Offline Timnomads
#1 Posted : 01 December 2015 16:31:36(UTC)
Timnomads
I am using two M83s to work my uncouplers (16 of them (its in my shunting yard))
I have set up the first in my CS2 with the dip switches set to 1, so the first 4 complet positions control the first 8 uncouplers, 2 per position. When I set the dip switches of the second M83 to 5, the next position for uncouplers 9 to 16. This does not work. I reversed the M83s and thats ok for 1 to 8, so I know the M83s work. Is my address of 5 for the dip switch incorrect if so what should it be ?
Can I plug the M83s together and use just one dip switch setting for both ?
Tim
#2 Posted : 01 December 2015 19:25:37(UTC)
I may be stupid here, since I don't have an M83 - but have you tried to set the DIP switches to "2" on the second unit?
Offline Thewolf
#3 Posted : 01 December 2015 20:00:52(UTC)
Thewolf
The second M83 has a adress different
Here :
Hopefully it helps
Thewolf
Project The Richelieu Valley Railway-CS2-Track C- Itrain-Digital
Offline Thewolf
#4 Posted : 01 December 2015 20:04:17(UTC)
Thewolf
adresses 1-4 : first M83 dip switch 1 on others off
adresses 5-8 : second M83 dip switch 1 off 2 on others off
And so on ...
Thewolf
Offline sjlauritsen
#5 Posted : 01 December 2015 21:16:51(UTC)
sjlauritsen
Some times you have to wiggle the DIP-switches a bit. I usually set all of them into position, even though they seem like they are in position, they can be slightly out of placement.
Søren from Denmark
thanks 1 user liked this useful post by sjlauritsen
Offline Thewolf
#6 Posted : 01 December 2015 22:20:40(UTC)
Thewolf
Very important also
Offline oranda
#7 Posted : 17 December 2015 19:58:16(UTC)
oranda
I use wooden tooth picks or cocktail sticks to push the dip switches. They are sharp and don't damage the dip switches.
thanks 2 users liked this useful post by oranda
#8 Posted : 18 December 2015 09:37:04(UTC)
Dip switches of the m83 are very small,so this way of work toy was smart!
ThumpUp
This page was generated in 0.725 seconds.
