franciscohg Offline
#1 Posted : 13 June 2012 05:07:47(UTC)
franciscohg
Chile
hi everybody, i have a 7286 TT and i have get a 7686 to run it with my cs2, of course it didnt work...jeje. Problem is i think that if i remember well the TT was bought befote 2002 and in the 7686 manual it says that the TT pre 2002 had to be sent to a m dealer for some modification in order to work with the 7686. does anybody knows what is that modification? too hard to be done at home?
thanks in advance.
francisco
Bedroom layout building in progres....
French_Fabrice Offline
#2 Posted : 13 June 2012 05:59:28(UTC)
French_Fabrice
Hi Francisco,
I bought mine (7286+7686) before 1994 -don't remember exact date , and no problem with my CS2.
Maybe your trouble has another reason ?
Fabrice
FrankF Offline
#3 Posted : 13 June 2012 08:54:31(UTC)
FrankF
Hello francisco
You are right about the modification of the 7286 TT prior to 2002
In the old Manuel for the 7687 TT-Decoder this is written :
Important Information
The 7282 TT has been delivered since 2002 in a Technically different version that is part of the usual ongoing product development.
The Current version of the 7687 Decoder has already been designed for this Change.
If you have af Turntable that was bought before 2002, then you must have the Turntable and the 7687 electronic Circiut adjusted to work together.
You can have an authorized Marklin Dealer send the 7286 Turntable along with 7687 Electronic circuit to the Marklin Service Department.
Caution : With this Adjustment work, damage is possible to the electronic circuit or the Turntable. These damages are not covered by the Manufacturer's warranty.
In the new Manual for the 7826 (dated 7 month 2011) this is written on page 5 (1 column) :
Important Information:
The 7286 turntable has been delivered since 2002 in a technically different version that is part of the usual ongoing product development.
It can be retrofitted with no problem with the currently available 7687 digital circuit.
Other information about the necessity to send the turntable with this circuit to our service department
(example: in the Märklin catalog for 2002/2003) do not apply to the current production series.
In the new Manual for the Marklin 7687 TT Decoder (dated February 2012) nothing is written about the modification of the 7286 TT.
Please also take a look at the following links :
http://www.marklin-users...spx?g=posts&m=120574 (looks like pictures before and after modification of the 7286 TT)
http://www.windigipet.de/win-digipet-workshops/
http://www.ldt-infocenter.com/english/ttdec_e.htm (Alternativ decoder from LDT for the 7286 Turntable)
Frank F - Homepage: www.marklinisterne.dk
CS2 (60215 HW4.33-SW3.0.1-GFP2.31) / 60101 100WA Transformator / 2xMS2 (SW1.83) / 2xMS1 (SW1.8)
iPad 2 / iPad 4 Retina / iPhone 4 ( MainStation / Mobilestation / Touchcab Apps )
mDT / ESU Lokprogrammer / ESU Teststand / H0 / C-Track / Layout 40m2
Marklin 7286 (LDT TT-DEC Decoder)-7294-76500-76510-7051
 2 users thanked FrankF for this useful post.
franciscohg Offline
#4 Posted : 13 June 2012 15:14:32(UTC)
franciscohg
Chile
Hi Francisco,
Fabrice
hi fabrice, so your 7686 is also pre 2002 and it works fine with the older too 7286. back home i will try to check how old is my own 7686.
is there a way to check is the decoder is fine?
if i make the led assembly, should they work with the TT not connected?
franciscohg Offline
#5 Posted : 13 June 2012 17:41:03(UTC)
franciscohg
Chile
Ok, i have checked the TT, made on 09-2002, check the wires and it is the modified version with the diodes.
I looked at my 7686, it seems to be very old, but not with any date on it, the circuit board is version3.1 serial 391850.
On the box the serial number is D0021971.
Perhaps it is an old 7686 made to work with the early TT version. How can i check that?
If so, how can i "unmodify" the TT? In the pictures appears an extra brown cable, apart of the diodes on the other 3 cables of the unmodified version. In that one, where that brown cable should be? Pictures are not that clear....
franciscohg Offline
#6 Posted : 13 June 2012 17:48:52(UTC)
franciscohg
Chile
Here is a picture of the wiring of my TT
As you can see the wiring is different to that shown in the pictures shown in the other topic.
TT
 1 user thanked franciscohg for this useful post.
franciscohg Offline
#7 Posted : 13 June 2012 18:00:15(UTC)
franciscohg
Chile
Hi Francisco,
Fabrice
Fabrice, if you could take a picture of the wiring on your TT??
The version of your decoder would help me a lot too
Francisco
#8 Posted : 13 June 2012 18:03:52(UTC)
French_Fabrice
Hi Francisco,
Mmm, not sure I'm able to help you a lot Blushing
One question: Did you get your 7286 and 7686 TT decoder from the same source and at the same time ?
When I bought mine, the decoder was included with the turntable ..., so the 2 items were supposed to work fine together...
If for instance you've got a TT decoder with a revision not compatible with your Turntable, it may explain some problems.
Otherwise, have a look inside the decoder for a visual inspection (unscrew the cover), but you have certainly had the idea.
I've never use the leds with the TT, so I can't help.
Try to plug the decoder and reset the turntable...When the turntable reaches position 1, my turntable emits a faint two-tone sound a few times meaning pos 1 is reached.
On my turntable connected to the CS2, I've also plugged the red wire connected to a booster circuit to the "yellow" plug of the 7686. It works fine and allows easily to stop power for the layout including the TT, when pressing the stop bar of the CS. This in turn eases to manage the 5 seconds timeout after power up, this duration being the delay while you may enter programming mode...
See this thread for the wiring (and ignore the Viessmann device) : http://www.marklin-users...gh-Viessmann-device.aspx
Good luck
Fabrice
Western Pacific Offline
#9 Posted : 13 June 2012 18:10:02(UTC)
Western Pacific
TT
To me it looks like the same modification electrically seen, just differently done mechanically.
In both cases 3 diodes have been added, all connected to the yellow cable at one end and to the contact tongues at the other. It could be N4004 diodes:
diod
 1 user thanked Western Pacific for this useful post.
#10 Posted : 13 June 2012 18:10:05(UTC)
French_Fabrice
Hi again Francisco,
You've added more info while I was replying, so my post is a bit old.
My TT is mounted on the layout, so I can't remove it easily, but I plan some refactoring by the end of the month. When done, I'll provided you the info I could get.
fabrice
franciscohg Offline
#11 Posted : 13 June 2012 18:27:38(UTC)
franciscohg
Chile
TT
diod
It is not the same i think, yellow cables are wired identically, but in mine the brwon cable goes to the coil, in the other i just cant see well, also in mine the blue one is wired to the plate of the red screw and in hte other it is wired to the coil, in the other picture i cant see well the whole connections at the motor end...
franciscohg Offline
#12 Posted : 13 June 2012 18:31:47(UTC)
franciscohg
Chile
Hi Francisco,
Fabrice
Nop, i jus get my 7886, i bought it as a 7687, even the box says so, but it seems to be an earlier 7686....
This page was generated in 0.393 seconds.
Map
See the web site statistics
Bookmark and Share
