Offline camcath
#1 Posted : 30 April 2016 05:01:25(UTC)
camcath
I just received a Brawa 42904 loco from Germany and it doesn't have the advertised functionality eg no cab light and no destination light. I am wondering if this is because of my controller, an MS2 that has not been upgraded for some time. Any advice gratefully received.
Cameron
#2 Posted : 30 April 2016 08:28:15(UTC)
With the MS2 you can access the first 16 functions of the loco - provided the MS2 is optimally configured. If the cab light is in the range F5 through F15 then check your configuration.
Is it an H0 loco? (There is an H0 forum on this site.)
Which class is it?
Which version does your MS2 have?
Offline camcath
#3 Posted : 30 April 2016 08:43:40(UTC)
camcath
Thanks Tom
I only get five functions when the loco registers. Yes it is H0. I have had the MS2 for three years and no update in that time.
Cameron
#4 Posted : 30 April 2016 08:47:47(UTC)
Do you call "Detect loco"?
Do you get a DCC loco?
If yes: add function symbols (under Edit loco) for F5 through F15 as needed - you can also select other symbols for F0 through F4.
#5 Posted : 30 April 2016 09:29:05(UTC)
Yours locomotive Brawa 42904 are analog basic.
You must verified correct what kind of locomotive you have.
Offline camcath
#6 Posted : 30 April 2016 11:57:04(UTC)
camcath
You are right - my error, its Brawa 42903. Tom, it reads as a DCC loco, not sure how to add function symbols, but will have a go.
Cameron
#7 Posted : 30 April 2016 12:16:58(UTC)
See pages 14 and 15 of the MS2 manual.
#8 Posted : 30 April 2016 15:00:54(UTC)
Cameron
Okey
This model can been reprogrammed by change protocols too.
If you shall use DCC,make sure MS2 stand with this protocol too.
This page was generated in 0.432 seconds.
