Offline Khanzir
#1 Posted : 10 February 2016 00:25:52(UTC)
Khanzir
Hi friends
I got the DB BR 184 as a part of a set. Its a great Lok, runs very well. But has only the 3 lights front and back. I want to upgrade this so can have sounds too. can I do that?
#2 Posted : 10 February 2016 02:31:19(UTC)
I believe that that locomotive was one of the ones that were designed by Trix and then issued in AC by Maerklin. It should be possible to add a decoder to it. I am not sure of what other adaptations may be required to convert an analog version to DC. What was the item number of the set? I know that there was a set (digital and analog versions) with a 184 and Rola cars with trucks.
I also know that LS Models has a ESU decoder with sounds for the BR 184. ESU might also have a separate sound file too.
#3 Posted : 10 February 2016 08:42:23(UTC)
My Br 184 (37312) has the standard Marklin DCM motor.
https://medienpdb.maerkl...es/1/pdf/37312_explo.pdf
It is no great problem to replace the supplied decoder with a sound decoder and add a speaker.
This page was generated in 0.375 seconds.
