Offline flashwebb
#1 Posted : 29 August 2014 07:03:49(UTC)
flashwebb
Can anyone explain to me why Hardware version and Serial Number is 0 on my CS 2??
i have run update (internet) and my CS2 is up to date..I have no MFX+ loco at all only MFX
Hardware version: 0.0
Software Version: 3.6.2
Serial Number: 0
On a youtube clip i saw a guy update to Software version 3.6.2 and there i could see he have below
Hardware version: 5.1
Serial Number: 31370
#2 Posted : 29 August 2014 07:33:26(UTC)
Hi, Peter!
Probably not.
Were they already 0 before they upgrade or did they get lost during the upgrade? Maybe you didn't check then.
Either way: never heard about a CS2 without serial number before.
But I had two mfx decoders without serial numbers. At some stage during production the serial number is set. Maybe your CS2 slipped through that step or and never had neither serial number nor hardware version.
Is there a serial number printed at the bottom of the case?
Hardware version is relevant for galvanic insulation and maximum power output only - and there should be a sticker at the bottom indicating galvanic insulation if present. Only relevant for ref. number 60214.
Offline flashwebb
#3 Posted : 29 August 2014 16:25:45(UTC)
flashwebb
Hi H0
i don't know if it been 0 all the time
Something went wrong with the update 1 1/2 years ago..so i have to send it back to the shop and they send it to märklin..(Warranty)
This is what is on the bottom
Bottom
Version:
Version
Update error:
i get this error when i update it 3 days ago
Update
Offline waorb
#4 Posted : 29 August 2014 18:33:57(UTC)
waorb
Brazil
Hello Peter!
Since the velocimeters are pink, this could be an expected behavior...
Seems that you are in the middle of the regular update.
Did you reboot and retry to do a second update?
The standard last update from Märklin expect that the customer do 2 updates one-after-another with a reboot in the middle, to complete all the tasks.
Walter
#5 Posted : 29 August 2014 19:08:36(UTC)
Hi, Peter!
Do what Walter told you: start the Update again.
Pink dials indicate an intermediate step. Check the serial number again once you are back to normal dials.
This should also cure the mfx CV error message.
Offline flashwebb
#6 Posted : 29 August 2014 19:16:29(UTC)
flashwebb
i have allready made the 2 update...and the color is back to normal...and my system is up to date it say
But no change in the serienumber and the hardware
Offline waorb
#7 Posted : 29 August 2014 20:58:43(UTC)
waorb
Brazil
Really very strange...
This page was generated in 0.426 seconds.
