Offline Martin T
#1 Posted : 05 February 2016 17:04:17(UTC)
Martin T
Hi! :)
For most of my layouts I´ve been either buying ready-made walls and platforms, or been engraving in plaster on a wooden plate.
Now however, I´ve gone over to making all engraving in Styrofoam, finishing with a layer of plaster and then Acrylic paint.
The colours can be varied to fit whatever scenario you´re going for, but the process stays more or less the same.
Surpricingly enough I made a video-tutorial! LOL
Regards / Martin T
thanks 13 users liked this useful post by Martin T
#2 Posted : 06 February 2016 05:25:33(UTC)
Originally Posted by: Martin T Go to Quoted Post
Hi! :)
Hello Martin,
I felt I had achieved a fair result with scenery on my layout, mostly using Woodland Scenics and other products from Faller, Vollmer, Kibri, Merkur et al with but a few original base construction ideas of my own, however I have learnt many lessons from your posts and video-tutorials.
I absolutely admire your skills in producing great results at minimal cost from simple materials that are all around us.
You are indeed a master of the craft !!
PJ
Offline Br502362
#3 Posted : 06 February 2016 06:32:28(UTC)
Br502362
Hi Martin,
I noticed that you had some problems when cutting styrofoam.
You didn't get very smooth surface with the hot wire.
Make a scale to both stencils and cut styrofoam with a friend.
You both repeat scale numbers when cutting so that you cut in the same pace.
This is the best way. I have cut rc scale model wings with this method over 40 years.
Mvh
Åke
Offline Martin T
#4 Posted : 06 February 2016 23:22:03(UTC)
Martin T
Hi! :)
Hello Martin,
PJ
Ohh! Smile Thank you very much for the kind Words!! Blushing
I so glad to be able share the ways of doing things I found useful over time and even more happy it´s for help for you too.
Regards / Martin T
Offline Martin T
#5 Posted : 06 February 2016 23:24:53(UTC)
Martin T
Hi Martin,
Mvh
Åke
BigGrin Same here! I used this method to cut F2 Combat Wings in line Control aeromodelling. Yeah... For that use the shape is more important than for a support pillars, but for sure.. With help the result improves a lot. ThumpUp
Regards / Martin T
thanks 1 user liked this useful post by Martin T
Offline dennisb
#6 Posted : 07 February 2016 09:22:16(UTC)
dennisb
Nice video, again! Thanks for sharing!
D.
This page was generated in 0.467 seconds.
