VinceHerman Offline
#1 Posted : 24 May 2012 14:47:50(UTC)
VinceHerman
Our layout will have many sensors. Many s88's which have to be daisy chained together physically close to the CS2.
How have you wired these?
There are clusters of sensors for the shadow yard. I am not looking forward to 20 or 30 individual wires from each cluster.
I am thinking of using network cable with it's multiple twisted pairs.
What have you done?
 1 user thanked VinceHerman for this useful post.
kbvrod Offline
#2 Posted : 24 May 2012 19:34:43(UTC)
kbvrod
Hi Vince,all,
I am thinking of using network cable with it's multiple twisted pairs.What have you done?
Thanks for sharing youse guys layout photos!
A few questions before the experts chime in,.....BigGrin
Your running the whole she-bang with a CS2?
You are going wire it above the shadow station baseboard?
Two things to consider,IMVHO,....1)contact sections before and after the storage tracks in the shadow yard.
2) make the whole length of storage tracks contact sections.
Dr D
Maxi Offline
#3 Posted : 24 May 2012 20:22:16(UTC)
Maxi
What have you done?
I have used network cable for connecting the individual feedback sections and had no problems.
All of my cable runs go back to a single point and then connect up to the respective input on the S88 module.
I did it this way so that I could service the modules if required, instead of squirming into awkward places to sort out issues.
Maxi Offline
#4 Posted : 24 May 2012 20:26:35(UTC)
Maxi
I agree.
You can not have too many sensors and I prefer to monitor all sections of track when and where possible.
Contact switches are really just showing a small area of information, lots can happen from one contact switch to another.
Monitoring all pieces of track by isolating one of the running rails and connecting sections of track to a single S88 input makes for a very detailed monitored track system.
 1 user thanked Maxi for this useful post.
Danlake Offline
#5 Posted : 25 May 2012 04:47:19(UTC)
Danlake
Wasn’t part of the advantage of using the Marklin 3 rail system that you always have 2 rails for ground contact to ensure smooth running?
Just wondering if you isolate long section of rails, if you have observed any performance issues, especially at slow speed when trains are pulling into the shadow station?
Brgs - Lasse
Digital 8m2 layout / C (M&K) tracks / Era IV / CS2 60214 / Train Controller Gold
Maxi Offline
#6 Posted : 25 May 2012 12:33:17(UTC)
Maxi
Brgs - Lasse
No I have not experienced any performace issues, I have installed feeder wires about every 8 to 10 sections of track.
Copper is cheap, use more than what you think is engineered required and you will have no problem.
I am not really a fan of following minimum standard.
Overkill is usually a better choice.
Danlake Offline
#7 Posted : 25 May 2012 16:56:20(UTC)
Danlake
I agree Maxi - you can never have to many feeders wire!
kbvrod Offline
#8 Posted : 25 May 2012 17:40:36(UTC)
kbvrod
I am not really a fan of following minimum standard.Overkill is usually a better choice.<
Good point Maxi! Like the old saying "When in doubt,power out!" BigGrin
My former shadow station/yard was 10' long and one rail served as a contact track,no issues(K-track) and I did as Maxi,I dropped feeder wires ever 3'.
In fact,having many feeder wires,even if you don't 'need' them is good idea on a layout.Easy to solder them to your bus then take up the track,solder,....
Dr D
Maxi Offline
#9 Posted : 25 May 2012 20:17:22(UTC)
Maxi
Dr D
On one section of my layout I ended up cutting a large section out to put a bridge in and of course there was a feeder in that section.
I just removed that feeder and installed the bridge which was on an curved incline, and no change in performance. Smile
Edited by user 25 May 2012 21:05:54(UTC)  | Reason: Not specified
clapcott Offline
#10 Posted : 27 May 2012 03:01:38(UTC)
I believe this to be correct - and a very desirable backup for warping track especially any transition in gradient and/or curves.
It will !! (performance issue = stall)
But risk management has to weigh this against the benefits of using the isolated rail for sensing.
Suggestions
- "Work" at laying the track correctly (physically smooth to mitigate rocking locos from loosing contact)
- Don't uses abrasive cleaners that remove the rail protection once rust gets through it will always be an issue.
- If you have to isolate the rail for sensing on a a curve , do it on the inside rail - the loco will tend to tilt towards the outside and that is where you really need the power circuit to be complete
- for small 0-4-0 type devices, maybe with tires (e.g. glastkasten), an additional wire to the carriage chassis may help
In my ideal world I would leverage the current detection method like the 2-Rail guys do(They have no option). but this doesn't work if there is no power to the track. Both methods have there place as does the actual "tracking" of trains around the layout (i.e. prototypical block control and CTC).
Personally I prefer an "out of band" sensing solution where there is no connection between the track power system. e.g. reed sensing, LISSY, etc. But this is never an either/or discussion
 1 user thanked clapcott for this useful post.
clapcott Offline
#11 Posted : 27 May 2012 03:21:42(UTC)
What have you done?
I am very happy with the use of Cat5 network cables. the bundling of 8 wires aligns with each side of a s88
having the s88s at the control desk assists if you use the desk for multiple layouts (e.g. a club)
This includes using the "industry tested" RJ45 connectors or MDF terminators - but use a proper punch-down tool
I am conscious to use the stranded "patch" cable in preference to the single core "fixed wiring" cable, that can be recovered from building renovations, as this flexibility is needed for regular pack-up/set-up of the layout or relocation of the control desk
The ground/return is important and if a true, out of band, solution is needed - i.e. the various grounds on the layout maynot/cannot be commoned - then a separate wire is needed for that. With your size of layout I would expect the CU with the s88s attached to be dedicated to driving the accessories (boosters being used for trains on the track). In which case the CUs own Brown (that snakes to the various k83/k84 devices) will do nicely for that.
Danlake Offline
#12 Posted : 27 May 2012 03:42:14(UTC)
Danlake
Suggestions
Thanks Clapcott,
Some very good advice for us newbiesSmile
Brgs - Lasse
This page was generated in 0.586 seconds.
Map
See the web site statistics
Bookmark and Share
