Offline TRUKO
#1 Posted : 04 June 2009 11:23:57(UTC)
TRUKO
Hi All,
Rocrail Rocks!!! Yesterday I got it all up and running so I'am able to drive my trains via the PC with Rocrail.
You'll take over the controls from the CS2. In the down right corner you see the Rocrail server running polling all messages from and to the CS2.
Some details at this (beginning) stage:
- currently I've only MFX locs running
- there is no feedback electronics installed yet
- the switches can be contolled also via Rocrail
- all MFX functions of the loc's can be managed from Rocrail
- the CS2 is still on version: 1.0.5 (3)
It has taken a few hours to get it all up and running, so I think thats rather quick.
Up to now I'am very happy with Rocrail, with the software on the screen in front of you and the manual, it is not a ig problem to setup it all together.
You can see more on: http://sites.google.com/site/derangeerbaan/rocrail
and the Rocrail forum: http://forum.rocrail.net/portal.php
Rutger
Model Railway: Marklin C rails | Digital CS2 | Rocrail | Website: http://www.derangeerbaan.com/
#2 Posted : 04 June 2009 12:22:21(UTC)
Very good Rutger. Because I have been using fvri's LocCommander, I never got around to having a play with Rocrail.
Therefore, I am interested to hear of your experiences with it.
Of course, the 3rd free train control software package is Control-GUI, which again, I haven't got around to using.
Offline MarioFabro
#3 Posted : 04 June 2009 17:24:28(UTC)
MarioFabro
Can we have (or do we have) a comparison between the different software offered for train controls?
Offline TRUKO
#4 Posted : 04 June 2009 19:16:08(UTC)
TRUKO
Hello all,
@Bigdaddyzn: Ok,I personally have no experience with LocCommander. I will keep you posted about Rocrail, any special interest area's?
@MarioFabro: as far as I know ther eis no comparison table or something about train controll software, so maybe you can make one?
Rutger
Offline dntower85
#5 Posted : 04 June 2009 19:48:30(UTC)
dntower85
@Rutger how are trains controlled in Rocrail, I see a clock so are they timed based?
One of the reasons I like LocCommander is that it has a state based engine for automatic train control. If an event happens and conditions are met then commanded actions happen.
DT
Offline TRUKO
#6 Posted : 04 June 2009 22:45:09(UTC)
TRUKO
[size=1" face="Verdana" id="quote]quote:Originally posted by dntower85
Hi DNtower85,
I'am just starting with Rocrail so probably about a few months I can give you all the details, but what I have seen it looks like it is possible to have the train fully automated running. When you've build in feedback messages from the track, Rocrail can set in "automate modus" and it will start running the loc's. Also you can setup events in de definition of the locs, and you're able to setup train routes and train time tables.
Hope this helps from this beginner...wink
Rutger
#7 Posted : 04 June 2009 23:21:54(UTC)
Excellent, Rutger.
Offline fvri
#8 Posted : 05 June 2009 10:46:45(UTC)
fvri
This webpage gives some overview:
http://www.digital-bahn.de/info_kompo/software.htm
Br,
Frank
Offline TRUKO
#9 Posted : 11 July 2009 03:26:38(UTC)
TRUKO
I'am a little further in the Rocrail world and can confirm now that the trains can run according a timetable which is related to the clock.
Rutger
Online xxup
#10 Posted : 12 July 2009 06:12:51(UTC)
Roco rail for Windows works well, but I can't get the Linux version to talk to the eCOS - I suspect that I need a particular string for the INI file.. Perhaps I will struggle through it during the Christmas break...
Offline TRUKO
#11 Posted : 19 July 2009 02:47:50(UTC)
TRUKO
<br />Roco rail for Windows works well, but I can't get the Linux version to talk to the eCOS - I suspect that I need a particular string for the INI file.. Perhaps I will struggle through it during the Christmas break...
Maybe this link give some help: http://forum.rocrail.net...=681&highlight=linux
Good luck,
Rutger
Offline TRUKO
#12 Posted : 19 July 2009 02:50:37(UTC)
TRUKO
[size=1" face="Verdana" id="quote]quote:Originally posted by fvri
<br />Hi,
Br,
Frank
Hi All,
Just for info: the Rocrail part of this page is updated: http://www.digital-bahn....mpo/software.htm#rocrail
One look at the number of supported command stations, the green dots of supported options and the pricing should be enough.SmileSmile
Rutger
Offline TRUKO
#13 Posted : 05 August 2009 14:51:06(UTC)
TRUKO
Yesterday I reached the milestone that the first TrainSchedule was operational in Rocrail on "De Rangeerbaan". The train nicely travels from Block to Block and stops in the Station just before the Red sign. If you're interested I put a part of my configuration settings on my website. They are in Dutch, but probably the screens also are for some help.
http://sites.google.com/...ail/rocrail-configuratie
Rutger
Offline dntower85
#14 Posted : 05 August 2009 16:59:06(UTC)
dntower85
[size=1" face="Verdana" id="quote]quote:Originally posted by TRUKO
<br />Hi all,
Rutger
I am as impressed with you web site and the info on RocRail as I have been with your welded steal frame for your layout. biggrin
The web site translates well using google translate. Thanks for all the info. I have just gotten my second S88 so I can now properly define my blocks properly, so after I get that set up I may give RocRail a try.
Have you found any limitations using RocRail?
DT
Offline TRUKO
#15 Posted : 05 August 2009 17:35:16(UTC)
TRUKO
<br />Hi all,
Yesterday I reached the milestone that the first TrainSchedule was operational in Rocrail on "De Rangeerbaan". The train nicely travels from Block to Block and stops in the Station just before the Red sign. If you're interested I put a part of my configuration settings on my website. They are in Dutch, but probably the screens also are for some help. http://sites.google.com/...ail/rocrail-configuratie
Rutger
Thanks for the compliments...[:I] I'am curious how do you use Google translate with my website? I didn't know about that feature.
Currently I did not discover limitations with using Rocrail, but as you can see, I'am just starting. So keep you posted.
Thganks,
Rutger
Offline dntower85
#16 Posted : 05 August 2009 18:01:57(UTC)
dntower85
Thganks,
Rutger
its easy just copy and past you url on this page
http://translate.google.com/translate_t?hl=en#
then select the language for from and to.
I have been looking at the Manual for Rocrail again and now I remember why I had shied away from it. They have too much info in the manual to sift through to get to a simple setup, they make it look harder than it is.
They needed some simple examples like you have shown.
DT
Offline TRUKO
#17 Posted : 05 August 2009 18:14:24(UTC)
TRUKO
Thganks,
Rutger
Thanks for the tip, i was searching now on Google translate.
To be honest you're right. It takes me a lot of time before I figured out how to configure blocks, Routes and Schedules...The Wikipedia and the text in the menu's is confusing sometimes.
I will update my pages with more examples, hopefully it helps you and others, because it's a good program and the support from the developpers team via the forum is excellent!!
Rutger
Offline TRUKO
#18 Posted : 10 August 2009 16:10:18(UTC)
TRUKO
Hello All,
I added the configuration of a Schedule: http://sites.google.com/...guratie-Dienstrooster-01
Copy the URL in 'Google Trnaslate' and you can read it in your own language.
Rutger
Offline TRUKO
#19 Posted : 11 August 2009 22:54:40(UTC)
TRUKO
Update:
- one Route with the BR01 'clock wise' + Schedule
- one Route with the BR64 'counter clock wise' + Schedule
I'am now starting with configuring the other Blocks, Routes and the functions on the Loc's like steamsound, whistle etc.
Remember to copy and past the url in 'Google translate' to read it in your own language.
Be continued,
Groet,
Rutger
Offline TRUKO
#20 Posted : 20 December 2009 18:57:15(UTC)
TRUKO
Hello All,
I moved my website to a new domain: www.derangeerbaan.com
this website will be updated and the old one will dissappear in januari.
Please enjoy: http://www.derangeerbaan.../home/computer-besturing
Rutger
#21 Posted : 20 December 2009 22:40:30(UTC)
Thganks,
Rutger
It's even easier with the latest Google toolbar plugins, both for IE and Firefox. When viewing a foreign language web page, you now get a translate button, which when clicking on translates the page for you there and then. Very useful for ebay and suchlike.
This page was generated in 0.928 seconds.
