Online river6109
#1 Posted : 12 August 2016 12:37:52(UTC)
Hi, you may already know this but I've just realized the latest ESU adapter plates 51968 have now 6 Aux functions whereas before they only had 4.
which is a great improvement. I've bought the 51970 to be able to add all the functions for my BR 85 (smoke generator, 2 Telex coupling, gear light, fire box and cab light, have I had known I didn't need this one which has 10 Aux functions and is quite more expensive.
I've just improved my SBB Cargo Re 482 (36660) with a sound decoder,
German light configuration:
3 headlights,
2 high beam
2 marker lights
Swiss light configuration
3 headlights - 1 light rear
2 high beam
2 marker lights
1 marker light
I'm quite pleased with the outcome, I'm waiting now for the 4 headlight fittings, and I'll cover the light defuser with shrink tube so the light doesn't transfer from one tube to another.
I also electrically connected the 4 pantographs
I'll have 2 of these SBB Cargo locos but the second one will just have German light configuration and why ? because I've put the smd Led's in the wrong order. Cursing
I will post pictures when they are all ready
Offline anthpao
#2 Posted : 13 August 2016 01:35:58(UTC)
anthpao
Do you mean that it has except from the front and rear lights power outputs for aux1 to aux4 or aux1 to aux6?
Online river6109
#3 Posted : 13 August 2016 09:55:28(UTC)
FO = front light
FO = rear light
Aux 1 - Aux 6,
the original 51968 had 4 aux functions and this has now been updated to 6 aux functions. it shows I had these for at least 2 month and haven't noticed it. it was only when I soldered a blue wire onto the 21 mtc adapter plate did I notice the Aux 6 functions and I was a bit shocked but pleasantly surprised. 2nd edition March 2106, it has taken 7 years to upgrade it
it means now I like to update some of my locos again and this is another job on my list in the near future.
for instance locos with telex coupling Aux 1 & Aux 2) had only 2 Aux left, Aux 3 & Aux 4) 1 would have been used for the smoke generator, 1 for the gear light, there was no chance adding a cab light or a fire box light (Steam locos.)with electric locos its pretty much the same: if you had 2 telex couplings (Aux 1 & Aux 2), my configuration with the interior lights (Aux 3 & Aux 4) there was no choice of adding 2 driver cab lights.
I haven't looked at the ESU website if they've announced an update for this adapter plate.
Offline GlennM
#4 Posted : 13 August 2016 19:32:43(UTC)
GlennM
Hello John, the Forum Luddite here,
I have only recently started to upgrade old locos with new decoders, and I am assuming that once this plate is installed and wired, you can insert any 21 pin decoder to the plate, or does it have to be an ESU decoder?
I have read quite a few of your conversions, but not sure if I can recall what part you use for the firebox light?
Looking forward to seeing the pictures ThumpUp
BR
#5 Posted : 13 August 2016 19:39:31(UTC)
mLD and mSD are not NEM compatible and cannot be used.
mLD/3 and mSD/3 have CVs that make them NEM compatible, so they can be used.
But they only support AUX1 through AUX4. You get AUX5 and AUX6 when you disable the motor outputs, but I'm afraid this is not compatible with the ESU board.
I am not sure, but it could be that only newer ESU decoders support AUX1 through AUX6.
Update: After checking ESU catalogue and manuals I assume that the only ESU loco decoders with support for AUX5/6 are recent LokSound V4 without M4.
Online river6109
#6 Posted : 14 August 2016 04:15:52(UTC)
Tom, when you say recent Loksound V4.0 decoders, are you suggesting earlier sound decoder V 4.0 are not in this category (Aux 5 & 6) ? is it not possible to update the decoder firmware ?
Online river6109
#7 Posted : 14 August 2016 04:23:27(UTC)
BR, the firebox light, a.) to establish such function, one has to drill a hole into the metal housing where the firebox door is, if the hole already exists, than with a lokprogrammer, you open the window under function output and than click on the light mode effect and a drop down menu appears with 20 different application. under 3 & 4 you will see the firebox and smart firebox.
#8 Posted : 14 August 2016 07:47:31(UTC)
is it not possible to update the decoder firmware?
John,
I don't work for ESU.
In the latest manual they give different specs for "v41" and "v43" decoders. Maybe there is such a mark on the decoder, I didn't check that yet.
Does not look like a software issue, I think there are hardware changes.
Offline Bart
#9 Posted : 17 August 2016 10:40:37(UTC)
Bart
That's interesting news.
AFAIK, the ESU decoders only have 2 amplified AUX outputs, so that would imply that the new 51968 now has 4 amplifiers on board.
Could anyone confirm?
I can't find the new documentation on the ESU site - any link available?
*Bart
Online river6109
#10 Posted : 19 August 2016 07:31:29(UTC)
Bart, here is a documentation of the adapter board (2) 51968 although the picture and instruction manual shows the older type, I don't know where Tom got it from
I don't think the 2 amplified outputs have changed.
here is the front side
#11 Posted : 19 August 2016 08:11:38(UTC)
I was referring to the latest LokSound manual on their site which documents 8 outputs for the v43 V4 decoders.
I didn't find the current adapterplate manual on their site.
I didn't see information about 8 outputs in the LokPilot manual.
Offline Bart
#12 Posted : 19 August 2016 19:16:09(UTC)
Bart
Yes, it has changed.
Looks like 2 double transistors (6 connections each), indicating 4 amplifiers, while the original 51968 had only 1 of those double transistors.
This is supported by the newest Loksound manual (May, 2016 version), which contains this table:
LokSound V4.0
LSV41 21MTC: 4/250 mA + 2 Logik
LSV41 PluX / Kabelbaum: 6/250mA
LSV43 21MTC: 4/250 mA + 4 Logik
LSV43 PluX / Kabelbaum: 8/250mA
LokSound V4.0 M4: 6/250mA
Assuming that LSV41/43 indicate different versions 4.1 and 4.3, the v4.3 Loksound 4 21MTC was enhanced to have 2 additional unamplified ("Logik") outputs (now AUX 3/4/5/6 as compared to AUX 3/4 in v4.1).
This would be in agreement with the 4 amplifiers on the new 51968 board.
Surprisingly, if the table is correct, the M4 version is now suggested to have amplified AUX 1 thru 4 ("6/250mA"), which I find somewhat hard to believe. That would render it compatible with Märklin boards but incompatible with the 51968 board, which wants to see unamplified AUX3/4 inputs.
There is no updated LokPilot 4 manual online, so we will wait and see whether the 21MTC LokPilots are being updated as well to have AUX5/6 available (and whether the M4 versions now will have amplified AUX3/4 to make them fully Märklin compatible).
Interestingly, the older PluX22 LokPilot 4 M4 already had 9 amplified outputs, so neither costs nor space were a limitation to add output transistors on the decoder board itself; it is just the 21MTC protocol that limits the number of outputs.
*Bart
#13 Posted : 19 August 2016 19:41:11(UTC)
Page 25 in the manual indicates that AUX3 through AUX6 are still logic-level outputs, so ESU would still be NEM-compatible and not Märklin-compatible. Also see table on page 58.
There are some inconsistencies in the manual, so in case of doubt contact ESU for details.
One example: AUX5/6 are missing in the diagram on page 15.
It is possible to make outputs switchable between logic level and amplified - ESU do that for the fx decoders, Märklin do it with the msd/3 and mld/3 decoders. But there is no hint about such a feature in the May manual.
Offline Bart
#14 Posted : 19 August 2016 19:59:56(UTC)
Bart
Yes, it appears that not all paragraphs in the manual were updated to accommodate the v43 changes.
You are probably right that the table on page 8 I referred to (suggesting Mä compatibility of the M4) is incorrect and the table on page 58 is correct.
It would be hard to believe if ESU now would give up NEM660 in favor of Märklin's standard.
*Bart
#15 Posted : 20 August 2016 18:03:10(UTC)
So what constitutes the difference between version 41 and version 43?
Is there an actual hardware difference on the decoder?
Or is it just a different version of software that uses the available outputs differently?
#16 Posted : 20 August 2016 18:20:31(UTC)
The difference between LokSound 3 and LokSound 3.5 was just firmware - you can use the LokProgrammer to upgrade a decoder from LokSound 3 to LokSound 3.5.
But IMHO a firmware upgrade won't be enough to upgrade a LokSound 4 decoder from 6 outputs to 8 outputs.
I take it for granted that "v41" and "v43" refer to hardware versions. I still didn't check if a small "v41" can be seen on the decoder PCB.
I assume they added more outputs for the PluX22 socket and now also make most of them also available for the 21MTC socket.
Online river6109
#17 Posted : 21 August 2016 10:37:19(UTC)
sofar I have updated my sound decoder V4 and I have some new ones but there seems to be no problem having 8 outputs, what I will try later today and see if the older and new V4 lokpilots also respond to 8 outputs.
This page was generated in 0.668 seconds.
