marklin-users.net community
| Forum
Home
Community Forum
Login
or
Register
Forum
Active Topics
Login
Register
OK
General topics
Digital
memory program CS2
2 Pages
1
2
Go to Page...
memory program CS2
Email this topic
LinkBack Topic URL
Retweet this Topic
Share Topic on Google+
Like this Topic
Share on Facebook
Digg this Topic
Reddit this Topic
Share on Tumblr
Watch this topic
Print this topic
» Normal
Threaded
Previous Topic
Next Topic
#51
Posted :
25 March 2015 00:45:06(UTC)
Retweet
Re:
Picture 11
This TEXT-item is here only for timing. I think this is basicly ment for delaytime at the station.
This is a convenient delay technique, however its real purpose is to compose a timetable for use with either mFX+ GameWorld locomotive operation or with the schedule clock mode.
Refer to separate section on "Using the Memory to set up TimeTables"
1 user liked this useful post by clapcott
siroljuk
User Profile
View All Posts by User
View Thanks
#52
Posted :
25 March 2015 00:50:35(UTC)
Retweet
Re: page 11
- Impulse Function
To avoid confusion I would suggest using the same terminology as can be seen in the picture - i.e. "Momentary Function"
User Profile
View Thanks
siroljuk
#53
Posted :
25 March 2015 08:07:34(UTC)
Retweet
Hello everyone,
Thank you Peter for your valuable comments and corrections. I am going to make changes to document.
Because I don´t have mFX+ locos I cannot write anything about those features.¨
When I saw that Märklin is going to publish new book about CS2 and it´s features I decided to wait for that before I continue writing.
Anyways, I have been testing all the time S88 features around memory and also various number of contact points an so on.
I have learned all the time better and better that the best way to automate is keeping everythin as simple as possible.
Don´t try to make complicated sequences, make clear and small secuences, only few items inside and combine those. dont´t try to make complicated memory packages. Write always your plans on the paper too.
CUT THE POWER before you do anything with you layout hardware.
There is a lot of fun to use your brain as part of the routes "on line."That is the whole trick of playing with Märklin isn´t it.
Happy trainig
Jukka
User Profile
View Thanks
#54
Posted :
25 March 2015 20:04:29(UTC)
Retweet
The "Timetable" facility has yet to mature in my opinion, and right now is a solution looking for a problem. I would also stil call the implementation a bit "clunky"
That said it can be demonstrated in both mFX+ cab mode (not Steam) or on the Clock mode of the Control panel.
If you have a memory sequence definded with text in it, then clicking the timetable window of CabMode or the display window below the clock will provide a menu with just those memory sequences (i.e. it will filter out the other memory sequences)
I will reserve judgement, however what the book does not provide and which this forum does, is a two way dialogue with "how do you do ..." Q&A.
I am surprised I haven't seen any posts like this, which might be used as real life scenarios.
siroljuk
User Profile
View Thanks
siroljuk
#55
Posted :
26 March 2015 08:21:04(UTC)
Retweet
Very good, I am quite excited
about this:
""If you have a memory sequence definded with text in it, then clicking the timetable window of CabMode or the display window below the clock will provide a menu with just those memory sequences (i.e. it will filter out the other memory sequences)""
This opens up completely new opportunities for my studies, hopefully CS2 speed is enough for all experiments.
When you try you learn. . . and by reading the forum you learn more and more.
Thank you
Happy training
Jukka
User Profile
View Thanks
siroljuk
#56
Posted :
26 March 2015 10:02:47(UTC)
Retweet
Originally Posted by: clapcott
Re: ... page 3, under picture 2
When activated BR94 start run three seconds in speed of 53 ( at the moment I don’t excatly know what that 53 stands for)
Below is from the help file "hilfe/de/fsitem_speed.html" translated using google ...
In summary the CS2 uses a 0-1000 scale for its internal speed range - this is divided into increments based on the decoders definition of # of steps.
Possibly the easiest way to conceive this is as a percentage divided by 10 - thus 53 = 5.3% of maximum speed
This is rather an over simplification as ...
- the speed curve set into the decoders of modern locomotives is rarely linear
- for a given decoder speed step (say 14 on a 28 step decoder) the scope within the 1000 range could be from approx 482 to 512 )
however it does give a starting reference.
- the magic around a 27 step decoder interpreting a 1-14 command range depends on acceleration v deceleration.
I have my reservation about the calculation shown
I suggest you would be better to learn the speed by driving the loco the way you want and noting the values anyway.
FWIW, on the normal CS2 throttle control page, the FS (Fahstufen) value shown next to the green speed bar max's out a "-1" (1 less) than the specified decoder. i.e. for an mfx 126 step decoder it is 125 and for an old MM 14 step decoder it is 13.
Change engine run command
Loco
Selection of the loco to be controlled
Speed
desired speed of the locomotive in parts per thousand (1: 1000) of the maximum speed of the locomotive
0 = stopping the locomotive with ABV
1 = locomotive runs at the lowest possible gear
100 = train reaches 10% of full speed
500 = train reaches 50% of full speed
750 = train reaches 75% of full speed
1000 = train reaches full speed
Waiting period
The pause after this step run (real-time hh: mm: ss.ss)
If you want to calculate the (per 1000) value for an appropriate gear (decoder spreed step) , the following formula is used:
- Rate (per thousand) = 1+ (increment * ( desired_speed_step -1))
The step size is obtained from the number of speed steps, supported by the decoder:
14 speed steps
increment = 77
27 speed steps
increment = 38
28 speed steps
increment = 37
31 speed steps
increment = 33
126 speed steps
increment = 8
Hi Peter, How on earth you find this link: ""hilfe/de/fsitem_speed.html"", I tried to find it, but I didn´t.
Maybe you have similar hidden secrets, please tell us how to find them
Jukka
User Profile
View Thanks
#57
Posted :
26 March 2015 11:13:59(UTC)
Retweet
If you press the help button on the "edit route element" screen for a locomotive it is missing any English text however it will show hilfe/
en
/fsitem_speed.html. By changing the "
en
" to "
de
" you get the german help page.
This page is found either in the directory you installed the CS2-PC program for direct from your CS2 (on the network) at
http://xxx.xxx.xxx.xxx/hilfe/de/fsitem_speed.html
Of course if you have set up the CS2 (or CS2-PC) with language = de the the help works OK
2 users liked this useful post by clapcott
GSRR
siroljuk
User Profile
View Thanks
siroljuk
#58
Posted :
26 March 2015 17:01:31(UTC)
Retweet
Thank you very much.
Then it really is so that we have to start to study German language, because English version help doesn´t show all important things in CS2.
That is really bad thing.
Does anyone know how to get into CS2 and its website so that we could read all txt-files what we can find inside.
I think it would be much easier to translate all help files. Who know what marvellous information there might be.
regards Jukka
User Profile
View Thanks
2 Pages
1
2
Go to Page...
General topics
Digital
memory program CS2
General topics
- General MRR
- H0-scale
- Small scale
- Big scale
- Prototype
--- Videos
----- Steam
----- Electric
----- Diesel
----- Accidents
- Digital
- Model railroad software
- Model railroad photography
Reviews
- Loco Reviews
- Reviews of rolling stock
- Accessories reviews
- Model kit reviews
Collector's Corner
- Collector's Corner general
- Märklin Sprint
- Construction kits
- Steam engines
- Tinplate toys
- Märklin Factory Layouts
The Projects & Workshop area
- Track plans
- Painting & Weathering
- Model railroad wiring
The Club Corner
You
cannot
You
cannot
You
cannot
You
cannot
You
cannot
create polls in this forum.
You
cannot
vote in polls in this forum.
Powered by YAF.NET
YAF.NET © 2003-2024, Yet Another Forum.NET
This page was generated in 0.434 seconds.
