sevs Offline
#1 Posted : 01 August 2012 13:55:17(UTC)
sevs
Say, if I have analog power from the catenary, and digital power from the center studs, and connect both the analog adapter and the digital adapter's ground together, will I fuck up something then?
Edited by user 03 August 2012 19:02:12(UTC)  | Reason: Not specified
Regards, Jon Håvard :) About me - click here!
H0 Online
#2 Posted : 01 August 2012 14:08:30(UTC)
This will work fine ...
... until you accidentally connect centre rail and catenary while both have power (this will most likely kill your digital controller or the booster)
Suaviter in modo, fortiter in re
 1 user thanked H0 for this useful post.
sevs Offline
#3 Posted : 01 August 2012 15:14:16(UTC)
sevs
Thanks, Tom
If I have connected centre rail and catenary while only one of them have power, what happens? Laugh
H0 Online
#4 Posted : 01 August 2012 15:26:44(UTC)
I presume that for a moment, nothing will happen. Then, after a second or so, nothing will continue to happen. Wink
Read more at http://www.brainyquote.c...html#PBlYo8iXFm3Ufmpm.99
But I haven't tried that - and I won't put my controllers at any risk to find out ...
Better turn both off both analogue and digital power before fiddling with rolling stock (especially tin plate stuff) or tools on the layout.
Ian555 Offline
#5 Posted : 01 August 2012 16:52:17(UTC)
Ian555
Hi Jon,
I've ran both analog and digital Loco's on my layout for the past 3 years, BUT, they run on totally seperate tracks, both mechanically and electrically.
It's the only safe way to do it.
This way of course you can run both analog and digital Loco's together and directly compare the performance of both against each other.
Ian.
Edited by user 01 August 2012 17:51:37(UTC)  | Reason: Not specified
5HorizonsRR Offline
#6 Posted : 01 August 2012 17:08:13(UTC)
I have done 2 layouts now with the following solution, for those who have a few analogue items they want to run from time to time, but are mainly digital operators:
1: On a normal digital layout, I take one loop/line of track and wire it independently from the rest of the layout. The only permanent contact is K83 decoders working the switch motors, and 2-3 switches that join the loop to the main layout- on which with C track I isolate BOTH the hot and ground contacts as a security measure.
2: This leaves a possible ground joint from outer rail to outer rail at the switch, but that is it. (and I'm pretty sure it doesn't really matter anyways)
3: I then have 3 way toggle switches for both hot and ground wires to the isolated line. I use 3 way as I like taking both switches to the "off" position in the center as a security measure before flipping from one current to another. Via these switches I can route power to the rest of the layout, or to an analogue transformer.
It works like a charm, but like Ian recommends it basically just enables a very independent analogue loop on the layout. No trains cross over or anything like that. it does leave the benefit of the K83 keeping digital switch control while you run analogue trains though- which is nice.
SBB Era 2-5 and USA Era 2-3 East Coast
mike c Offline
#7 Posted : 01 August 2012 17:46:54(UTC)
If you have both systems connected but only use one at a time, you must ensure that the cables from the layout to each transformer are equipped with a switch to prevent power from one transformer from damaging the other.
If using digital loks on a layout where you also operate analog loks, you must ensure that all analog loks are safely removed or disconnected when powering up with digital. This may also apply to coaches and cars with lighting as they may not be equipped for digital operation.
The safest switch to use would be a switch which would have three positions, one for digital, one for analog and an intermediate one with no power source. This would ensure that there is no accidental power surge when switching from one system to the other.
You may also decide to power the catenary with DC which will enable you to run DC electrics on a Maerklin AC layout.
Good luck
foumaro Offline
#8 Posted : 01 August 2012 18:45:24(UTC)
Thanks, Tom
Scared Scared Scared Scared Scared
BR01097 Offline
#9 Posted : 02 August 2012 04:01:02(UTC)
BR01097
I'm not sure Sevs^'s question got answered: to have the digital circuit using the center-rail stud contacts and the catenary wire for analog share a common ground (the tracks) routed back to their respective transformers will not fuck up anything. Accidentally connecting the center studs and the catenary at the same time (to each other, I presume that is what is meant) will cause a short, which may blow out a digital transponder.
Personally, I like the idea of running alternating current through the tracks and direct current in the overhead to power the few HAMO locomotives I own to mimic the various European system and cycle differences. It is the same principal of isolated circuity, also to no adverse effect.
cookee_nz Offline
#10 Posted : 02 August 2012 06:03:31(UTC)
Love the highly technical technical analysis of potential failure!! "Fails Unless Constantly Kicked" !!
I actually did this for some time on a former layout some years back - the brown/'ground'/common remained connected all the time, but I was also very particular to keep the Red (Stud&Catenary) wiring very distinctly separate. It enabled me to run some older non-converted Loco's along with the Digital ones, in fact against the common advice I used the overhead for Digital and the stud for Diesels & Steam. I had no problems with the Digital off the overhead but at that time I had all older style decoders as well - 6080 & 6090 which seemed quite happy with it, but I understand the potential problems with some of the newer decoders that are more sensitive to the possible erratic contact made by the pantograph.
Keep those Reds away from each other, and above all else, don't cross the beams, keep out of the nebula, and always keep the flux capacitor loaded to capacity, you never really know when you are going to need 1.21 Gigawatts in a hurry!!
sevs Offline
#11 Posted : 03 August 2012 14:21:50(UTC)
sevs
Thanks, everyone! :D
This page was generated in 0.925 seconds.
Map
See the web site statistics
Bookmark and Share
