Hello
I did use a laptop switching power supply from a Compacq (65VA) .
It works OK with the following remarks:
- Output (secondary) is usually a triple shielded cable (Plus, Minus, digital information exchange between the PS and the computer)
- Identify and connect only the + and minus of the regulated output '19 volts DC in my case) and disregard (do not connect)
the digital information wire (the central pin usually).
- There is no connection between the mains ground and the secondary voltages so it is safe to connect a CS (CS1 and CS2 in my case, I tried with both of them).
- The drawback using a laptop PS is that, the PS turns off very abrutly when over current is detected, causing the CS1 or CS2 to reboot with all loks stopped . I get aggravated to be forced to reprogram the speed on all my locs.
Because of my increasing power needs, I am now using a 100 W märklin switching power supply (60101 if I am correct) for my CS2 -60214 TOGETHER with a 2 mm² ring feeder.
Full 5 Amps are now available, a very graceful over-current detection that causes no destructions to the shorting unit (wheel, current feeder, relay contact, etc). All this is probably coming from the latest CS2 s/w (2.0.1 in my case).
King regards from Paris
My floor installation can be seen here:
http://www.youtube.com/w...ture=channel&list=UL
