Offline thomas buckley
#1 Posted : 21 May 2016 00:44:03(UTC)
thomas buckley
i have gotten my turntable to move back and forth after replacing the entire motor and housing with older working unit, yeah! Now I put it all together and run my analog loco through switch yard and the moment it is on turntable, it stops. i observe that the loco moves slowly till it reaches table, plus, on the yard side the loco will not reverse. on layout side of turntable everything works normally. the turntable itself has low miles, contacts look new etc. the motor was replaced due to hard oil syndrome, bad magnet, just easier to install known good motor. what should i look for to get the loco to complete the trip from yard to layout?
Offline analogmike
#2 Posted : 21 May 2016 02:49:03(UTC)
analogmike
add power to the yard side, see if it helps. mikey
#3 Posted : 21 May 2016 20:12:11(UTC)
thomas buckley
should i connect feeder track to yard side with another transformer, is that possible with AC?, or connect track from layout side and make yard continuous with rest of layout? (a challenge in geometry lol) Thanks in advance for the help!!
Offline analogmike
#4 Posted : 21 May 2016 20:19:31(UTC)
analogmike
You can do it either way but for now just go to the same trafo. add a ground too. older m-track can loose ground. sometimes it need help. mikey
#5 Posted : 28 May 2016 20:14:16(UTC)
thomas buckley
I added power to yard side and loco ran better, reversed and such. However, when loco reaches turntable, it just plain stops. I used my handy dandy multimeter, set to AC voltage and there is no voltage on turntable, even though the turntable is working back and forth. What should I look for on turntable? I thought the turntable was good but maybe my reassembly was defective?!!!
Offline carlos.rivas.16752
#6 Posted : 28 May 2016 20:50:38(UTC)
carlos.rivas.16752
Maybe there's an unsoldered cable somewhere...look under the turntable. Or maybe sometjing is wrong with the joint piece in the edge of the turntable
My blog both in Spanish and English: https://grunewiesen1965.wordpress.com
thanks 1 user liked this useful post by carlos.rivas.16752
Offline analogmike
#7 Posted : 29 May 2016 15:59:41(UTC)
analogmike
Ah ha, Now with a lok on the table and the traffo track power at about 1/2 get a pencil and put pressure on the three metal clips near the center of the bridge and see if the lok moves. If it does dust may need to be cleaned from the contact ring. The clips may also need adjustment. It is not difficult to get the bridge off from the table. Flip the entire assy over and remove the "E"- clip from the center taking care not to lose it. I have to do this to mine every few years or so. One day I will make a little cover for it to keep the dust out. Good luck Mikey
thanks 3 users liked this useful post by analogmike
#8 Posted : 29 May 2016 16:37:27(UTC)
carlos.rivas.16752
thanks 3 users liked this useful post by carlos.rivas.16752
#9 Posted : 01 June 2016 23:03:51(UTC)
thomas buckley
Will wonders never cease, cleaned every contact with 91% alcohol and got intermittent contact with loco. duh me! cleaned track rails with rag and alcohol and voila, runs great. got to keep reminding myself to keep it simple, fix the obvious. at least the turntable is spotless, :)) thanks for the help
thanks 1 user liked this useful post by thomas buckley
Offline analogmike
#10 Posted : 03 June 2016 21:38:08(UTC)
analogmike
Dirty Track
Mikey
Offline biedmatt
#11 Posted : 03 June 2016 21:42:50(UTC)
biedmatt
My dirty track never looks like that, where can I find some?
Matt
Era 3
Offline analogmike
#12 Posted : 03 June 2016 22:16:12(UTC)
analogmike
You gotta go to Thomas Buckley's house.
#13 Posted : 19 June 2016 19:02:51(UTC)
thomas buckley
lmao!! my dirty track is "redhead" but yeah:))
Offline analogmike
#14 Posted : 20 June 2016 00:36:46(UTC)
analogmike
OK then, REDHEAD dirty track;
Laugh Laugh Laugh
Online kiwiAlan
#15 Posted : 20 June 2016 01:00:55(UTC)
Not going to get far without any wheels though ... Drool
Offline analogmike
#16 Posted : 20 June 2016 03:27:39(UTC)
analogmike
Is this better?Flapper
Offline Rwill
#17 Posted : 20 June 2016 08:05:43(UTC)
Rwill
Still not going to get very far unless they put it on the track.
Offline analogmike
#18 Posted : 20 June 2016 12:25:47(UTC)
analogmike
I know and you know but they don't. For the time being they seem to be quiet and happy so let's leave them alone. Mikey
#19 Posted : 20 June 2016 19:31:21(UTC)
thomas buckley
omg, you guys are funny!!!
This page was generated in 0.544 seconds.
