Offline jstedge
#1 Posted : 27 September 2011 02:54:43(UTC)
jstedge
Hi;
Looking for some insight on Marklin's BR18. To the best of my limited knowledge, I found three versions of the BR18 that are slightly older: 3518, 3618 & the 3318. Looking to find out what the differences are and which one I should get, if any....
thanks for any help you can give me.
Jeff Stedge
Offline BR01097
#2 Posted : 27 September 2011 04:18:33(UTC)
BR01097
The difference in the versions by catalogue number is that one is digital, another has high-efficiency propulsion (the 3500-series), and the last has Delta or conventional operation. I picked up the digital version--sans a few parts on the boiler--for a pretty good price, but its running is sometimes spotty if it is changed between analogue and digital operation.
Offline jstedge
#3 Posted : 27 September 2011 04:45:48(UTC)
jstedge
Thanks for the very quick follow up. Sounds like the high propulsion one is the one to get. I am assuming that the other non-digital models will not run at all on a digital layout. Any difference in performance between the three? Difference in details? They look exactly the same to my untrained eye.
Thanks again,
Jeff
#4 Posted : 27 September 2011 05:48:40(UTC)
Jeff,
Please note: the 3500 series, although it has a 5 pole armature it hasn't got a permanent magnet, so the voltage is still AC and not DC going through the motor.
The 3600 series are digital but again AC and a 6080 decoder.
Delta locos (33xx) can run on digital but have restricted access (1-80 loco numbers)
I've just done a conversion for a member (high efficiency motor conversion set), it can be done but there is a scale of difficulties involved in it all depends how much experience you've got in trying to do it.
Online H0
#5 Posted : 27 September 2011 10:33:59(UTC)
The 3318 in question here is analogue, not Delta.
Most Delta decoders are limited to 15 addresses out of 80 (80 addresses accessible with a soldering iron).
The three models are BR 18.4. Märklin also made BR 18.1 and BR 18.3 in H0.
Overview of older BR 18.1/18.4 Märklin models:
http://www.hfkern.de/Maerklin/Dt_Loks_D18.html
#6 Posted : 27 September 2011 11:32:12(UTC)
To add some confusion there aare a belgium Vesion and I think a French (I could be wrong thre)
Nev
Offline Osterthun
#7 Posted : 27 September 2011 20:15:58(UTC)
Osterthun
Hi Pink Panther (Nevw), indeed there are some foreign versions in Entente livery, such as models for Belgium in brown (NMBS/SNCB) and France in green (ETAT, NORD, SNCF), the latter even with deflectors. For information and pictures, please have a look at my ModelsList.
These versions are based on the 'simple' 3091/3093 versions with AC-propulsion.
Frits Osterthun
http://www.osterthun.com/2.Static/Xtra2/M3317.jpg
© Frits Osterthun
(PS: I do have my 3318 for sale).
© Frits Osterthun
thanks 1 user liked this useful post by Osterthun
#8 Posted : 28 September 2011 01:14:52(UTC)
Frits,
I have a 3111 now converted to Digital, as well as the Marklin MFX model 37184.
Nev
Offline BR01097
#9 Posted : 28 September 2011 05:08:09(UTC)
BR01097
Not fond of any of the S 3/6 variations when they started their roll-out in 1978, now somehow I have most of them:
3092 S 3/6 3673 2'C1'h4v
3093 18 478 2'C1'h4v
3618 18 434 2'C1'h4v
3091 231 981 2'C1'h4v
3111 59 80 2'C1'h4v
Guess they're not without their charms. [Incidentally, most digital locomotives will work just fine on analogue layout; some will not have headlights available though.]
Offline amartinezv
#10 Posted : 28 September 2011 11:58:05(UTC)
amartinezv
Hello
3318 is analog
3518 is also analog, but with 5 stars engine
3618 is digital, but with c80, that means only light function and no choice to adjust speed or inertia
Best regards Smile
Antonio Martínez
www.raildigital.es/davidruso
Offline igf2
#11 Posted : 28 September 2011 14:35:40(UTC)
igf2
Hello
Here are some more references and photos :
3111 Belgian SNCB
33185 Germany KB
3618 Germany DR
3317 France SNCF
3083 France Etat
3093 Germany DB
thanks 6 users liked this useful post by igf2
Offline Frits Osterthun
#12 Posted : 24 January 2015 21:28:25(UTC)
Frits Osterthun
Today's fotoshoot gave me the opportunity to shoot the Märklin 3083 ETAT Saintes (with black gear construction) at my dealers.
http://www.osterthun.com/2.Static/Xtra2/M3083-Rv.JPG
http://www.osterthun.com/2.Static/Xtra2/M3083-LvLok.JPG
Märklin 3083 © Frits Osterthun
thanks 10 users liked this useful post by Frits Osterthun
Offline amartinezv
#13 Posted : 24 January 2015 21:59:00(UTC)
amartinezv
Hello
Here is a good report about these locos
http://www.lctm.info/Sec...s/L009_BR18/HO/index.htm
Antonio Martínez
thanks 6 users liked this useful post by amartinezv
This page was generated in 0.745 seconds.
