Offline Rwill
#1 Posted : 29 July 2016 14:49:32(UTC)
Rwill
Sorry for dumb questions.
I know that for two rail operation, marklin wheel sets are no good as they short out - but what of the other way round? Can you run two rail wagons on K track without changing the wheels?. My fuddled brain also recalls a problem with the flange depths of non M wheels on M,K or C track.
#2 Posted : 29 July 2016 18:02:35(UTC)
I know that for two rail operation, Marklin wheel sets are no good as they short out - but what of the other way round? Can you run two rail wagons on K track without changing the wheels?. My fuddled brain also recalls a problem with the flange depths of non M wheels on M,K or C track.
There is a difference in the depth of the flanges and also the back-to-back measurement, which is the distance between the backs of the wheels on either side. Some wheel-sets allow for the wheels to be slid along the axles to correct this. The flange depth will only be a problem on some really ancient wheels, and sometimes if the depth is very little it may be easier to derail on turnouts.
Some manufacturers manage to get a compromise wheel dimension which works for both 2-rail and 3-rail tracks. I have no problems with my Roco wheels, for instance, Others are more stringent, and in the case of my Lilliput wagons I always have to change the wheels to prevent derailing on turnouts. Piko are somewhere in between. Some wagons will be alright and others not.
#3 Posted : 29 July 2016 22:41:02(UTC)
Ray is 200% right!!
Most two-rail axles will work on Märklin, **providing you adjust the inner space** (distance between flanges) to 13.8 mm (vs 14.3 mm in 2 rail)
The gauge to measure and adjust easily is here https://www.fohrmann.com/en/rail-gauge-h0.html
I even have had success with RP 25 style reduced flange wheels, but only on well laid C-track;
Hope this answers your question
Edited by user 30 July 2016 07:13:41(UTC)  | Reason: Not specified
Offline Hackcell
#4 Posted : 01 August 2016 02:10:16(UTC)
Hackcell
Costa Rica
I have no major issues using RP-25 wheels on my C tracks, the only thing I have to do is to adjust the distance between wheels and voilá.
Danilo Jiménez
Costa Rica, pura vida!!
thanks 1 user liked this useful post by Hackcell
cheap Chinese wheelsets (H0-scale)
by heinrichhess 18/08/2023 18:11:19(UTC)
Strategies for bridging/"uninsulating" Trix/Roco DC Wheelsets for AC Signaling Continuity? (H0-scale)
by 5HorizonsRR 12/01/2023 17:08:53(UTC)
DC wheelsets and Marklin track (H0-scale)
by revmox 17/06/2022 07:03:57(UTC)
Substitute wheelsets for VT11,5 (37605) motor bogie¿? (H0-scale)
by hxmiesa 23/04/2021 20:31:07(UTC)
Spoked 9mm AC wheelsets (H0-scale)
by PMPeter 28/04/2019 20:03:41(UTC)
Problems when installing AC wheelsets on DC rolling stock freight cars (H0-scale)
by Minok 05/04/2019 21:26:35(UTC)
AC Wheelsets (H0-scale)
by Amr 25/08/2018 19:10:34(UTC)
Piko and Lilliput wheelsets (H0-scale)
by Jabez 14/08/2018 01:01:05(UTC)
Converting Wheelsets from 3 to 2 rail (H0-scale)
by mb300e4m 18/03/2018 19:52:21(UTC)
The never ending discussion on changing 2rail for 3rail wheelsets (and vice versa) (General MRR)
by jvuye 10/12/2016 06:39:15(UTC)
Changing wheelsets for DC 2-rail operation (H0-scale)
by Ian Byrne 18/04/2016 23:57:49(UTC)
Part number AC wheelsets? (H0-scale)
by biedmatt 26/01/2016 20:43:56(UTC)
Metal wheelsets for large scale passenger cars (General MRR)
by tommycox 04/12/2015 22:07:48(UTC)
DC wheelsets and C Track turnouts. (H0-scale)
by Sparrow 18/07/2015 21:21:17(UTC)
Double Decker coach Wheelsets? (General MRR)
by BigJeffyLawd 04/12/2013 23:42:28(UTC)
Spoked AC Wheelsets for 43019 & 43981 Coaches? (General MRR)
by DumbGuy 30/09/2013 12:26:56(UTC)
Cars of other makes on Märklin track - Exchanging wheelsets (H0-scale)
by Elukka 17/04/2011 03:56:24(UTC)
Cleaning corrosion off wheelsets (Small scale)
by ozzman 03/04/2010 10:41:38(UTC)
Marklin wheelsets on other brands? (H0-scale)
by obxbill 30/12/2008 05:10:57(UTC)
Trix rp 25 wheelsets (H0-scale)
by jselter 18/06/2008 17:41:27(UTC)
Ordering American Style Wheelsets As Spare Parts? (H0-scale)
by Amerklin 04/08/2007 02:04:34(UTC)
Wheelsets from other brands on K-track ? (H0-scale)
by KjellAn 13/02/2006 21:55:32(UTC)
ROCO Wheelsets (General MRR)
by Peter Neumann 17/12/2005 07:27:30(UTC)
This page was generated in 0.527 seconds.
