fvri wrote:Hi Thomas, Well I'm still in somekind of wintersleep. Currently, I have it very hard professional and I don't have a lot of time to continue 'serious' development. On the other hand I would like to continue but I'm some what stucked with thirdparty SW I'm using (QuickGraph). With these graph algo's I would like to improve the way the user could easily define routes. Strange but downloads of LC have increased since I stopped development... Best regards, Frank Frank, Thank you for the update, and some encouraging words from Juhan. Regards, Thomas |
ETE-ENE  ECoS iTrain TouchCab C-Gleis German Era Id & IIIb USA Era IIIb SBB Era III SJ Era IV GC Era V |
Joined: 27/08/2005(UTC) Posts: 11,291 Location: Strathpine QLD
Frank, I am not ready yet as I am about 25% into the development of a new layout however I will be using the software to run the layout when I get there. I all ways download the latest release. Nev |
wearing the Pink Pinny, which is hard to see and now have a new shiny tin Hip Junior member of the Banana Club, a reformist and an old Goat with a Bad memory, loafing around |
Joined: 07/10/2002(UTC) Posts: 773 Location: Zwevezele,
Hi Juhan, Yes indeed your forum has certainly contributed to the success of LC at least making it known to a large model railroad public visiting this great MM forum. Especially a number of members in this forum (Frankie, Dntower65, Michael, ...) have given a lot of feedback so that I could improve it. If it is really a success well I really don't know, sometimes I'm suprised to see people visiting my LC forum "fvri.forumco.com" after a long time. So then I suspect they are still interested or using it. But, I don't get a lot of feedback neither good or bad. But, I'm already very glad if a few people are using it. BTW. how are you currently doing in C# programming? Best regards, Frank Edited by user 05 February 2010 11:37:51(UTC)
| Reason: Not specified |
Hi Nev,
Nice to hear that you are still using LC for controlling your 'ongoing' new layout. I hope all is now well with your shoulder/arm.
Best regards, Frank |
fvri wrote:Hi Nev,
Best regards, Frank
COming along slowly. was going OK until I had another fall  and then overdid the exercises and tore a Muscle.  Time will cure all. NN |
I updated my ECoS to firmware version 3.3.3 but it seems the protocol 0.2 is not compatible with LC V1.0.27 at least not for updating the locs.
I might still do an update of LC to support the protocol V0.02... as I'm not able to use any longer my LC and my ECoS1 :).
Joined: 17/09/2006(UTC) Posts: 12,212 Location: New Zealand
Frank, I used LC to transfer my loco list from my CS1 (v2.0.4) to my (new for me) Ecos1 (v3.3.3). I got a whole bunch of errors when transferring from LC to the Ecos, but the list of locos still appeared in the Ecos. Hopefully, it won't be too much work for you to update LC.
I see in your other thread that the changes are around the Function Descriptions, and it was there that I noticed that some of the function symbols had not been transferred across.
Normally I should be a small and easy fix... :).
Joined: 08/01/2006(UTC) Posts: 2,208 Location: Shady Shores, TX - USA
Originally Posted by: fvri  Normally I should be a small and easy fix... :).
Best regards, Frank Frank Just a note. I did a quick test (meaning I put in the IP number and that was about all I did) with the ECoC II connected to LocCommander it did connect and I could turn the Ecos off and on but could not run a Loc got an unknown error. Now don't worry about it and go run that marathon. |
DT Now powered by ECoS II unit#2, RocRail
era - some time in the future when the space time continuum is disrupted and ICE 3 Trains run on the same rails as the Adler and BR18's. |
Hi Darrin, Before you can control a loc with LocCommander you will need to have a catalog (wit train objects) that corresponds to the object data base of the ECoS system. In the loccommander forum you'll find the necessary explanation how to do this, see: http://fvri.forumco.com/topic.asp?TOPIC_ID=11I hope this will help! But as the ECoS PC protocol V0.2 has a new syntax for exporting the train functions the export of the existing catalog (train) objects in LocCommander will fail or at least will not be complete. Yeah, counting down for the marathon in Paris on the 10 April. The only thing that matters now is to stay healthy to accomplish this mission... Best regards, Frank |
