cm) - see pic.
#19 Posted : 30 March 2014 13:09:25(UTC)
I found a recent German 120 x 220 cm interpretation for Maerklin track of an older U.S. design for a compact 4 x 8 ft urban layout for passenger and freight operations which requires access from the front and the rear. While the U.S. approach was for a "flattop" with a town on the center divider, the German is a bi-level one with an industrial area on the center divider. In both cases the front is dominated by a big city terminal for long distance and commuter passenger trains, while the back is centered about local industry tracks and a suburban passenger station. I would change the direction of the main station layover tracks to allow for commuting back and forth between front main station and back suburban station stub tracks, and I would optimize turnout positions to extend track lengths. It is not clear what the intention is regarding the right side. To be connected to close the oval? Connection to a hidden lower basement level with a shadow station or or even return loops to change the direction of trains?
Anyway, even with the flattop approach the layout has a big operating potential. Freight trains could originate on the elevated area, circle around once and end in the industrial are next to the suburban station and vice versa. Commuter trains could shuttle between suburban and main station stub tracks. Long distance passenger trains (e.g., a "double-headed" ICE) could leave the main station, zoom without stopping through the suburban station, stop and change direction in the far hidden curved tunnel, respectively, and return from the distant destination in order to terminate the journey in the main station. Or one could just play and let trains circle.
Offline BrandonVA
#20 Posted : 04 April 2014 18:20:50(UTC)
BrandonVA
I love dense layouts with lots of station, siding and yard opportunities. I think using reverse/return loops at either end would make for more interesting operations, although also more complicated construction. A fiddle siding (or shadow station) could be incorporated on the reverse and return loops, accessed through the illustrated trap doors that would allow different trains to come and go. The upper(?) reverse loop (on the inside/right side) would potentially be the limiter for overall train length. However, based on the station and siding sizes, this would lend itself to operation of shorter consists IMHO. If it were to be US based I would try to extend this to a maximum to run longer trains.
-Brandon
#21 Posted : 22 April 2014 00:15:19(UTC)
Brainstorming on 105 x 180 cm. Bi-level folded dogbone. Red = visible upper level and ramps), blue = hidden lower level.
#22 Posted : 27 April 2014 19:53:57(UTC)
I cannot get this concept out of my head. For a long time I am planning to incorporate it, and maybe I will do so once I have to retouch or rebuild a layout for any reason. It is a space saving idea to combine long layover tracks with a "dog bone end blob". The mainline swinging over the stub tracks will obscure the ends of the latter, thus giving the illusion of more depth. There are R9 easements at the beginning of visible curves and R1 curves are almost entirely hidden; ruling grade is three percent. Sticking to the limits of a 100 x 180 cm baseboard, the two inner stub tracks can hold five to six US streamliner coaches or nine to ten US 50 ft box cars. Outer stub tracks are for engines and cabooses. Increasing the baseboard dimensions by five centimeters would allow to add another stub track. When working the stub tracks, the outer mainline track serves as switching lead. In that case of an oncoming train circling on the mainline, it would be switched to the inner track, thus returning on its own path (see plan 1). Eventually, the train would need to return to the outer track at the top of the grade.
(One option is shown in plan 2, which proposes the second "dog bone end blob" on top of the lower one, thus closing the circle; the latter is not satisfactory enough for me, since I prefer a longer mainline run, but the option reflects the intended operation concept.)
Unsure Wink RollEyes
Offline BrandonVA
#23 Posted : 29 April 2014 20:29:15(UTC)
BrandonVA
Be careful, if I had a bit more C track I may give it a shot :P
Offline Irish Rail
#24 Posted : 30 April 2014 10:20:05(UTC)
Irish Rail
Ireland
Have been watching your ideas with interest as I have exactly this problem - how to fit an "interesting" layout into a confined area. In my case max is 2.4m*1.2m (slightly larger than your ideas here).
The latest version looks interesting, but one thing confuses me - the two red arrows point to "hidden reverse loop" but the tracks seem to end. Are you suggesting that they be connected by another loop? There doesn't seem to be sufficient height clearance on the at the arrow on the left. Or maybe I have misunderstood.
thanks 1 user liked this useful post by Irish Rail
#25 Posted : 30 April 2014 12:47:27(UTC)
Thank you for the flowers.
Indeed I am suggesting to connect the "loose ends" to another loop. I do have a "full" track plan reflecting that, but did not post it since it looks confusing with the overlaying layers (one blob above the other). There should be enough clearance between the layers, namely a minimum of 7.5 cm for diesel and steam operations. Of course the spots where one track dives under another are crucial and critical. Layout construction experience proved that this manageable. In the worst case, one track with a larger slope has to be designated for descending trains only, while the other one with a lower grade is reserved for ascending trains. In any case the grade on the outer "R3" curve is below 4%. The concept is meant for right hand traffic. So, for left hand traffic the layout needs to be mirrored. The stub track in the middle of the upper blob is optional. It might be used to pretend the throat of an urban station; when extended under the "city", it will be long enough to hold three coaches.
I attach an embellished track plan which might clarify.
#26 Posted : 08 June 2014 21:03:36(UTC)
Something new for the archive. I recall a quote of a German railroad employee cum model railroader who - when asked what layout design he favors after all those year on the real thing - stated anything with long runs without any turnout. Now, I spent the better part of the day for a feasibility study of what a MRR aficincado with space limitations can expect on a L-shaped surface of 190 x 190 x 110 cm in this regard. This is meant for the individual who wants to see train(s) running. There is hardly any space for sidings. However - and I deem this to be spectacular and impossible to top - it is possible to squeeze 30 m of main line into this concept. The approach is a twisted dogbone on four (!) levels with at least R2 radius curves in visible areas (with one exception where the viewer looks from below into the inside of short stretch of a R1 radius curve) with easements and a two track shadow station in the lower balloon. It is intended to minimize track hidden in tunnels. Therefore, parts of the reverse balloons are left in the open where socially acceptable. The design of the shadow station can be improved (e.g., track length). Again, this is meant to be a feasibility study to test the limits... Let us start with the confusing view of all levels - see pic.
#27 Posted : 08 June 2014 21:05:48(UTC)
Here are the lower levels 1 and 2.
#28 Posted : 08 June 2014 21:07:27(UTC)
And here the upper levels 3 and 4.
#29 Posted : 08 June 2014 21:09:34(UTC)
And finally the embellished version showing visible areas only. Note that the ruling grade never exceeds 3% and that - as usual - the M* C track geometry is "ignored" for the sake of aesthetics.
#30 Posted : 16 June 2014 00:13:45(UTC)
I reworked the latter approach based on:
- my desire to transform the shadow station into a visible station area serving as parking zone for trains;
- the fact that the local hardware store has 100 x 200 cm foam boards in stock which I could "sandwich" into a 200 x 200 cm baseboard, from which a square is to be cut out in order to obtain an L-shaped base.
Here is a pic of the carnival of the worms.
Blue = lower levels 1 and 2
Red = upper levels 3 and 4
#31 Posted : 16 June 2014 00:16:34(UTC)
Lower levels 1 and 2. Red = crossing of level 2 above level 1.
#32 Posted : 16 June 2014 00:23:01(UTC)
The urban station area and the monumental landscape are to be separated by a high scenic divider screen. On the station area it would serve as backdrop for urban canyons and on the landscape side for "real" canyons or badlands. When working either side, the respective other side is out of side. This requires to have access to the layout from three sides though.
On the side of the city, the elevated urban building flats behind the free standing station building - which again is sitting above the passenger station platforms - need to be high enough to hide the curve tunnel leading from level 2 to level 3 on the badlands side. Station tracks 5 and 6 are situated under tall warehouses or office building leaning against the scenic divider. On the badlands side, a creek separates the tracks on level 1 on the right side and level 2 on the level side. Tunnels are covered by eroded hills with sparse vegetation. Starting at 2 cm in the middle of the layout, the mainline gains altitude via the partly tunneled loop on the right bank of the creek before crossing its own path an following the left bank of the creek; then, follows a tunnel (which is actually under the city) before reappearing over the creek gap in order to cross the level 2 tracks at and disappearing again on the right bank; after another 180 degrees turn, a tall bridge at the end of the tunnel leads above the valley until at an altitude of 26 cm above the creek level (or 24 cm above level 1), the top tunnel on the left bank marks the summit of "Rotten Pass" on the "Fanta Se" mainline. From the station to the summit it is a 15 m run, thus a 30 m round trip. Because of the stretched grades, the ruling grade is kept around 2.5 percent.
See embellished track plan showing visible tracks and envisaged scenicking.
#33 Posted : 16 June 2014 00:28:46(UTC)
Oh yes, and the upper levels 3 and 4, too.
Red = level 4 crossing above level 3
#34 Posted : 16 June 2014 23:00:34(UTC)
And now in 3D!RollEyes
I built a 1/10 scale model of the layout trackage (thus 1/870 so to speak).
#35 Posted : 21 June 2014 01:01:02(UTC)
Another iteration of the lower level, improving appearance and functionality of the return loops. Yes, there are actually two balloons on the lower level linking Union Station to three destinations: two on the same level and Rotten Pass at the long end on level 4. The narrowed track distances require careful track laying of the shadow station area curves...
RollEyes
Edited by user 21 June 2014 09:41:19(UTC)  | Reason: Dyslexia
Offline Janne75
#36 Posted : 22 June 2014 08:59:00(UTC)
Janne75
Hi Ak,
You are genius as you are able to plan so long tracks in many levels to such a limited space ThumpUp . This is very interesting layout plan. When it will be ready it will be almost impossible for people watching trains running to know and tell where trains will go next. This is good and keeps it interesting to watch. I have no skills to build such multi level layouts myself. How many meters of track there will be in total?
Keep up the good work! RollEyes
Janne
#37 Posted : 22 June 2014 19:40:39(UTC)
Thank you. Below is the XTrackCad part list (which is indicative only since experience shows that needs change during actual construction) for all four levels: Should be roughly 30 m of track.
Wink
Count | Description
7 | 24064
4 | 24077
2 | 24094
11 | 24107
3 | 24115
31 | 24130
12 | 24172
9 | 24188
2 | 24206
8 | 24207
5 | 24215
1 | 24224
2 | 24229
25 | 24230
13 | 24330
9 | 24430
4 | 24530
2 | 24612
6 | 24671
4 | 24672
10 | 24912
As pointed out earlier, the curves in the shadow station area are demanding, and only a hands-on test with coaches would show if it is really feasible to squeeze five circles in there. It is always possible to play tricks on the C track geometry, which is easier with parallel straight tracks than with parallel curved tracks.
Blink
#38 Posted : 22 June 2014 19:56:42(UTC)
Oh, and another caveat: While allowing for long mainline runs of trains and up to three meter long spurs and sidings, I planned elevations and criss-crossing for diesel and steam operation. Employing catenary would either require to employ custom made solutions or slightly higher elevations, resulting in a little bit steeper slopes.
Glare
Offline petestra
#39 Posted : 22 June 2014 23:41:50(UTC)
Hi Ak, Yes, the tracks are very close together, BUT, are you going to use computer
planned routes? If yes, then is it possible to program the trains so that they do not pass
each other on adjoining tracks at specific speeds? I do not do this or have knowledge of this but it may be
possible, no? Peter Unsure
#40 Posted : 23 June 2014 13:15:19(UTC)
Maybe, but I do not trust them machines.Mellow
I am the last of the species "Tracklayerus Extinctus".WinkSMITHS-TRACK-LAYER.jpg
Edited by user 02 November 2016 12:21:30(UTC)  | Reason: Small typo corrected.
#41 Posted : 03 July 2014 02:55:31(UTC)
Now: Here comes the finalist. Shadow station "de-crowded", all turnouts accessible (at least from the side) without trouble, S-curves defused, no tight R1 curves in visible areas (graciously ignoring curved turnouts), tunnels minimized (following FD directive). It is a two-faced design, mainly for watching long train runs on the landscape side with the "Rotten Pass" towering over a deep valley as well as offering switching and shunting potential on the city side (working title: "Sam Diego"). Since there is a view block between both worlds, it is only possible to see either side. Therefore, there are two reverse loops on the lower level, so when working the station one has not to wait ages until a train returns from the mountain pass run (which cannot be supervised on the city side). On the other hand, when staying on the landscape side to guide a train during the mountain run, a train can safely return via the shadow station without any intervention, just reappearing without much delay near the creek at the valley bottom. I do not intend to automize operations. For ease of maintenance, the shadow station has open sides. The single track mountain pass tunnel and the double track sloped tunnel below the former can be reached by removing a low relief building on the city side. If I made up my mind, this would be the approach to be followed...
Blink Mellow Confused Bored Wink Woot
I attach the usual collection of plans (red = elevated):
1) lower levels;
2) upper levels;
3) all levels;
4) artist´s perception.
#42 Posted : 03 July 2014 02:58:55(UTC)
Somehow, I do not master the part list generated by the track planning tool. Thus, I provide two lists, one for the lower and one for the upper levels.
Count | Description
2 | 24071
4 | 24077
1 | 24094
4 | 24107
7 | 24115
23 | 24130
14 | 24172
6 | 24188
10 | 24206
4 | 24207
3 | 24215
4 | 24224
18 | 24230
12 | 24330
8 | 24430
5 | 24530
2 | 24611
1 | 24612
6 | 24671
4 | 24672
1 | 24712
16 | 24912
Count | Description
1 | 24064
4 | 24077
1 | 24094
4 | 24107
6 | 24115
21 | 24130
5 | 24172
2 | 24188
2 | 24206
3 | 24207
1 | 24224
23 | 24230
7 | 24330
2 | 24430
3 | 24530
11 | 24912
Offline Janne75
#43 Posted : 03 July 2014 08:41:41(UTC)
Janne75
Hi Ak,
I'm very impressed how well you have planned everything. You have limited space to create all this and anyway it will be a great layout when ready. When I look at your track part list I can see you are able to use many wider radius curves in the visible areas. In my opinion this is the best layout I have ever seen taking only this small area. And it has VERY long routes.
Congratulations as you are a genius! ThumpUp RollEyes
Janne
thanks 3 users liked this useful post by Janne75
#44 Posted : 03 July 2014 09:26:03(UTC)
Thank you Janne,
You make me blush.
Blushing
Yes, it is my intention to make ample use of wide radii and easements at the beginning of all curves to improve the appearance of coaches entering and leaving curves. Then, I want that tracks and landscape rise or increase steadily like cascading rice terraces - lower parts in front and higher parts in the back - to please a viewer.
Experience shows that - during a (potential) construction - it is possible to toss, push and pull here and there. I noticed already that it is feasible to turn the entire convolute in order to have the straight station trackage at an angle to the layout border, i.e. avoiding tracks running parallel to the the left edge of the layout.
All bridges need to be custom-built due to the capricious mainline design. And the city requires a lot of self-made low relief structures or backdrops.
At last but not at least, there should be a theatrical staging effect, thus trains appearing and disappearing with some sense of direction, i.e. coming from and going to distant destinations.
And I think I met all my aspirations during my day-long (many days already...) planning effort.
Blink Laugh
Edited by user 03 July 2014 16:05:55(UTC)  | Reason: Not specified
#45 Posted : 17 December 2014 12:33:36(UTC)
I detected a really cool compact (100 x 160 cm) multi-level layout plan for M* C track. It is a single track main line complete with visible station and hidden shadow station (three tracks) on the ground level plus a branch line climbing up to a small terminus on level 3 - quite a long run for a short train. Visually very attractive. The main line level is easy to construct, while the branch line is more demanding. Still it is possible to play on the ground level while the upper level and landscape construction is still under way.
Source (with track library):
http://www.moba-trickkis...p;total=353&start=21
#46 Posted : 17 December 2014 13:06:03(UTC)
Nice plan!
This would be nice as a secondary layout where you can run all your small engines with short trains. The branch line is especially attractive, and I would love to have the space to include such a feature on mine, but in the space I have available it would cover up too much of my main line.
#47 Posted : 17 December 2014 13:07:18(UTC)
Another idea which I find aesthetically appealing: Long twisted bi-level mainline run without a single turnout. The N-scale layout is supposed to support two PC monitors placed inside the two circles, respectively.
http://www.moba-trickkis...mp;total=64&start=40
#48 Posted : 17 December 2014 13:18:38(UTC)
And the final contribution (for today that is):
Actually not compact regarding the length - I reckon in HO scale it should be 3 m long - but conceptually interesting, an N-scale plan which is easy to construct with a lot of landscaping potential.
http://www.moba-trickkis...mp;total=64&start=42
#49 Posted : 19 March 2015 18:39:57(UTC)
Neither circle nor oval, but space saving design for "big time" shunting.
:o)
Offline Irish Rail
#50 Posted : 19 March 2015 21:10:47(UTC)
Irish Rail
Ireland
I like that idea, Ak. Any idea what sort of dimensions it would require?
I'm currently trying to come up with an overall layout plan/theme and shunting/freight operations would suit better than passenger or rural scenery. But space is limited and I will be using M-track. Would there would have to be an exit to a fiddle yard or shadow station?
6 Pages123>»
This page was generated in 1.578 seconds.
