Offline Kaspar
#1 Posted : 31 October 2014 23:53:40(UTC)
Kaspar
I have 3 of the older Mobile Stations lying around from various starter kits. I see you can buy a cable to hook up a second station to the track box, one becomes a Master and one a Slave. But what can you do with this in practice? Reading the user manual it says the Slave uses the masters locollist, which is fine, but then it says: "No operation is possible with the Master controller"
Is it not possible to operate 2 trains at the same time, one from each Mobile Station? What is the point the of connecting the second controller?
-kaspar
#2 Posted : 01 November 2014 00:12:26(UTC)
Hi, Kaspar,
Maybe something got lost in translation.
You can run locos from the slave unit, but you cannot register or program them.
BTW: Some of those Mobile Stations are for 1.9 A track output, some are for 1.2 A track output. If you have different units, use one with 1.9 A as the master. Can be checked under OPTIONS => INFO.
Feasibility of Running 4 separate Marklin C Track Loops Using 2 Mobile Stations 60653 (General MRR)
by mjborelli 31/01/2023 02:44:06(UTC)
This page was generated in 0.317 seconds.
