Joined: 13/02/2008(UTC) Posts: 609 Location: Kirseberg
Hi all! It´s not easy having the time you need to plan the layout when you work alot and I´ve not finished moving Everything from my apartment. Today I´ve got some tima to spare and I´ve come up with a definitve version of the plan. I´ve also included all the Contact Points. It´s gonna be a Little bit complicated. There will be 3 coal trains (37970, 37973 and 37976) from the tracks closest the water and they are gonna run on the same tracks using the shuttle train function. Therefore I´m gonna use 2 7244 on Contact Points 11 and 7 and be activated by using the route function of the CS2 thereby fooling the S88. Pretty complicated but I Think it will work. I´ve got lots of problems using RocRail so I plan on only using the 60215. I also intend to build the framwork mostly in plywood as open framwork in 4 different modules for easier seperating them if I move. Also a new improvement are all the switches. The single track will be the one that connects to the rest of the layout. Now I "only" have to find a good way to use the Rolling mill, the Bonn station and the Faller military Buildings... and also find some good way to use all 4 Big Boys... and maybe some hidden shadowstations. Please come with suggestions and comments.  |
 2 users thanked klarinettmeister for this useful post.
Joined: 23/08/2006(UTC) Posts: 2,078 Location: Beverly, MA
Hi all, David,I would use good quality pine board or MDO for the module frames,pine will be a lot lighter if you move.MDO is very rugged and again fit and finish is very important. Also have a system to plug each module wiring into the next easily.
Dr D
 1 user thanked kbvrod for this useful post.
Originally Posted by: kbvrod  Hi all, David,I would use good quality pine board or MDO for the module frames,pine will be a lot lighter if you move.MDO is very rugged and again fit and finish is very important. Also have a system to plug each module wiring into the next easily.
Dr D Thanks for the tip! The sheets of pine are quite expensive here and they are only 7,5 mm thick and there are also some pattern on them. I aim for 12 mm plywood. I´ve only been looking at 2 different stores. I can´t find MDO and haven´t heard of it Before. Maybe there´s a different name for it here in Sweden... Or maybe it´s not used very often. |
 1 user thanked klarinettmeister for this useful post.
Joined: 04/06/2009(UTC) Posts: 17,046 Location: Scotland
Hi David, "It's gonna be a little bit complicated". Sure is for me anyway. I'd stick with plywood, if you want heavy weight go 18mm. Ian.
 1 user thanked Ian555 for this useful post.
Hi David all, all, >Thanks for the tip! The sheets of pine are quite expensive here and they are only 7,5 mm thick and there are also some pattern on them. I aim for 12 mm plywood. I´ve only been looking at 2 different stores.< I was thinking pine boards for the framework.  When you said modules and maybe one day -might- move again the lighter weight is better.The ETE module group teaching me a lesson. >I can´t find MDO and haven´t heard of it Before. Maybe there´s a different name for it here in Sweden... Or maybe it´s not used very often.< MDO is explained here: http://en.wikipedia.org/wiki/Medium_density_overlay_panelBig use in the US is road/highway signs and architectural uses on houses.The reason I used it on my old home layout was I couldn't find a true flat sheets of plywood! I need that for the large Bw I was building.MDO is perfectly flat,easy to cut,... Dr D
