5 Pages<12345>
Offline Chris6382chris
#101 Posted : 05 July 2012 00:51:42(UTC)
Chris6382chris
Originally Posted by: Caralain Go to Quoted Post
Hi Chris:
You made two beautiful videos of your new layout. It is not only interesting to watch, but also it is well filmed. Congratulations and thank you for sharing with us.
I have a question: is your layout entirely digital, or do you have same analog sections? I am asking because you showed a few locomotives from the sixties or so, like the DB green shunter. As for your two cranes, you did a wonderful job in restoring them. They really add something to your layout.
Please keep making more videos!
Pierre
Pierre:
Thanks for the kind words. My videos are still a work in progress but I appreciate the compliments. With regard to your question about my layout, it is all digital. I have converted all of my locomotives. I used a combination of ESU Lokpilot and LokSound decoders and permanent magnets. I find that the existing motors work really well with the ESU decoders and I don't need to upgrade to the 5 pole motors (just my opinion).
With regard to the cranes, one was like new out of the box, even though it was 40 plus years old. The other one was bought on eBay and was a wreck that had to be taken completely apart, cleaned, unbent, restrung, rewired in some parts and repainted. I am very pleased with the results. The only thing I haven't done is replace the piece that connects the crane arm to the cab, you can't see it but it is actually a piece of coat hanger that I painted and and bent so that it works just as the original. One of these days I plan on buying a replacement part for it.
Chris
#102 Posted : 05 July 2012 20:46:37(UTC)
Chris6382chris
Hey I finally made it to the multi page club on this forum. Two pages, yes! Woot Thanks everyone.
Offline GTSE800
#103 Posted : 05 July 2012 23:37:45(UTC)
GTSE800
Thats a good idea on the oil tanks, I think they look good ........
GTSE800
#104 Posted : 06 July 2012 01:56:57(UTC)
Chris6382chris
Thanks, I can get each PVC coupling for about $3 at Home Depot and they have a bunch of different diameters. I simply sand down the edges and paint with flat black or with flat white and then cut the tops, paint them and glue them in place and I am all set. Instant tank farm.
Chris
#105 Posted : 06 July 2012 07:54:47(UTC)
Great video, Chris!
Offline Ian555
#106 Posted : 06 July 2012 08:14:42(UTC)
Ian555
Hi Chris,
Great video, thanks for showing the cranes in operation. ThumpUp
Ian.
#107 Posted : 06 July 2012 17:32:17(UTC)
Chris6382chris
Thanks Ray and Ian.
With regard to the cranes, I must say when I have visitors they love them, the kids can play with them and the adults are amazed that they run. They have turned out to be a real crowd pleaser and alot of fun.
Chris
Offline pab
#108 Posted : 06 July 2012 18:55:07(UTC)
pab
Very nice video with those cranes in action and the trains running.
#109 Posted : 08 July 2012 03:22:27(UTC)
Chris6382chris
Thanks for the compliment Piet. Today I did some work on the lights for the town and the station area. I put up some street lights as well as put lights in some of the buildings. I still have more work to do but it is progressing and I am pleased with the outcome so far.
Here is a picture of the town at night.
Chris
thanks 2 users liked this useful post by Chris6382chris
#110 Posted : 08 July 2012 03:52:02(UTC)
Very nice result,congratulations.
Offline Ian555
#111 Posted : 08 July 2012 05:23:15(UTC)
Ian555
Hi Chris,
Looks great. ThumpUp
Ian.
Offline utkan
#112 Posted : 08 July 2012 11:10:13(UTC)
utkan
Turkey
Both the video and the night shots are very cool,Chris....ThumpUp ThumpUp
www.marklinistanbul.com - marklinistanbultv - YouTube if I manage to be nearby tomorrow, I'll continue to post....
Offline pab
#113 Posted : 08 July 2012 13:12:28(UTC)
pab
Nice scene.
Maybe the lights in the picture are a little bit too much.
I saw you used an exposure time of 0,8 sec and an aperture of 2,8.
To create a more nightly atmosphere you could use a smaller aperture (like 16 or higher) and a longer exposure time.
Shut of the lights after 2 or 3 seconds (maybe less). I thinks the outcome may surprise you.
Offline Loadmaster
#114 Posted : 08 July 2012 13:51:22(UTC)
Loadmaster
Chris,
Have you thought about installing a riastat (sp) which would give you the adjustability of light intensity.
Rob
HOac and Z scale running SBB/BLS Era IV-VUserPostedImage
#115 Posted : 08 July 2012 14:31:12(UTC)
Chris6382chris
Thanks for the comments. After I installed everything that is something I am considering, installing a rheostat to drop the voltage on the street lamps a bit. All my lights are run off of an older big blue Marklin 30 VA transformer. To be honest I am just happy to have lights. Piet, as far as exposures and timing for my camera I have no Idea how to do that, I will check into that, thanks for the suggestion.
Chris
Offline Shintaro
#116 Posted : 09 July 2012 09:33:32(UTC)
Shintaro
Hi.
Why not plug the active (yellow) into the Bahn (red) socket instead, that will make the transformator act as a rheostat (trimpot, or variable resistor - depending on where you are). And leave the Ground (Brown) as is. Just an idea.
Cheers.
Edited by user 10 July 2012 09:28:11(UTC)  | Reason: Not specified
#117 Posted : 09 July 2012 09:56:33(UTC)
Nice street shots!
#118 Posted : 09 July 2012 13:58:54(UTC)
Chris6382chris
Thanks for the comments and suggestions. I could plug the lights in to the post for the track and use that to turn the voltage down but that would reduce the lighting on everything and I like some of the lights bright. ThumpUp I think I will put something in between the street lights and the wire bus and turn the lights down that way. We shall see, right now I am just happy to have lights. Woot
Offline Loadmaster
#119 Posted : 09 July 2012 14:03:06(UTC)
Loadmaster
Let me know how you proceed.
Offline LMS800
#120 Posted : 09 July 2012 18:05:13(UTC)
LMS800
Chris
Hi Chris,
I use the Märklin transformer as a rheostat for dimming the light. I connect the light with B on the transformer (normally current for the tracks) and dim the lights.
Wolf
Offline Joe Meiring
#121 Posted : 09 July 2012 18:26:45(UTC)
Joe Meiring
WoW!!...Thanks Chris, simply an awesome layout....well done
Joe
Medium digital C track layout with MS2: When I grow up I want to be a steam engine driver....
#122 Posted : 10 July 2012 16:06:11(UTC)
Chris6382chris
Thanks Joe and Wolf for the comments. I just ordered some very small fiber optics cable and some modified blue LEDs, so the next step for the town scene is to light up all of the headlights and then I want to make either an accident scene or fire scene with my emergency vehicles and I will light up the emergency lights. I tried this on the last layout and wasn't completely happy so I am hoping to do a better job this time.
Chris
#123 Posted : 14 July 2012 05:22:58(UTC)
Chris6382chris
Finished some decoder conversions today on engines I just bought off of eBay. I took a quick video of them running through the passenger station on my layout. You will see two V200's and one BR 212. One of the V200's has sound. All the decoders are ESU and I kept the 3 pole motors in each of the engines, the only change was to use LEDs for lighting and to add the permanent magnet. I hope you like.
Chris
Video of BR 212 and V200s on my layout
Offline Ian555
#124 Posted : 14 July 2012 05:39:38(UTC)
Ian555
Hi Chris,
Enjoyed watching the video. ThumpUp
Ian.
Offline DV
#125 Posted : 14 July 2012 06:07:01(UTC)
DV
Chris
Very nice looking V200's Chris.
Welcome to the V200 (and their offsprings) ClubThumpUp ThumpUp ThumpUp
Hope you have many years of enjoyment out of them, I know I have out of mineWink Wink Wink Wink
Dusan V
#126 Posted : 14 July 2012 14:21:56(UTC)
Chris6382chris
Chris
Thanks Dusan, I must say that after buying two of them and seeing them run on my layout I am happy to have joined the club. Next on my list is a Blue and Cream one, I will be looking on eBay.
Thanks Ian.
#127 Posted : 25 July 2012 02:16:17(UTC)
Chris6382chris
Here is another video of the layout. I have added catenary to the layout and added another engine, a BR 216, to my roster. You will also see in the middle of the video the lighting of my emergency vehicles. I ended up making a simple circuit I found on the internet that gave me a great flash rate and found some perfectly sized LEDs for the blue emergency lights.
Chris
Link to the YouTube Video
Offline Ian555
#128 Posted : 25 July 2012 06:15:55(UTC)
Ian555
Hi Chris,
Great video. ThumpUp
Ian.
#129 Posted : 25 July 2012 09:54:05(UTC)
Great video Chris! ThumpUp
I have to say I'm a much bigger fan of the V160 family of locos than of the V200s. I'll probably get hate mail now for saying that! Anyway, I like your new 216!
Your LED flashing lights are brilliant too!
Offline petestra
#130 Posted : 25 July 2012 10:28:44(UTC)
Excellent video and trains, Chris. PeterThumpUp Smile
#131 Posted : 25 July 2012 17:20:02(UTC)
Chris6382chris
Thanks for the comments. I am adding a few additional pictures showing some engines and the catenary in place. For those who are zealots about catenary, I am not running my trains on them and I did indeed bend the catenary to match the curves, I was going for the overall look and feel of an electified line. My biggest desire was to have it up on the routes where I plan to run my electrics, I am pleased with how it turned out. ThumpUp
I hope everyone likes.
Chris
thanks 3 users liked this useful post by Chris6382chris
Offline petestra
#132 Posted : 25 July 2012 20:28:22(UTC)
Great pics, Chris. PeterThumpUp
#133 Posted : 25 July 2012 21:46:31(UTC)
Nice photos!
Offline hennabm
#134 Posted : 26 July 2012 21:38:39(UTC)
hennabm
Hi Chris
nice pictures of the E loks where they should be - under catenary.ThumpUp
1957 - 1985 era
What's digital?
Offline Ian555
#135 Posted : 27 July 2012 05:27:52(UTC)
Ian555
Hi Chris,
Great photo's of your layout. ThumpUp
Ian.
#136 Posted : 27 July 2012 05:42:06(UTC)
Excellent pictures.ThumpUp
#137 Posted : 27 July 2012 06:53:17(UTC)
Hi Chris,
Bewdy, mate! The catenary certainly looks the part.
HO Scale - Märklin (ep III, C Track, digital) - 2 rail (USA and Australia) - 3 rail (English Hornby Dublo) - a few old O gauge.
#138 Posted : 27 July 2012 13:48:04(UTC)
Chris6382chris
Thanks everyone. Things are coming along pretty well. BigGrin
#139 Posted : 27 July 2012 14:44:44(UTC)
Good stuff, Chris.
Online Johnvr
#140 Posted : 31 July 2012 06:20:22(UTC)
Johnvr
Chris,
Well done on those conversions, and the layout looks great, what a difference the catenary system makes !
Regards,BigGrin
#141 Posted : 31 July 2012 17:36:21(UTC)
Chris6382chris
To John and John thanks for the comments. I agree the catenary adds so much to the look.
Chris
Offline kweekalot
#142 Posted : 31 July 2012 18:41:02(UTC)
kweekalot
Hi Chris,
You have a beautiful layout !!
I wish I had a bit more space for a bigger layout than the one I have now.
Marco
#143 Posted : 25 October 2012 07:23:30(UTC)
Chris6382chris
Thanks Marco. Sorry it took me so long to respond. I just posted a new video on youtube, the link is below. I think the room was a little dark so things could look a bit better. Anyway, you can see a few of my engines traveling through my station area. Since the last time I posted about my layout I have added several engines, including a Blue E 41, and a BR 50. Both have ESU LokPilot 4 chips with the original 3 pole motors in them. In addition you will see a BR 212, V200, BR 23, an Italian Steam Engine, a BR 38 as well as my green E 41.
YouTube Video of trains running on the layout
thanks 1 user liked this useful post by Chris6382chris
Offline Ian555
#144 Posted : 25 October 2012 07:50:31(UTC)
Ian555
Hi Chris,
Thanks for the video and the update on your new Loco's. ThumpUp
Ian.
#145 Posted : 25 October 2012 09:36:10(UTC)
Chris,
enjoyed the video can we have more in future ?
#146 Posted : 25 October 2012 13:56:35(UTC)
Chris6382chris
No problem John. I haven't been updating as much as I should have in the past but I will be catching up as winter approaches. I also have to improve upon my video skills. More video's will be coming.
#147 Posted : 25 October 2012 18:04:36(UTC)
Great video, Chris! ThumpUp
I really enjoyed watching your locos doing their stuff!
Maybe next time you could try with the light on? BigGrin
Offline utkan
#148 Posted : 27 October 2012 20:17:00(UTC)
utkan
Turkey
Hi Chris,
Another enjoyable video.....ThumpUp ThumpUp
mehmet
Offline Christoffer
#149 Posted : 09 November 2012 04:33:19(UTC)
Christoffer
Hello Chris! Smile
Very nice layout you have created here ThumpUp ThumpUp Keep up your good work, hope to see more in the future ThumpUp
Offline pab
#150 Posted : 09 November 2012 20:40:21(UTC)
pab
Very nice video of the station area.
OceanSpiders 2.0
5 Pages<12345>
This page was generated in 1.710 seconds.
