Offline siroljuk
#1 Posted : 23 June 2015 08:14:55(UTC)
siroljuk
Hello everyone.
I assume that someone has already examined the structure of CS2 files and directories. Is there any way to find programmed memory sequences by browsing CS2´s web server?
If I can find files which include programmed memory sequence is it possible to copy that file to Usb-stick and edit it then in PC and copy back to CS2?
I can see lots of files by browsing CS2´s webserver, but it is hard to see the file structure, so that there could find what you are looking for. Does someone know if theres is somewhere a MAP of filetructure of CS2?
My target is to find a way to copy all necessary fileas example MEMORY sequences and all stuff needed, to USB and the send it to my friend who copy all files to his or hers CS2 and run sequences there.
Happy TrainingBigGrin
Jukka
#2 Posted : 23 June 2015 08:29:17(UTC)
Point your browser @ http://xxx.xxx.xxx.xxx/config/fahrstrassen.cs2
Offline siroljuk
#3 Posted : 23 June 2015 11:09:26(UTC)
siroljuk
Thank you Peter!
Now I remember that I have asked this before.
I have made some homework and I relized that it is not very good idea to make changes to CS2 by moving files into CS2. You can do so, but there are many possibilities to make mistakes.
It don´t make sense to try to move individual files from CS2 to another by copying and using USB-stick.
in fact, I don´t intend to try to transfer and reproduction, because the entire CS2 unit can go to accidentally fail.
Jukka
This page was generated in 0.201 seconds.
