Offline Solly
#1 Posted : 18 November 2014 06:38:34(UTC)
Solly
How do I check the software ver in my cs2 ?
#2 Posted : 18 November 2014 08:02:27(UTC)
Hi, Solly,
Welcome to the forum.
You will find the CS2 version under Setup on the Version tab (something like "3.5.6(16)" behind the label "Software Version"). The TFP version is on the Information tab (something like "2.43" behind the label "Version").
Offline charles Sharpe
#3 Posted : 18 November 2014 13:18:40(UTC)
charles Sharpe
Hello.
CHARLES SHARPE
Offline GDJTrain65
#4 Posted : 22 November 2014 09:26:18(UTC)
GDJTrain65
And the latest version is 3.7
Look at http://www.maerklin.de/d...ds/software_updates.html
( hope you understand German)
#5 Posted : 22 November 2014 10:47:29(UTC)
Hi and welcome to the forum!
Offline MikeR
#6 Posted : 23 November 2014 04:40:19(UTC)
MikeR
Hi Solly
Member of ETE
CS2 60215 with 6021 slave (Digital)
by Willr 09/03/2024 00:05:11(UTC)
CS2 upgrade to CS3 (Digital)
by rhfil 11/12/2023 00:39:07(UTC)
CS2/CS3 multiprotocol Wave form (Digital)
by peter_moulin 07/11/2023 12:43:12(UTC)
CS2 firmware update (Digital)
by gbel78 20/10/2023 17:45:06(UTC)
Central Station CS2 (General MRR)
by gbrendem 13/10/2023 19:52:37(UTC)
Marklin CS2 60213 (H0-scale)
by Kuhan 09/09/2023 14:41:33(UTC)
Setting up CS2 (General MRR)
by Drongo 25/08/2023 02:01:03(UTC)
CS3/CS2 - same loco different photos (Digital)
by twmarklinfan 26/07/2023 00:51:29(UTC)
CS2 and programmer programming decoder question (H0-scale)
by billyamy 18/07/2023 21:37:04(UTC)
CS2 : s88Link and Booster use same port : how do I connect them both ? (Digital)
by Johnvr 06/07/2023 13:04:58(UTC)
Märklin MFX+ is not registering to CS2 after factory reset (Digital)
by applor 11/06/2023 23:12:15(UTC)
Mapping and adjusting functions on the Giruno using CS2 (Digital)
by PeFu 29/05/2023 06:46:31(UTC)
CS2 failure to start (Digital)
by gamolina 23/05/2023 01:08:52(UTC)
Does the CS2 have "events" like the CS3 (General MRR)
by Drongo 31/03/2023 08:40:57(UTC)
RailControl Pro — CS2 and CS3 controller for iPhone, iPad and Mac (Model railroad software)
by northstar 24/02/2023 15:29:28(UTC)
Which is latest software version for CS2 60213 ? (Digital)
by Johnvr 13/02/2023 19:58:43(UTC)
Voltage input for CS2 (Digital)
by Juan Carlos Carbonel 05/02/2023 04:28:02(UTC)
Märklin CS2.exe (Model railroad software)
by w4sepp 09/11/2022 10:44:12(UTC)
Little problem with my CS2 (Digital)
by Thewolf 07/11/2022 23:52:12(UTC)
Das LoDi-Con, new wireles controller, compatible with CS2/3 and several other systems (News from Märklin and others)
by bph 26/10/2022 21:20:06(UTC)
Lenz LS150 address change not responding - CS2 vs lokprogrammer (Digital)
by applor 26/10/2022 01:12:52(UTC)
CS2 compared to CS3 (Digital)
by mrunix 30/09/2022 23:44:03(UTC)
Märklin CS2 (Digital)
by Rolando 07/09/2022 13:08:56(UTC)
Central Station CS2 (Digital)
by Rolando 31/08/2022 13:19:36(UTC)
by Rolando 24/08/2022 10:11:46(UTC)
Registering decoders on three way points on CS3+ and CS2 and other problems (Digital)
by DV 11/08/2022 10:30:31(UTC)
Need help upgrading CS2 (Digital)
by nelson77 17/06/2022 18:06:58(UTC)
Computer software with Marklin CS2 (General MRR)
by Christo Swanepoel 25/04/2022 19:16:22(UTC)
New Updates for CS2 ( Software 4.3.0 ) and MS2 ( Software 3.148 ) (Digital)
by FrankF 23/03/2022 14:49:22(UTC)
cs2 back (Digital)
by Thewolf 11/12/2021 18:32:28(UTC)
Cable extension from S88Link (60883) to cs2 (60215) (Digital)
by Thewolf 06/12/2021 23:19:19(UTC)
Accessories/Cables for CS2? (Digital)
by Shay 16/09/2021 17:32:30(UTC)
CS2 update and Digital Switch recognition and action (Big scale)
by Inspectorate56 19/08/2021 15:55:07(UTC)
CS2 software upgrade. (Digital)
by Barby & Stan 16/08/2021 22:37:28(UTC)
Adding sounds to a Shuttle route using a CS2 (Digital)
by Elsleuth1 29/06/2021 21:56:13(UTC)
Loco Icons & CS2 (Digital)
by Timnomads 21/06/2021 08:37:42(UTC)
MUs in CS2 and CS3 (H0-scale)
by Timnomads 10/05/2021 10:07:53(UTC)
CS2 issues (H0-scale)
by Airfix05 20/04/2021 17:03:56(UTC)
CS2 60215 English manual (Digital)
by Donb 16/04/2021 17:36:40(UTC)
CS3 plus connected to CS2 and 3 units 6088 S88 feedback (Digital)
by George Culliver 29/03/2021 06:30:30(UTC)
New Software-Update for CS2 (60215/60214/60213) and MS2 (60653/60657) (Digital)
by FrankF 26/02/2021 22:23:59(UTC)
Copy data from CS2 to CS3 plus (Digital)
by gachar001 24/02/2021 07:15:23(UTC)
Märklin CS2 is loading, loading, loading but not starting? (Digital)
by jaakkomu 11/02/2021 19:27:06(UTC)
How to setup the turnout indication in Marklin CS2 (Digital)
by arniland 23/01/2021 17:20:23(UTC)
Mfx locomotives not found by CS2 - Solutions? (Digital)
by Martin T 21/01/2021 20:22:52(UTC)
bizarre problem CS2 / iPhone mobile station with turnout control (Digital)
by applor 03/01/2021 01:23:21(UTC)
7286 turntable with LDT TT-DEC - CS2 step turn doesn't work properly (Digital)
by applor 29/12/2020 22:56:15(UTC)
LokPilot 4 decoder OK in LokProgrammer but not with CS2 (Digital)
by PeFu 28/12/2020 17:46:56(UTC)
CS2 or PSU issue? (Digital)
by Borsig-Werke 08/12/2020 17:38:36(UTC)
ESU Loksound 5 Decoder, CS2 or Intellibox (H0-scale)
by johnmarklin 29/11/2020 12:49:47(UTC)
This page was generated in 0.562 seconds.
