James Offline
#1 Posted : 12 July 2010 18:42:53(UTC)
James
Greetings all:
I've decided to try to operate my layout through a PC and so far, it's eluding me. Sooo, I've come to the experts in regards to this dilemma of mine. From what I can discern, the first thing I have to do is get the two talking to each other. This about where everything craps out. I'm using the CS2 and trying to get it to comunicate with my Windows 7 based Toshiba laptop connected through a DLink switch (which I was told would automatically register the necessary IP addresses. Well... gues what? It doesn't... go figure!!!!!!. I've downloaded the latest RocRail freebie software, at least I think I have. The rocrail site has over 20 or 30 different downloads available, all very confusing to say the least. I have tried to sift through the agonizing translation (I'm not fluent in German)and find it very hard to make heads or tails of what I have to do to make this silly software work. I'm sorry, but I'm not a techno weenie when it comes to programming. At this time, all I want to do is find a system that will work (no matter the cost) If I thought Zimo would do the trick, I'd even change to that system. Please... would anybody be able to offer a step by step way of setting up RocRail, or at lkeast a proper english manual? Failing that, what is the next best thing (in english please)?
____________________________________________________________________________________________________________________________________________
James Bannerman
Give me steam, and how you feel can make it real, real as anything you've seen. (Peter Gabriel)
nevw Offline
#2 Posted : 12 July 2010 22:54:24(UTC)
To get talking first you have to set the CS2
In the Setup go to the Network Section and set the the CS to obtain the IP Address Automatically.
Then turn off, connect the cable to the Cs and the Switch.
Turn on the CS and it should obtain the IP Address.
CHeck what IP address it is showing.
Then using your Internet browser go to that address possibly
192.168.0.2
or
192.168.1.2
or 10.0.0.1
or
10.0.1.2
Or something similar.
Hope that is enough to get the machines talking.
I know nothing about rocorail. Sorry
NN
wearing the Pink Pinny, which is hard to see and now have a new shiny tin Hip
GSRR Offline
#3 Posted : 13 July 2010 00:46:42(UTC)
GSRR
James,
Have you visited the forum and posed your question there? It maybe an issue with Windows 7 not being supported yet?
http://forum.rocrail.net/portal.php
Thomas
ETE-ENE ECoS iTrain TouchCab C-Gleis German Era Id & IIIb USA Era IIIb SBB Era III SJ Era IV GC Era V
Piper Offline
#4 Posted : 13 July 2010 00:49:59(UTC)
Piper
Hi James,
Nevw is right, setup by using the method as described and use your internet browser to make sure you can see the CS2 from your computer. This is even before you run Rocrail, to make 110% sure there is coms between CS2 & your computer.
Then you also need to put the gateway tick in on the setup screen on CS2, where you set the IP address and add your computer's IP address to enable Rocrail/CS2 to know where to get S88 feedbacks, if you use them.
In Rocrail just enter the IP address of your CS2. That's it, give it a try and let us know.ThumpUp ThumpUp
It works quite nicely and is apart from WinDigipet is the only software to works with the CS2.
Cursing Cursing When you get to MFX locos it becomes a bit fiddly, but once you set it up, it works just fine.
Pieter
Era I-V / HO / C-Track / MS, MS2, CS1 & CS2 RR&Co Z gauge. Insider
Member of Märklin Modellers Group
James Offline
#5 Posted : 14 July 2010 18:51:54(UTC)
James
Thanks Guys:
At this time, I'm trying out two systems, iTrain and Rocrail.
So far, this is what I've found:
iTrain
(1)claims that it will work with the CS2, although not as well as it will with the CS1 or the ESU controller, which would make sense since ESU built the CS1.
(2)iTrain's English instructions are clear although a bit technical for my level of computer savvy.
(3)The download contains everything in the package to get one up and running, once I figure the software out.
(4)Developing a track plan is possible although a bit like using a back door to build.
Rocrail
(1)claims that it will work with the CS 2 and after I was able to get the two device to talk to one another I think that it might work.
(2)RocRail's English instructions appear to have been run through an online translator. It is like trying to read a set of instructions written by a six year old. It is very poor and is full of German words that are untranslatable. This makes it unusable and therefore no help at all.
(3)The download of this program is a nightmare. Trying to figure out which download is what I need is impossible. After I downloaded the version I thought I needed, I was confronted with instructional prompts that claimed I needed to download other programs (Rocrail View, and RocRail Server). It took me awhile to figure out that RocRail server was the actual program...I think. I'm still not sure what RocRail View is.
(4)Certain pull down menus mentioned in the instructions do not actually appear in the software menus. All in all, this is a nightmare.
(5)So far I have not been able to create a track plan in this system, the instructions for such a thing are not present.
For my money, neither of these systems are very user friendly. If one is a computer programmer, then iTrain would be the one to go with. Rocrail is perhaps the one to go with if one is fluent in German.
All I want is a plug n play software system that will work for my system, one that has clear concise instructions in English and one that doesn`t require that I have a diploma in C++ programming. At this time, I don`t think that this is possible.
James Bannerman
Besra Offline
#6 Posted : 01 August 2010 10:48:00(UTC)
Besra
Hi James,
I agree Rocrail's instructions sometimes are not very straightforward. We are working on that!
Please give this Wiki-page a try: http://wiki.rocrail.net/doku.php?id=stepbystep-en. It is not yet translated completely but should guide you through the first steps. I will try to translate additional chapters the next days. To set-up the CS2 please follow the instructions here: http://wiki.rocrail.net/doku.php?id=cs2:cs2-en#setup
By the way: I am not a member of Rocrail's developer team but I'm trying to improve the wiki to the best of my ability and I'm not a native English speaker, so please excuse my wording.
Besra
GSRR Offline
#7 Posted : 02 August 2010 00:42:05(UTC)
GSRR
Besra wrote:
Hi James,
Besra
Besra,
Welcome to the forum. Appreciate the effort with Rocrail.
Thomas
Bigdaddynz Offline
#8 Posted : 02 August 2010 01:03:08(UTC)
iTrain also supports the CS2. http://berros.eu/itrain/
steventrain Offline
#9 Posted : 02 August 2010 20:46:59(UTC)
Hi Besra,
Large Marklinist layout with C-tracks/Central station 2/Mobile station 2/Boosters 60174s/Marklin collector since 1990s/Collector Marklin from the 1950s/Favorites Steam class BR01/BR03/BR05/BR50/Insider Club membership.
Webmaster Offline
#10 Posted : 02 August 2010 22:20:22(UTC)
Besra, thanks for joining the forum since RocRail is unknown territory for most of us! ThumpUp
Besra Offline
#11 Posted : 04 August 2010 15:53:22(UTC)
Besra
Thank your for your welcome messages!
I will try to answer any questions concerning Rocrail you may have - prior to your subscription to Rocrail's own famous forum BigGrin.
I came across Rocrail about 18 months ago looking for some freeware layout control software or a demo - wasn't sure if I like computer control at that time. Well, I do. Meanwhile Rocrail controls my whole layout.
Besra
Piper Offline
#12 Posted : 04 August 2010 19:47:52(UTC)
Piper
Hi Besra
I agree with Juhan, most welcome and we need a expert of Rocrail. ThumpUp ThumpUp
Do you have some info about your layout?
How many blocks do you have and do you use S88's or what do you use for feedback.
Pieter
Besra Offline
#13 Posted : 04 August 2010 22:56:38(UTC)
Besra
Hi Pieter,
I'm probably not a Rocrail expert, let's say a somewhat experienced user...
I think I have to collect some data of my layout because I'm currently not aware of all details. At least, M-tracks, 19 or 20 blocks, about 50 locos, all Marklin except for two BRAWA and I'm using LocoNet feedbacks connected to Uhlenbrock's Intellibox. A Marklin Infra Control 80f is attached to the Intellibox. Blocks are equipped with at least one feedback (no current sensors, no occupation detectors, contacts only), most feature two feedback sensors, some have up to four. My layout is in my attic of about 30 square meters.
Besra
This page was generated in 0.734 seconds.
Map
See the web site statistics
Bookmark and Share
