Online TrainIride
#1 Posted : 07 February 2015 11:22:24(UTC)
TrainIride
Hi Friends,
Found on the web this incredible picture, that's why I've copied it here.
The German E44 with the French BB10000 on the same tracks, somewhere in France in the early 1950's
I was so happy to find a good reason to run simultaneously two of my favourite models on my layout Wink .
More details on this history will come soon.
And if someone knows more about this, please post !
Joël
thanks 11 users liked this useful post by TrainIride
Online TrainIride
#2 Posted : 07 February 2015 11:24:36(UTC)
TrainIride
So I've tried to reproduce this mood at home....
thanks 8 users liked this useful post by TrainIride
#3 Posted : 07 February 2015 11:59:17(UTC)
The German E44 with the French BB10000 on the same tracks, somewhere in France in the early 1950s
interesting photo.
The loco on the picture is E 244 22, a loco compatible with the SNCF voltage. It is not an E 44.
It is based on the E 44 and became E 44 189 after a conversion in 1965.
On a model layout, an E 44 will do as a substitute for an E 244.
Online TrainIride
#4 Posted : 07 February 2015 12:29:02(UTC)
TrainIride
interesting photo.
Hi Tom You are absolutely right !
In fact E244 was based on E44 Prototype and was used in Germany
on the Höllental railroad to test catenary feeded with 20000v 50Hz Ac current.
French SNCF was interested by these tests because 20kv AC power
was reducing costs of power plants and catenary installation.
Instead of previous common 1500v DC current more easy to drive motors,
but needing bigger overhead copper wires and more power plants along the tracks...
It is interesting to see that AC vs. DC current was also a question for real train companies - same for modellers BigGrin .
So E244-22 was lent to SNCF for tests on a first small 78km AC line in France.
SNCF ordered also to ALSTOM a loco to run on these tracks.
Alstom used parts of the NS1100 prototype to build the "BB10001" equipped with DC motors
but embedding an AC/DC converter...
thanks 5 users liked this useful post by TrainIride
Online TrainIride
#5 Posted : 07 February 2015 12:47:40(UTC)
TrainIride
The E244 22 prototype was build with parts of the E44 005
thanks 7 users liked this useful post by TrainIride
Online TrainIride
#6 Posted : 07 February 2015 12:53:58(UTC)
TrainIride
The BB10001 prototype was at first named BB8051
thanks 6 users liked this useful post by TrainIride
Online TrainIride
#7 Posted : 13 February 2015 15:24:07(UTC)
TrainIride
BB10001 has even been painted in blue :
#8 Posted : 13 February 2015 20:09:36(UTC)
Hi Friends,
Joël
Ok,easy enough!
The 244 was in France to test the new 50hz catenary system.
The 244 is a variation of the 144, used on the Hollentalbahn at the time which was one of the few industrial frequency rr in Europe.
Obviously it had to be moved to the test grounds, which explains why it was in tow of a 1500v DC loco.
Hope this helps
Jacques
#9 Posted : 14 February 2015 01:36:10(UTC)
Just for information, this locomotive (CC6051) was ordered from BBC/SAAS in the early 1950s and shares a lot in common with a very well known Swiss locomotive series.
Any guesses which Maerklin model I am referring to?
Online TrainIride
#10 Posted : 14 February 2015 10:02:06(UTC)
TrainIride
Maybe the one at right on the pic ? Wink
Joël
thanks 3 users liked this useful post by TrainIride
Online TrainIride
#11 Posted : 14 February 2015 10:05:45(UTC)
TrainIride
Hi Friends,
Joël
Ok,easy enough!
Hope this helps
Jacques
Hi Jacques,
The BB10001 was not a DC Loco .
It has four DC engines but had an embedded AC/DC converter to run (and only) under AC catenary !
Joël
thanks 2 users liked this useful post by TrainIride
#12 Posted : 14 February 2015 10:08:36(UTC)
On the photo both locos have one raised pantograph. The E 244 (the E is significant here as the E 244 was for 50 Hz while the 244 of the DR was for 16 2/3 Hz - and an E 144 would have been a DC loco) was an AC loco - so what power is on the catenary if both raised their pantographs?
Maybe there is no power and both locos were just on display?
Online TrainIride
#13 Posted : 14 February 2015 10:14:39(UTC)
TrainIride
Both were powered, at first experiment with 20000v 50Hz
Then, the voltage was raised to 25000v 50Hz
Joël
Online TrainIride
#14 Posted : 14 February 2015 10:17:46(UTC)
TrainIride
Again,
BB8051 renumbered BB10001, was an AC loco !!
Online TrainIride
#15 Posted : 14 February 2015 10:30:31(UTC)
TrainIride
And more than ten years later, in 1963,
BB10001 was again modified to be able to run on both systems:
25kV 50Hz AC
1500V DC
Joël
Offline Wildrose-Wally
#16 Posted : 14 February 2015 12:21:35(UTC)
Wildrose-Wally
The NS 1100 series was based on the four-axle SNCF BB 8001 locomotive and BB 8100 series.
Wildrose-Wally attached the following image(s):
thanks 6 users liked this useful post by Wildrose-Wally
Online TrainIride
#17 Posted : 14 February 2015 12:31:16(UTC)
TrainIride
Yes, and you can see on the pics above of BB8051/BB10001 , behind the front SNCF logo, the shape of the NS one !
To build the AC Loco, ALSTOM company used external chassis ans body of NS 1100 serie they were making in the early 1950's
See above
Thank you for the pic and information !
Best Regards
Joël
This page was generated in 0.711 seconds.
